  • PCW
  • PCW's Avatar
18 May 2026 16:22
Replied by PCW on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
Are the motors connected to the linear axis?
This will affect the loop stability
Can you change the velocity loop gain on the drives?
  • PedPEx
  • PedPEx
18 May 2026 15:38
Retrofitting an old industrial CNC mill with EtherCAT components - MAHO MH400E
Category: EtherCAT
Hello guys,
a friend and i have planned a retrofit of an old industrial CNC Mill - a MAHO MH400E - since many years, after scoring it back in 2020 and driving it through Bavaria while the very first Corona wave hit the whole world.
The first intention was to retrofit the machine with Mesa hardware and LinuxCNC. After destroying two Mesa boards in another machine build, we decided to use propper industrial components. Therefore the desire to use EtherCAT with reliable Beckhoff hardware arose. After gathering all the necessary components over the years, it was finally time to implement drivers and everything in order to install the accumalted hardware into the Maho CNC mill. The whole process can also be found in my bachelors thesis and is publicly available on GitHub .
The thesis is intentionally written in a way, that beginners have all necessary EtherCAT commands, instructions on how to build the repos from source and CiA402 related information centralized in one place.
The retrofit is not finished at the moment and the process of implementing every component into the CNC mill will be shared here. We aim to execute this retrofit to the highest possible standard, drawing on our professional backgrounds in electronics and mechanics.
Starting from 05/2026, the hardware is mounted inside the control cabinet - which is subject to change, all spindle motor speed controll with contactors will be removed and all the 400V components will be replaced with newer Siemens safety hardware and contactors. The machine is able to read the axes position with an accuracy of 2µm (1µm was planned). The root cause of this problem is subject of the future posts. I'll keep you posted.
All machine files can be found in this GitHub Repo (Maho400E-LinuxCNC) , the custom interpolator PCB is also avaliable on GitHub (SinCosEnc-Conv_EP5101) , the custom EtherCAT drivers can be found in the seperate "linuxcnc-ethercat" repo and in the long shot, the Siemens Machine Keyboard ( Siemens-LinuxCNC-Interface ) is also planned for implementation as a seperate EtherCAT device.
If you have any questions, just join the conversation
Best Regards
Patrick
  • RotarySMP
  • RotarySMP's Avatar
18 May 2026 15:12 - 18 May 2026 16:38
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
I have taken many false starts at attempting this over the years. It is nice to finally do something about it.
I would love to know how Schaublin did this with no feedback other than the encoder, and less compute than a toaster. I am not sure if it did real CSS, or just lots of fixed, open loop timed steps. I will let you know how my last change software solution with such open loop, actually works (or not).
Assuming I fail... (good assumption :) ... and need to add a sensor...
Please share your argument for CVT lever feedback vs motor encoder.
I don't really see the advantage of feedback of the CVT positioning lever, given the non-linear relationship of position verses ratio, which would require an equation or LUT,  and have all the inaccuracies and slop in those linkages. That whole drive unit is beautifully engineered and made. Pulling that little 3ph CVT positioning  motor and replacing it with a servo (I have no step gens) adds a fairly complex  mechanical project, and the need for another servo driver (I dont have space for).
A motor encoder would allow for a highly accurate, real time reduction ratio signal, which can be installed with just a mod to the motor cooling duct, a single cable (okay plus one for the electric fan), and connected to an existing spare 7i85 encoder channel. The back gear is only shifted stationary, so the ratio is only adjusted when running by the CVT.
Cheers,
Mark
18 May 2026 13:34
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Category: Turning
My first idea was same as SMC.Collins with a stepper motor instead of the existing AC one on the variator, the second idea would be a linear potentiometer bolted to variator, and analog reading on a Mesa input, low resolution yes, but more that enough for this case.
Set some ranges in hal and be done with it, let the VFD do the fine adjustments.
  • RotarySMP
18 May 2026 09:43 - 18 May 2026 09:47
Category: Turning
Thanks for your ideas, this all really helps.
This is a summary of the various ways I could add sensors, or control to the overall gear ratio.
1/ pull the motor fan, and use the shaft stud to drive an encoder, and then mount an electric cooling fan on the shround for the motor.
++ Seems most robust solution.
++ covers entire drive train with single unit.
++ high resolution, low noise
++ encoder in and encoder out, the gear ratio would be rock steady and real time.
++ does not require pulling the entire drive unit.
++ spare encoder input available on 7i85
2/ Make a little amplifier to scale that 0-10V motor speed output to 0-36V
++ Simplest solution
-- I am not strong in electronics.
-- less resolution than motor encoder
-- lower qualiy signal than encoder
3/ use an optical or hall sensor to count motor fan fins, or CVT features.
++ Slightly simpler that adding an encoder... or not...
-- as it would need the entire drive pulled.
-- less resolution then encoder
-- doesn't sense gearbox ratio.
-- dirty environment, unsuitable for optical sensors.
4/ Add an encoder to the CVT linkage, or to the CVT lead screw.
-- better options above
-- need to pull drive unit.
-- non-linear relationship to ratio
-- needs LUT or algorythm to convert to approx ratio.
5/ Replace the CVT motor with a stepper or servo
-- more work than the better options above
-- large wiring change, add addition servo driver etc
6/ Use a laser range finder on the CVT belt with a look up table to estimate ratio.
-- dirty environment, optics will likely unreliable over time.
7/ Using a sensor to detect backgear lever position .
-- dont think there is an external lever, it is internally, pneumatically actuated with no external moving parts.
-- Since it is only shifted stationary, this is the easiest to infer. I can log last position, and cross sheck it using overall ratio, so this seems unnecessary.
8/ adding a gear tooth detector in the gearbox
-- significant effort to pull, disassemble drive unit, and drill hole in housing, design and mount sensor
Seems to me that the motor encoder would to be the most likely to simply work, and work best. It covers the entire drive train in a single component, offers the highest resolution, and provides (with the spindle encoder) the most direct measurement of overall reduction ratio without noise, interpolation, LUTs etc.
However, before I add a sensor which Schaublin didn't need when they designed this system in the first place, I am thinking of taking one last swing a software solution. My original idea, which I have not yet tried. How accurate does a lathes spindle speed control really need to be?
- divide the CVT range into 5 "fixed ratios", one second apart.
- survey the whole range, generate a look up table of CVT "fixed ratio", and VFD Hz.
- Command the CVT in one second bumps (gear changes).
- largely open loop with VFD frequency interpolated between LUT values.
- Maybe switch to closed loop to fine tune speed (but I am hoping not to need to)
-- if closed loop needed, add PI gains to the LUT.
--  I already have VFD "motor on speed" wired in, and had not thought to use that to gate and freeze the ratio calculation when it would be garbage.
-- when there is steady state operation, use the calculated ratio just to cross check and maybe correct for CVT drift after multiple shifts. In practice, I expect it to be on limits quite often, which is a natural drift reset.
If I can't get that working, and really do need a sensor, I tend to the motor encoder.
  • MiMaMoadlo
  • MiMaMoadlo
18 May 2026 07:15
No unhoming after emergency-stop or limit-sw trigger
Thanks, I will look into these parameters!
My thought behind adding it as an E-stop was to have it as part of the safety relay circuit outside of linuxcnc.
  • Buzzcut
  • Buzzcut
18 May 2026 02:24
Probe screen V2 with Gmoccapy T/M6 causes system to pause - Solved+Corrections
I need help with this. I can not seem to get mine working. If you remember how you where able to do it would be a great help. The hal file only loads after the psng probe screen. I can switch back to the gmoccapy change.ngc and it work as expected but i can then not probe like i want to. I can not get the correct tool height after gcode start. Any help would greatly be appreciated!
18 May 2026 00:25
Replied by tommylight on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
Measure between gnd and each channel.
  • PCW
  • PCW's Avatar
18 May 2026 00:24 - 18 May 2026 00:27
Category: HAL
You cannot do this without two  differential probes.
Measure the A,B signals relative to ground.
But as you said I don't think this is the issue as long as the position
readout is correct.
  • tbrasselle
  • tbrasselle
18 May 2026 00:03
Replied by tbrasselle on topic Mill Retrofit with Fanuc DC Drives
Category: HAL
I was measuring it against the compliment. I had the probe on channel A and the ground on the probe clamped to the inverse channel A. Same thing for channel B.
Viewing channel a and channel b in HALSCOPE everything looks normal. So I’d assume this isn’t actually the issue either.
  • HansU
  • HansU's Avatar
17 May 2026 19:27
Replied by HansU on topic Launching gladevcp panel with gmoccapy
Category: Gmoccapy
The GMOCCAPY documentation indicates that if no EMBED_LOCATION is defined, the the glade VCP will be floating. Is that no longer valid?
AFAIK this was never supported. Where do you have this info from? I can't find such in the current Gmoccapy documentation.
17 May 2026 18:46
  • agant172
  • agant172
17 May 2026 18:31
Mesa conversion for a Mazak VQC 20/40 M2 mill
Category: Driver Boards
Hi all,
Hoping this is the right place for a conversation about machine controller conversions. I'm a hobby user, not a production shop. I've got a  Mazak VQC 20/40 mill with M2 control, it's a nice fully functional machine with good tolerances for it advanced age. It's lack of memory is a real pain point. Programming in Mazatrol CAM M2 was probably great back in the day, not so much now. I can send G-Code files to it, but hit file size limits rather quickly. It's not capable of drip feed. I think I'm ready to go for the Mesa upgrade. With AI help I've input all the info I can think of, this is where I'm at... realistic? reasonable?
Servo Motors & Drives:
X-axis: Mitsubishi HD-81-12 DC permanent magnet servo motor with analog drive accepting ±10V command (terminals: AX, BX, G1X, G2X, G)
Y-axis: Mitsubishi HD-81-12S DC PM servo with analog drive (terminals: AY, BY, G1Y, G2Y, G)
Z-axis: Mitsubishi HD-101-12 DC PM servo with analog drive (terminals: AZ, BZ, G1Z, G2Z, G)
All three drives are MELDA-8 or similar Mitsubishi analog cards that accept ±10V command signals—these are REUSABLE
Position Feedback:
X-axis: Magnescale SR-921RH linear encoder (outputs quadrature signals directly) + MS3100B 20-29P tacho generator
Y-axis: Tamagawa Seiki resolver (MS3108B 20-29P, pins: RS1, RS2, RC1, RC2, RO1, RO2) + tacho generator
Z-axis: Magnescale SR-921RH-450-R-0 linear encoder + MS3108B 20-29P tacho generator
Spindle:
Mitsubishi AC motor SE-EV-FV with FREQROL FR-SX VFD controller
Already accepts 0-10V analog speed command and direction signal—fully LinuxCNC compatible
Tool Changer:
20-tool carousel ATC with CAT40 tooling
Nachi proximity sensors for position detectionMesa Hardware StackCore Cards
7i92H  - Ethernet-based motion controller, main brain
7i77  - 6-axis ±10V analog outputs + encoder inputs + 48 I/O points
7i49 - 6-channel resolver interface (for Y-axis only)
7i73 - Pendant/operator panel interface
Servo Drive Connections:
Existing 24VDC power supply (HR-11F, outputs P24 and G24) remains in service:
Mesa 7i77 I/O is 24V compatible
Existing Contactors (3S-1, 3S-2, 3S-3, 3S-4):
Control servo drive enable sequencing
Spindle power control
Lube/coolant pump control
These stay and get controlled through Mesa 7i77 I/O outputsATC IntegrationInputs to LinuxCNC:
Tool-in-position sensors (Nachi proximity switches)
Carousel rotation feedback
Gripper open/close confirmation
Drawbar clamp/unclamp sensors
Outputs from LinuxCNC:
Carousel motor control (forward/reverse)
Gripper solenoid
Drawbar solenoid
Air blast control
  • andrax
  • andrax's Avatar
17 May 2026 16:43
Replied by andrax on topic Tuning Steperonline A6 Servos
Category: EtherCAT
Oh, I almost forgot – I wanted to let you know if I succeed.I’ve been gradually increasing the C00.05 stiffness parameter.
  • PCW
  • PCW's Avatar
17 May 2026 16:42 - 17 May 2026 16:43
Category: HAL
Are you measuring the encoder signals against ground?
(you cannot measure differential signals on an oscilloscope  without a differential probe)
Displaying 3001 - 3015 out of 13458 results.
Time to create page: 1.666 seconds
