  • timaer
  • timaer
22 Jul 2024 02:02
Can I embeded Vismach into Qtvcp ? was created by timaer
Category: Qtvcp
Hi,everyone.
     I'm developing a cnc control panel using Qtvcp,and I need to display the vismach 3d model and movement in the qtvcp UI interface,but I dont know how to make it ,does anyone help me how to make vismach 3d model and movement in qtvcp's UI interface (not popup window),thank you
  • Thayloreing
  • Thayloreing
22 Jul 2024 01:48
How to make Linuxcnc open with the feed and override 0?
yes I understand, I saw your answers there, I thank you for responding, but the link you gave me in the other post I tried to make it work but I couldn't, I even asked more questions there but I didn't get an answer, so I created another one, my apologies
22 Jul 2024 01:31
Replied by Cant do this anymore bye all on topic How to make Linuxcnc open with the feed and override 0?
First off tommy & myself replied.
Second, no double posting.
  • Thayloreing
  • Thayloreing
22 Jul 2024 01:19
I need to make Linuxcnc open with the feed and rapid closed, I've asked this question before, but I didn't get any results, I saw another post that the guy did using Python, but I didn't understand what he did, I even asked a question in his post, but no answer, can anyone help me?
  • phillc54
  • phillc54's Avatar
22 Jul 2024 01:10
Replied by phillc54 on topic 4 axis foam cutter configuration
Category: AXIS
You could create a  USER_COMMAND_FILE  in your config directory with a copy of the method from glnav.py like below. You do need to restart LinuxCNC to apply each change.
Warning: Spoiler!
  • Thayloreing
  • Thayloreing
21 Jul 2024 23:47
I looked at this post, but I didn't understand what was done so that Linuxcnc when opened has the feed override and the rapid override closed, I tried everything, can you explain to me how to do it, I know this issue has been going on for a while, I've been away for a while, thanks if anyone can help me
  • stirra
  • stirra
21 Jul 2024 22:31
Replied by stirra on topic 4 axis foam cutter configuration
Category: AXIS
Well, the file seems to be /usr/lib/python3/dist-packages/glnav.py , but I find my intuition for spherical coordinates is severely lacking. Setting the lat/lon to 0,0 gets the wire into the horizontal plane, but rotating it around in a desirable fashion is proving difficult. Is there a way to overload this set_view_p function somewhere downstream so I don't have to edit a python3 package, creating problems with future system software updates?
Thanks again.
-- Ralph
  • cmorley
  • cmorley
21 Jul 2024 21:54
Replied by cmorley on topic Spindle Inhibit while Probing.....
Category: Qtvcp
Excellent.
I am updating the docs on this a bit. hopefully you can critique the docs update later
when I push them.
  • Roguish
  • Roguish's Avatar
21 Jul 2024 21:36
Replied by Roguish on topic Spindle Inhibit while Probing.....
Category: Qtvcp
and again. thanks for the quick reply.
note my last edit in my last post.
I did add some hal commands, and I think it's working ok now.
  • cmorley
  • cmorley
21 Jul 2024 21:04
Category: Qtvcp
You are using the development version of linuxcnc.
Documentation will never be perfect, It's lucky there are any updated documentation in the master version, mostly because it constantly changes and a lack of time.
Obviously we are not paid to do this work.
It is expected that you will try to figure things out yourself and then ask questions on what you can't.
Some people then write new documentation from the info they figured out and/or were told about and offer it to linuxcnc, so as to help out. This is very helpful.
It's in fact harder to write good docs when you already know how something is supposed to work as you don't think about other ways to operate the feature.
Ok which problem do you want to work on first?
You can see in the picture there is a button that says 'no lift' eg spindle lift is turned off.
You can see in the pic the setting 'spindle raise' is set to 0 inches eg no spindle raise amount.
If you set these to 'spindle raise' and 1 inch respectably, run a program and then pause the program, you should see the program pause and the spindle stop and the spindle raise 1 inch.
This absolutely works in the sim configs.
This new feature - inhibit spindle when probe is loaded- is new so the sim has not integrated it.
Both features require controlling the spindle.0.inhibit pin. you can't normally have two driver pins connected to an input. If you use an OR2/logic component (or classicladder/custom component) you can.
You would need to connect qtdragon.spindle-inhibit to one OR input and qtversaprobe.probe-loaded to the other OR input and connect the OR output to spindle.0.inhibit
Now either event will inhibit the spindle.
if you erase the preference file entries while linuxcnc is not running and don't run any version that still uses the old version of versaprobe,you won't see it again.
Chris
  • mooser
  • mooser
21 Jul 2024 20:37 - 21 Aug 2024 13:37
  • my1987toyota
  • my1987toyota's Avatar
21 Jul 2024 20:22 - 21 Jul 2024 21:21
Replied by my1987toyota on topic 4 axis foam cutter configuration
Category: AXIS
I was wondering about this myself, so glad it was made a topic. Foam cutters seem to be seeing an increase
in interest. ( Me included ) I am also curious about it showing a 5th axis.
  • PCW
  • PCW's Avatar
21 Jul 2024 20:18
Replied by PCW on topic RCpwmgen
RCpwmgen
Category: Driver Boards
Nah, it was my late and careless editing of our DNS records
after our hosting provider moved servers around...
  • my1987toyota
21 Jul 2024 20:15
Replied by my1987toyota on topic RCpwmgen
RCpwmgen
The store should be back online (had to update the DNS so make take a while to propagate)
I was hoping it wasn't due to the crowd strike debacle.
  • PCW
  • PCW's Avatar
21 Jul 2024 20:14
watchdog and network connection problems
Category: Installing LinuxCNC
2: enp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether a4:1f:72:67:47:1f brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/8 brd 10.255.255.255 scope global enp4s0
valid_lft forever preferred_lft forever
inet6 fe80::a61f:72ff:fe67:471f/64 scope link proto kernel_ll
Try setting the netmask to /24
and disabling IPV6 in the network settings for enp4s0
Displaying 24781 - 24795 out of 25137 results.
Time to create page: 0.513 seconds
