  • dredivan
  • dredivan
16 Apr 2026 04:51
Probe Basic — 4-axis XYZB wrapped rotary backplot support
Category: QtPyVCP
Regarding DRO — I already did exactly that, edited dros_user.ui removing the A and C rows. DRO now shows only XYZB. However the A+/A- jog buttons remain — they are controlled separately from the DRO file. Is there a way to remove the unused jog buttons without touching system files?
Regarding wrapped rotary — very interesting! I am ready to test. What do I need to get started with the test branch and what machine model is required?
  • rodw
  • rodw's Avatar
16 Apr 2026 03:31
Replied by rodw on topic SIEG SX3.5Z Drivers EtherCAT A6 Steppers
Category: Driver Boards
You will probably find a 7i96s is cheaper in the end but there is a lot more wiring to do. Ethercat encoders are expensive and probably difficult to configure if you can't close things on the drive. Either way, try to get an Intel NIC. The balance probably falls in favour of Mesa if you can get away with a 7i96s
  • cmorley
  • cmorley
16 Apr 2026 02:45
Replied by cmorley on topic Custom widget management
Category: Qtvcp
Except for versa probe and basic probe, the short answer is no general way to customize widgets.
Versa probe and basic probe look for customized ui and handler files.
This describes the process for them:
linuxcnc.org/docs/devel/html/gui/qtdrago..._probe_screen_widget
You can always add your own widget to qtdesigner.
the plugin link should be in a hidden file in your home folder:
.designer/plugins/python/Link to qtvcp_plugin.py
you could add more links, but it's a fair amount of work.
What widgets do you wish to customize?
15 Apr 2026 22:16
PID visualisation software for drones but also informative for LinuxCNC
Bumped into this, seems nice for understanding what does what in PID tuning, link is in description, web based so no install needed.
  • juan13372k
  • juan13372k
15 Apr 2026 20:41
Replied by juan13372k on topic SIEG SX3.5Z Drivers EtherCAT A6 Steppers
Yes that sound more reasonable thanks for that info I wanted to go by ethercad to have a small HMI PC for Linux CNC but if mesa card makes more sense sure than I go that way.
Can you maybe give me some info what to look for I need a computer with PCi port and the the card is the driver or do I need extra drivers and than the stepper motors ?
Maybe someone can recommend me a setup :) that would be nice thanks so far for the help I really appreciated it
  • PCW
  • PCW's Avatar
15 Apr 2026 20:28
Replied by PCW on topic Lathe C axis homing
Lathe C axis homing
The commanded C position should come directly from LinuxCNC, It should not have steps
nor be affected in any way by PID settings.
Can you post your HAL/INI files?
  • Lcvette
  • Lcvette's Avatar
15 Apr 2026 20:07
Category: QtPyVCP
do you have the plot turned on for machine bounds in the ui? sidebar tab "PLOT"
for the dro display, you can use the user custom dro template and setup however you desire, just remove the rows for a and c and leave xyzb
for the wrapped rotary, this will be something coming down the line, we are currently working on multi axis plotting and simulation so if you have a model of your machine and would like to be a tester for the currently existing test branch you can give it a try if you like, the feedback would be good for us to have someone outputting multiaxis gcode for testing.
  • Zbigi
  • Zbigi
15 Apr 2026 19:49
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hi Axemas
Thank you for your hard work. As you suggested, I’ll send a request via GitHub. I’m having trouble with the lathe tab—can I count on a reply and help? Thanks, Z
  • BULGARIAN
  • BULGARIAN
15 Apr 2026 19:28
Replied by BULGARIAN on topic Need electrical schematics for Maho MH 800 C
Category: Milling Machines
Good day everyone,
My name is Radko. I got a secondhand MAHO MH 800 C too and having some difficulties with the mill.
I am need of the electrical schematic diagram of this machine.
If anyone has a soft-copy (pdf, image file) of the schematics then please send me.
If there is a link where to get the scheme
I would be very grateful if you could.
Best regards,
Radko
  • agrimani
  • agrimani
15 Apr 2026 19:18
Bay Area consultant familiar with ProBotix/LinuxCNC
Category: User Exchange
Thanks; am really looking for someone I can pay to configure this system, then help with programing of the router to make a number of parts.
  • maxi177
  • maxi177
15 Apr 2026 10:52
Replied by maxi177 on topic Probleme mit G Code...
In Zeile N55 fährt das eine file auf X11.57 und das andere auf X-1.444, die Differenz zwischen den beiden Positionen ist viel mehr als der Radiusunterschied zwischen D3.175 und D2. Da stimm evtl was in deinem CAM oder mit den Werkzeug Durchmessern nicht.
Gruse
Max
  • dredivan
  • dredivan
15 Apr 2026 10:44
Category: QtPyVCP
Setting up Probe Basic 0.6.6 on a 4-axis gantry machine (MPCNC with a fixed rotary B axis mounted at the end of the Y travel).
Configuration:
- LinuxCNC 2.9.8
- Mesa 7I76E (Ethernet)
- trivkins coordinates=XXYYZB, 6 joints
- B axis is a rotary chuck, fixed position at Y=700mm
What works:
DRO displays all 4 axes correctly using DRO_DISPLAY = XYZAB (A axis is unused but present — there is no XYZB option available).
What does not work:
The backplot renders the toolpath as 3-axis only — B axis rotation is not applied when building the path. For wrapped rotary applications (tube machining) the toolpath preview is not meaningful.
Also, machine bounds are not displayed in the 4-axis config, while they display correctly in the 3-axis config on the same machine.
Are there any plans to support wrapped rotary backplot rendering in Probe Basic / qtpyvcp?
3 axis configuration - mpcnc_probebasic.ini
4 axis configuration - probebasic_4b.ini
  • rodw
  • rodw's Avatar
15 Apr 2026 10:21
Replied by rodw on topic HAL component for tangential knife
Category: HAL
Pretty cool machine for somebody who had never seen one. Good for the OP to see there are other solutions.
I was envisaging much more gradual arcs. Maybe that was because I used to get 2mm rubber sheet cut with a tangential knife machine including 6mm dia holes.
When I started this, I wanted the arc radius and Andy asked me to add the tangential heading as by the time I had the radius, the heading was trivial. (so we thought anyway). It will be quite handy.
  • Hakan
  • Hakan
15 Apr 2026 09:49 - 15 Apr 2026 09:52
Replied by Hakan on topic Ethercat, CIA402, Yaskawa Sigma-X
Category: EtherCAT
Some Yaskawa servo drivers support LRW. Check syslog for this message to know if it does
EtherCAT 0: Datagram domain0-0-main: Logical offset   ....    type LRW.
  • LukeST
  • LukeST
15 Apr 2026 06:42
Replied by LukeST on topic spindle-at-speed
spindle-at-speed
Category: Deutsch
Das klingt gut. Ich melde mich, sobald ich das ausprobieren könnte. Danke.
Displaying 3541 - 3555 out of 13615 results.
Time to create page: 0.514 seconds
