  • blazini36
  • blazini36
04 Jul 2024 18:46
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Other User Interfaces
Has flex GUI officially integrated MennilTossFlykune's Gremlin approach? Might be a good idea until the other thing is working.
  • jg00163206
  • jg00163206's Avatar
04 Jul 2024 18:33
Replied by jg00163206 on topic error finishing read and joint following error.
also, in step 32 there is an extra : that gets an error if you are cut/pasting the commands.
  • jg00163206
04 Jul 2024 18:31
I'm getting this error now when i update.
W: Skipping acquire of configured file '2.9-rt/source/Sources' as repository 'www.linuxcnc.org bookworm InRelease' does not seem to provide it (sources.list entry misspelt?)
  • ffffrf
  • ffffrf
04 Jul 2024 18:22 - 04 Jul 2024 18:40
Updated linuxcnc 2.7 -> 2.9, now parallel port card not working with sherline
So... I recently got a sherline lathe, and opted to download linuxcnc 2.7 to my dell optiplex 7010. I used a startech pcie to parallel port card and followed the instructions but kept getting errors, however, towards the end, I realized the computer did detect it via lspci -v, and set up stepconf with the lathe and got everything to work.
Now, I eventually plan to use a mesa ethernet board with the lathe so I thought in the meantime to upgrade to the newest linuxcnc version and set up the lathe the same way.
However, it is not working. In stepconf when I test my axis they work, but when I compile, the software no longer moves the axis. When I do sudo lspci -v I do see my parallel port at the address e010 just as i did on linux 2.7. However, when I open up linuxcnc and type in a g code like g01 Z5 F100, I get "no parport registered at e010 (or 0xe010)" and nothing happens. I do not always get "no parport registered at e010 (or 0xe010)" when I restart linuxcnc but regardless the axis do not move.
I am at a loss on what to do as this is the exact same hardware I have been using. I tried clicking on the sherline pins in stepconf as I think that inverts them but nothing has worked.
In stepconf the axis works, and the steppers are energized. If I change the parport address to anything other than e010 or 0xe010, the axis no longer work in stepconf, so I know it is the right address
SHERLINE INI, HAL and terminal
# Generated by stepconf 1.1 at Thu Jul  4 12:14:30 2024
# overwritten when you run stepconf again
[EMC]
MACHINE = sherline
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 2.50
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 25.00
CYCLE_TIME = 0.100
INTRO_TIME = 5
PROGRAM_PREFIX = /home/maksym/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
LATHE = 1
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = sherline.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES =  X Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 23.75
MAX_ACCELERATION = 750.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
STEPGEN_MAXACCEL = 937.5
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
#*** AXIS_Z *******************************
[AXIS_Z]
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
SHERLINE HAL:
[code]# Generated by stepconf 1.1 at Thu Jul  4 12:14:30 2024
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0xe010 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0
loadrt pwmgen output_type=1
addf pwmgen.make-pulses base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 1166.6666666666665
setp pwmgen.0.offset 0.11428571428571428
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm     <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps     <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-at-speed    => spindle.0.at-speed
net spindle-cw <= spindle.0.forward
net estop-out       => parport.0.pin-01-out
net xstep           => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir            => parport.0.pin-03-out
net ystep           => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir            => parport.0.pin-05-out
net zstep           => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir            => parport.0.pin-07-out
net astep           => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir            => parport.0.pin-09-out
net spindle-cw      => parport.0.pin-14-out
net spindle-pwm     => parport.0.pin-16-out
net xenable         => parport.0.pin-17-out
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net zpos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net zpos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net zstep <= stepgen.1.step
net zdir <= stepgen.1.dir
net zenable joint.1.amp-enable-out => stepgen.1.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
TERMINAL:
[code]02:00.0 Serial controller: Asix Electronics Corporation Device 9105 (prog-if 02 [16550])
    Subsystem: Asix Electronics Corporation (Wrong ID) Device 1000
    Flags: fast devsel, IRQ 16, IOMMU group 10
    I/O ports at e020
[size=8]    Memory at f7c03000 (32-bit, non-prefetchable)
=4K%    Memory at f7c02000 (32-bit, non-prefetchable)
=4K%    Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
    Capabilities: [78] Power Management version 3
    Capabilities: [80] Express Legacy Endpoint, MSI 00
    Capabilities: [100] Virtual Channel
    Capabilities: [800] Advanced Error Reporting
02:00.2 Parallel controller: Asix Electronics Corporation AX99100 PCIe to Multi I/O Controller (prog-if 03 [IEEE1284])
    Subsystem: Asix Electronics Corporation (Wrong ID) Parallel Port
    Flags: bus master, fast devsel, latency 0, IRQ 3, IOMMU group 10
    I/O ports at e010
[size=8]    I/O ports at e000
[size=8]    Memory at f7c01000 (32-bit, non-prefetchable)
=4K%    Memory at f7c00000 (32-bit, non-prefetchable)
    Capabilities: [100] Advanced Error Reporting
 [/size][/size][/size]
[/code][/code]
  • Altenthaler1988
  • Altenthaler1988
04 Jul 2024 18:14
Replied by Altenthaler1988 on topic qtplasmac "torch not showing"
Category: Plasmac
Schaut nicht so aus so das eine fehlermeldung kommt. Muss mann noch etwas installieren als die nackte Linux cnc?
Es ist gerade noch die 2.9.1 drauf vom versuch nur zur info.
Ich habe es wie Talla83 gemacht. Linuxcnc auf usb stick dann als uefi grafisch installiert und dann die mesa Karte mit PNconig Konfuguriert.
Anpingen kann ich sie auch das sieht man im obigen video.
  • cakeslob
  • cakeslob
04 Jul 2024 18:11
Finally got it running without latency errors when coming out of estop. Finally get to use the RPi5.
Tho I can not rule out my messy SPI wiring from the FPGA to the WT32-ETH01.
Still have to have a try with a W5500 module.
Not sure how this effects RIO, but with the remora w5500 one, the wires were crucial to be as short as possible, but also something ground loop was important even with short wires. jiggling the cables effected it a lot more than I expected.
  • Irritant
  • Irritant
04 Jul 2024 18:10
Router Will not run was created by Irritant
Router Will not run
Hi,  I am using a Bosch router on a new install.
I can't get the actual router to turn on and off. Probotix controller.
Pin 14 "Spindle On" does nothing and if I invert the pin it will not stop.
Thanks!
  • Aciera
  • Aciera's Avatar
04 Jul 2024 17:42
Replied by Aciera on topic qtplasmac "torch not showing"
Category: Plasmac
Starte deine Konfiguration von einem Terminal und schau mal ob Du Fehlermeldungen im Terminaloutput findest:
$ linuxcnc
  • Altenthaler1988
  • Altenthaler1988
04 Jul 2024 17:16
Category: Plasmac
Habs mit 2.9.1 ausprobiert und passiert genau das selbe.
Mit 2.8.4 ist qtplasmac noch nicht inbegriffen.
Ich hoffe auf hilfe
  • JT
  • JT's Avatar
04 Jul 2024 17:09
Replied by JT on topic Flexible GUI
Flexible GUI
Started working on a Dark Side theme for keyboard use.
JT
  • meister
  • meister
04 Jul 2024 16:30 - 04 Jul 2024 16:31
Testing max motion.digital-out-NN via control with M64 / M65
www.youtube.com/shorts/eS7oG1WSP3c
M64 P0
G04 P0.01
M65 P0
M64 P3
G04 P0.01
M65 P3
M64 P6
G04 P0.01
M65 P6
M64 P9
G04 P0.01
M65 P9
M64 P12
G04 P0.01
M65 P12
M64 P15
G04 P0.01
M65 P15
M64 P18
G04 P0.01
M65 P18
M64 P21
G04 P0.01
M65 P21
M64 P24
G04 P0.01
M65 P24
M64 P27
G04 P0.01
M65 P27
04 Jul 2024 15:23
  • jmelson
  • jmelson
04 Jul 2024 15:22
Re-Use Existing Servo Motors? 2001 Techno Isel CNC Router.
Category: Driver Boards
AFAIK with parallel port breakout, you will be able to do only step/dir signals - if those servodrives do accept step/dir then you definitely can reuse them. The problem will be the parallel port. It is slow and limits your I/O and also has become ancient relic in PCs. That is why most of folks are using Mesa boards. But for that we need to know more about the drivesaa
The parallel port is not slow, but generating steps by software on the main CPU IS slow.  It is possible to generate roughly 20,000 steps/second on good CPUs, far less on some that don't have good real time performance.  There are various external hardware step generators available.  Mesa and Pico Systems (that's me) can provide these.  Our Universal Stepper Controller can easily do 300,000 steps/second with very good step timing.
Jon
  • andypugh
  • andypugh's Avatar
04 Jul 2024 14:44 - 04 Jul 2024 14:44
Replied by andypugh on topic BLDC component with 8i20 - how to get to work?
Initially, do as I suggested in the mailing list and try to drive the motor from the command-line. Take the rest of LinuxCNC out of the picture.
  • PCW
  • PCW's Avatar
04 Jul 2024 14:43
I would call that an 8 pole motor
Displaying 25366 - 25380 out of 25610 results.
Time to create page: 0.917 seconds
