  • Aciera
  • Aciera's Avatar
10 Oct 2025 15:12 - 10 Oct 2025 15:15
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
You'll need to make the hal connections in the postgui_hal file. Have a look at the millturn sim confi, (uses an xml instead of a glade file but the setup is the same.
github.com/LinuxCNC/linuxcnc/tree/master...xis/vismach/millturn
  • DerKlotz
  • DerKlotz
10 Oct 2025 15:05 - 10 Oct 2025 15:06
Category: GladeVCP
Hello,
I would like to have a header on my Linuxcnc interface that switches Pin17=hm2_7i76e.0.7i76.0.0.output-00 on and off on my Mesa7i76e. So far, I have created an LED and a button in Glade. This already appears on the Linuxcnc interface, but no control content is stored. How do I proceed? I tried to do some preliminary work on the Glade page, but failed. What do I need to do and where?
Thank you
  • RLA
  • RLA
10 Oct 2025 14:28
Replied by RLA on topic AC Servo change to run
OK...so would I still need a new INI file?...I have been trying to make a new configuration by copying original which has 9 axis, but it is not working..was just copying and renaming...missing something....but if that is not necessary even better!!
Thanks again,
Rick
  • Aciera
  • Aciera's Avatar
10 Oct 2025 14:17
Replied by Aciera on topic rotary axis brakes
rotary axis brakes
In [EMCMOT] section of your ini file you need to remove this line:
EMCMOT = motmod
The ini file parser takes the first match when looking for a keyword hence the next line with the 'unlock_joints_mask' is not taking effect.
  • alexandrap
  • alexandrap
10 Oct 2025 13:37 - 10 Oct 2025 17:35
Replied by alexandrap on topic My MESA 7i95T wiring
Category: Driver Boards
MPG - initial attempts
is used original connection of MPG wheel to Encoder 4, configuration only with PNCconfig and manual editing of one component in HAL file based on the solution in this post :
162.243.45.186/39-pncconf/51627-mpg-issue-on-mesa-7i77
net joint-select-a     (b,c)
to
net axis-select-x    (y,z)
I need to change the scale and maximum speed settings.
It's a shame that the MPG configuration error in PNCCONFG hasn't been fixed - it would be possible for beginners (like me) to configure MESA 7i95T (and others...) using only PNCCONFG without manual editing
  • jefsaro
  • jefsaro's Avatar
10 Oct 2025 13:28 - 10 Oct 2025 13:36
rotary axis brakes was created by jefsaro
rotary axis brakes
Bonjour ,
je voudrais mettre le freins sur l 'axe rotatif A, j'ai mis le fichier ini a jours mais je pense que j 'ai quelque chose qui manque , pouvez vous m 'aider?
  • meister
  • meister
10 Oct 2025 12:30
I have expanded rio so that you can also create rpi5-gpio and parport configs.
it's not direct mixable with the FPGA configs :(
  • meister
  • meister
10 Oct 2025 12:27
Replied by meister on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Hab mal rio aufgebohrt, so das man auch rpi5 gpio configs generieren kann :)
  • Fabse
  • Fabse
10 Oct 2025 12:06
Axis configuration not fully working on 2.9.6
Category: AXIS
Hey and thanks for your reply!
I experimented with version 2.9.6 for a bit, but I can not find the fault that causes my problems. It just does not make sense that my config functions perfectly when running 2.9.4 and then goes broken after updating to 2.9.5/6.
I also noticed that calling MDI commands does not work. I have a command that zeroes my z-axis, which I can activate via a pyvcp button. This does not work anymore.
I am a bit relieved that I am not the only one having issues after updating, but I would love to find a solution to all of this!
As for now, I will stick to 2.9.4..
Displaying 12946 - 12954 out of 12954 results.
Time to create page: 0.489 seconds
