  • Surmetall
  • Surmetall's Avatar
23 Apr 2026 15:02 - 23 Apr 2026 15:05
Replied by Surmetall on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Hi endian,thank you again. I made a completely clean test now with only the AX5125 connected on the EtherCAT bus, no other slaves connected.
I used your files from the zip exactly for the AX test. The startup initCmds file is your Antrieb-1-AX5-0-initCmds.xml unchanged. I only pointed my machine config to that file.
Current result is much better now:
the AX5125 reaches OP when it is the only slave on the bus.Current ethercat slaves output is:
0 0:0 OP + AX5125-0000-0216 EtherCAT Drive (SoE, 1 Ch.)
The important dmesg lines are these:
EtherCAT WARNING 0-0: Slave does not support changing the PDO mapping!
Currently mapped PDO entries: 0x0086:00/16 0x002F:00/32. Entries to map: 0x0086:01/16 0x002F:01/32 0x0024:01/32 0x0050:01/16 0x81E4:01/32 0x81E5:01/32EtherCAT WARNING 0-0: Slave does not support changing the PDO mapping!
Currently mapped PDO entries: 0x0087:00/16 0x0033:00/32 0x00BD:00/32. Entries to map: 0x0087:01/16 0x0033:01/32 0x00BD:01/32 0x0054:01/16 0x0028:01/32 0x81CC:01/16 0x81CD:01/16EtherCAT 0: Slave states on main device: OP.My currently active AX slave config is:
slave idx 0
type generic
vid 0x00000002
pid 0x14056012
name Antrieb-1-AX5-0
configPdos trueMDT PDO 0018 entries requested by config:
0086:01 16 bit
002F:01 32 bit
0024:01 32 bit
0050:01 16 bit
81E4:01 32 bit
81E5:01 32 bitAT PDO 0010 entries requested by config:
0087:01 16 bit
0033:01 32 bit
00BD:01 32 bit
0054:01 16 bit
0028:01 32 bit
81CC:01 16 bit
81CD:01 16 bitDC config currently used:
assignActivate 730
sync0Cycle 250000
sync0Shift 0
sync1Cycle 750000
sync1Shift 0
So the situation now seems to be:
before, the drive stayed in PREOP plus ERROR with MBX_SOE.
now, with only the AX and your startup file, it reaches OP.
but the drive reports that its current mapped PDOs are still the smaller set with subindex 00, while the config wants the extended subindex 01 mapping.
My main question is:
is this already the expected next step, meaning I should now reduce the config to the fixed PDO set the drive actually reports as mapped, or is there still a missing startup/configuration step that should switch the AX5125 to the full 01 PDO mapping?
In other words: now that the drive reaches OP, what is the correct next step before I put the other slaves back on the bus?
Thanks a lot for your help.
  • Ul
  • Ul
23 Apr 2026 14:45
Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Ich sehe gerade, dass die Chinesen die Aliexpress Anzeige geändert haben und nun zwei verschiedene Karten in der Beschreibung sind. Keine Ahnung was man bekommt, wenn man die bestellt. Ich meine jedenfalls die hier.
  • Ul
  • Ul
23 Apr 2026 14:35
Category: Deutsch
Dieses Fallback Bitfile ist blinkende LED und alle Pins IO. Du brauchst das gar nicht, sondern nur das Bitfile, das zu deiner Maschine passt.
Die ersten drei Zeilen sind nur zum Testen vom neuen Bitfile, weil es in den flüchtigen Bereich geflasht wird. Falls das Bitfile nicht mit der Karte funktioniert, wird beim trennen und neu verbinden der Stromversorgung das ursprüngliche Bitfile geladen und die Karte ist wieder ansprechbar.
Untere drei Zeilen braucht es, damit es nach dem Trennen der Stromversorgung im Speicher bleibt, aber eben nur wenn das Bitfile mit der Karte funktioniert. Sonst braucht man JTAG.
Deine Karte ist keine 7i98 sondern eine chinesische F7i98. Ist wieder eine andere, zu der ich nichts sagen kann. Mit 7i98 meine ich die hier: de.aliexpress.com/item/1005012092221990.html
Deine kann alles Mögliche sein. Ich vermute, die wird ebenfalls nicht mit originalen Bitfiles von Mesa funktionieren. Jetzt weißt du aber wenigstens wie man es testet, ohne dass gleich alles kaputt ist
Die JTAG Pins bei deiner scheinen anders zu sein, als bei anderen Karten. Keine Ahnung was man da macht. Man kann den IC aber auch direkt flashen (dürfte der zwischen Ethernetbuchse und FPGA IC sein).
Ich empfehle jedenfalls entweder die verlinkte 7i98 zu kaufen, oder die oben gezeigte 7i92, falls 34 Pins ausreichend sind und die 7i98 zu teuer ist.
  • Jimnyx
  • Jimnyx
23 Apr 2026 12:12
Category: Deutsch
Vielen Dank für die schnelle Antwort.
  diese Karte aber Vers. 1.1 habe ich gebrickt und warte jetzt auf eine neue.
Sie schickten mir diesmal die Doku + Bitfile vorab und schickten anschliessend die Meldung: "Sehr geehrter Kunde, Bitte beachten Sie, dass die Bedienungsanleitung und die Bit-Datei, die wir zuvor gesendet haben, alte Versionen sind. Die aktualisierten Dokumente werden in Kürze an Ihre E-Mail-Adresse weitergeleitet.Alibaba Translation"
Habe eine neue Doku bekommen, jetzt allerdings ohne das 7i98_fallback.bit File.
Wenn ich das richtig verstehe muss ich doch sowohl den Fallback-Speicher als auch den "Arbeits"Speicher flashen. 1x mit 7i98_fallback.bit mit den ersten 3 Zeilen Deiner Anleitung.
Die Endungen der 3 Zeilen --fallback bewirken das der Fallback-Speicher geflashed wird .
Dann muss noch der Arbeits-Bereich geflashed werden mit z.B. 7i98_5ABOBX3.bit. Wenn am Ende der Zeilen kein --fallback steht, wird der Arbeitsspeicher geflashed.
Irgendetwas muss ich da doch falsch verstanden haben...
Denn wann werden die Speicherbereiche wirklich geschrieben und nicht nur simuliert ?
Grüße !
  • RotarySMP
  • RotarySMP's Avatar
23 Apr 2026 11:53
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Has that bug been reported to the Devs?
  • spumco
  • spumco
23 Apr 2026 10:39
Replied by spumco on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
@JT -
Thank you for the update and new pins.  I pulled the latest deb and Flex is recognizing the additional spindle connections I put in my test GUI.
This doesn't affect me directly - I have no GUI spindle controls, just displays - but are there similar multi-spindle control pins?  I didn't see any update in the docs about those changing.
  • jetbadger
  • jetbadger
23 Apr 2026 09:17 - 23 Apr 2026 09:18
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
A little update as I've found the issue. It was the spindle-at-speed signal. Connected to encoder feedback it would go off in axis mode and I assume it's Gmoccapy behavior that it halts all motion if that signal is false.
Still took me embarrasingly long to figure that out.
  • papagno-source
  • papagno-source
23 Apr 2026 08:55
Replied by papagno-source on topic Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
HI good mornig at all.
The GUI, can running on Debian 10 ?
  • Retrofit
  • Retrofit
23 Apr 2026 08:05
Replied by Retrofit on topic 4 axis foam cutter configuration
Category: AXIS
  Hello to everybody
I use to retofit mill and lathe with linuxcnc , all of them with probe basic.
All of them are working  , i do this for hobby.
Now  i build a hot wire foam cutting machine , a large one , 3m*1,7*1,7 m ,(for 1,2*1,2 section cutting) 4 independent axis
It is configurated with 7i92+7i76 board (old type both of them , remain from other project ) , including the mechanics , remain from projects  , linuxcnc , axis - foam configuration.
On desktop looks like work.
I need an advice , a configuration , an ideea how to manage the wire change of lenght , with a stepper motor , not mechanicaly with spring , pneumatic cylinder , or weight on both sides.
Something like a 5th axis.
I tryed with double y and v axis (vertical axes) ,  mirror axes like routers , XYYUVV  , the mirror axes move and rotate a whell and 'recover' the lenght of the wire , but in my opinion is a better solution , I think with only one motor that can compensate and manage the lenght change.
Thanx in advance
Denis
  • Hakan
  • Hakan
23 Apr 2026 03:56 - 23 Apr 2026 03:59
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
The machine with refClockSyncCycles=-1 normally doesn't emit any noise, except for some window movements.
With refClockSyncCycles=1, it emits some noise.
With both refClockSyncCycles=-1 and 1, the command
ethercat upload -p 0 -t uint16 0x1C32 0x01 returns 0x0002 2
Pin pll-error oscillates around -1200 to 1300
When moving windows Linuxcnc's servo loop takes too long time.
There usually is a message in the start window saying that.
If you monitor pll-err in halscope or record it with sampler you will
see a spike in pll-err.
There is some more fundamental work needed to make linuxcnc independent
on such events.
Wouldn't surprise me if this is the difference between 4.19 and 6.
  • spumco
  • spumco
23 Apr 2026 01:43
Category: Turning
Had another peek at the vid on a bigger screen, and each pass is certainly starting to the right of the previous pass.
Start of pass 2, chip is forming on the right of the insert:
Two rotations later, and you can see a second groove forming to the right of the first pass... but it isn't much deeper.
Third pass, and now there's a 3rd groove  - also to the right.  And also isn't much deeper.  Maybe deflection, but I didn't see the stock wobbling a ton or climbing the insert.  Almost like it isn't going any deeper each pass, just shifting to the right.
In addition to running a no-Q value test, it might be helpful to set up a halscope with the Z-axis position and the spindle index signal.  Try to see exactly where the Z-axis is when the index signal is triggered, and does the Z-axis then start moving immediately?
My earlier suspicion about the start point being the same may not be accurate - hard to spot 0.1mm-0.2mm shift of the insert on video.
Finally, you could put an ink pen in the tool holder and run a series of 3 to 4 G33 moves, using the pen to draw a thread.  Since "The G76 canned cycle is based on the G33 Spindle Synchronized Motion", multiple G33 passes should help you determine if the synchronization start point is exactly the same place without any other motion distractions.
Try it at different spindle speeds - but use the same speed for each set of repetitions.  If you want to test my claims about the bug, run a 4-pass test, but increase the spindle speed by 100-200rpm each pass.
If the start point is the same every time during G33 (same spindle speed) - but not during G76 - you've got a threading-specific problem.
If it's not the same, you've got a more fundamental synchronization problem... mechanical or LCNC configuration.  Or you may be encountering the bug I mentioned earlier from a different direction.
  • PCW
  • PCW's Avatar
23 Apr 2026 00:32 - 23 Apr 2026 00:33
Replied by PCW on topic Adding additional i/o beyond default
In your hal file, change:
to:
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_dio=N
where N= the number of DIO needed (1 to 64)
man motion
  • epineh
  • epineh
22 Apr 2026 23:47
I'm trying to decide on a connection for my satellites
Ethernet or Firewire Cables, 5V or 24V ?
* RJ45 is cheaper, but could be confused with Ethernet
* FireWire uses thicker cablesCheaper
* satellite boards can be built using 5V, but 24V is practical for many sensors and limit switches
* RJ45 and 5V are compatible with Mesa-SmartSerial (except for the firmware)
Does anyone have any ideas?
I was going to ask you this very question, I would lean towards RJ45, tx with a gnd twisted pair, same with rx. Otherwise a properly shielded/grounded (at the source point only) cable over a short run, possibly with a bit of passive filtering. I think if either are kept as short runs and don't go looping around a spindle drive it should be OK.
I think keeping the uart at 5v will save level shifting headaches, keep 24v on the machine hardware side of things. I have some PCB's turning up soon and I will try out the satellite expansions, looking forward to it :)
  • Metalurgent
  • Metalurgent
22 Apr 2026 22:02
Adding additional i/o beyond default was created by Metalurgent
Longtime reader, first time poster.
Running a cnc lathe retrofit with 2.8.
I was using the y-axis as a drive axis for a tool turret. The y-servo motor moved the turret to the tool position and some simple digital outputs locked it down using an air cylinder. Unfortunately, the system was very "loose" and backlash problems and other repeatability issues meant that it wasn't very reliable. It was a good learning experience and I could get away with using just the 4 default input/outputs that came from a simple configuration.
I've redesigned the turret/indexing system for more effective indexing and this means that I need to unlock more inputs and outputs.
 I'm not any kind of linux programmer. I've used the forum to cobble together snippets of code to make things work and that's been enough for three mill retrofits so far and this lathe project.
I cant figure out how to expand the i/o so that the M62 -M68 codes can call the extended inputs and outputs that are available on the mesa 5i25- 7i77.
I can add and assign names to the i/0 in pncconfig. They show up in the hal file and I can see them in halshow.
There is a section in hal that shows the only i/0 that  I can access.
#  ---digital in / out signals---
net dout-00     <=  motion.digital-out-00
net dout-01     <=  motion.digital-out-01
net dout-02     <=  motion.digital-out-02
net dout-03     <=  motion.digital-out-03
net din-00     =>  motion.digital-in-00
net din-01     =>  motion.digital-in-01
net din-02     =>  motion.digital-in-02
net din-03     =>  motion.digital-in-03
I know its probably something very basic but I'd like to expand this to include all the i/0 that I select in pncconfig.
I've been through the archives and I'm still drawing a blank. I'm getting errors regarding missing pin numbers and  i/0 max errors.
Any help would be much appreciated.
File Name: redo_night.hal
File Size:15 KB
File Name: redo_night.ini
File Size:4 KB
  • Spezidrohne
  • Spezidrohne
22 Apr 2026 21:44 - 22 Apr 2026 21:46
Replied by Spezidrohne on topic Need help transitioning from axis XYZ to XYYZ
Category: Basic Configuration
Solved.
The problem was my KINS part of the ini. I had it the following:
[KINS]
KINEMATICS = trivkins
COORDINATES = XYYZ
kinstype=BOTH
JOINTS = 4
And they need to Look like this:
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
Thanks for all the help.
Displaying 3256 - 3270 out of 13637 results.
Time to create page: 0.644 seconds
