  • axemas
  • axemas's Avatar
14 Apr 2026 11:27 - 21 Apr 2026 10:34
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hello everyone,
I would like to announce the release of NativeCAM 2.0b — a community port
of the original NativeCAM (by Fernand Veilleux) migrated to Python 3 and GTK3.
The original NativeCAM was written for Python 2.7 / GTK2, which is no longer
available on modern distributions. This port makes it fully compatible with
LinuxCNC 2.9 on Debian 13 Trixie.
--- What's new in 2.0b ---
* Full Python 3 / GTK3 migration
* New: Side Drill feature — horizontal drilling from Top / Bottom / Left / Right
  faces of the workpiece, designed for multi-spindle machines like Biesse Rover
* New: Horizontal tool visualization in AXIS — tool rotates correctly in the
  3D view when a side spindle is active (uses tool table Q column: 10-13)
* Fix: Phantom GTK popup windows no longer remain on screen after LinuxCNC exits
* Fix: About dialog now shows version correctly (Python 3 bytes decode bug)
* Fix: Validation Messages menu now uses checkboxes showing current state
* Debian packaging updated for modern build tools
--- Download ---
GitHub: github.com/cnc-proton/nativecam-py3-gtk3
Releases: github.com/cnc-proton/nativecam-py3-gtk3/releases
Install:
  sudo apt install ./nativecam_2.0b-4_all.deb
--- Tested on ---
* Debian 13 Trixie + LinuxCNC 2.9
* Biesse Rover 336 (multi-spindle, 4-side horizontal drilling)
Any feedback, bug reports or pull requests are welcome on GitHub.
Credits to Fernand Veilleux (FernV) for the original NativeCAM project.
Best regards,
CNC Proton
  • grandixximo
  • grandixximo's Avatar
14 Apr 2026 11:02 - 14 Apr 2026 11:03
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
You are using DC. Confirmed.
All four slaves show "Distributed clocks: yes, 64 bit" and all four report 0x1C32:01 = 0x0002 which means DC Sync0. Your drives are running in DC synchronized mode right now. This is the best mode for a CNC machine.
The only thing that does not work for you is the alternative sync strategy where the master follows the reference slave clock instead of the other way around. But that is just a different way of keeping everyone in sync, not a better or worse one. What you have now, master as reference with refClockSyncCycles=1, is perfectly fine and is DC.
One thing I notice is that your reference clock, slave 0, is not one of the SD700 drives. It is a separate device, the first on the bus. That could be related to why syncToRefClock=true causes problems, if that device reports timing that my PLL does not handle well. If there is an opportunity to test this any time in the future within a better setting, I'd love to debug it remotely.
  • papagno-source
  • papagno-source
14 Apr 2026 10:53
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
I'm actually at the client's site performing the installation. This machine was already running Debian 10, but I wanted to test Debian Trixie and we're encountering these problems, which we seem to have solved.
The output of the ethercat slaves -v command is:
=== Master 0, Slave 0 ===
Device: Main
State: OP
Flag: +
Identity:
Vendor Id: 0x0000022b
Product code: 0x0531ec01
Revision number: 0x00000003
Serial number: 0x0001894b
DL information:
FMMU bit operation: yes
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 3151034175 0 0
1 MII up open yes 1 3151039505 5330 935
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x1000/1024, TX: 0x1400/1024
Standard RX: 0x1000/128, TX: 0x1080/128
Supported protocols: EoE, CoE, FoE
General:
Group:
Image name:
Order number:
Device name:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
=== Master 0, Slave 1 ===
Device: Main
State: OP
Flag: +
Identity:
Vendor Id: 0x00850104
Product code: 0x01030507
Revision number: 0x02040608
Serial number: 0x00000000
DL information:
FMMU bit operation: no
DC system time transmission delay: 935 ns
0 MII up open yes 0 3730859530 0 935
1 MII up open yes 2 3730862990 3460 855
2 MII down closed no - - - -
3 MII down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Supported protocols: CoE
General:
Group: ServoDrive
Image name: DRIVE
Order number: SD700_ECAT Drive
Device name: SD700_ECAT_V1.2_G
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
=== Master 0, Slave 2 ===
Device: Main
State: OP
Flag: +
Identity:
DL information:
DC system time transmission delay: 1790 ns
0 MII up open yes 1 3711076970 0 855
1 MII up open yes 3 3711078720 1750 875
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
=== Master 0, Slave 3 ===
Device: Main
State: OP
Flag: +
Identity:
DL information:
DC system time transmission delay: 2665 ns
0 MII up open yes 2 3704486570 0 875
1 MII down closed no - - - -
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
while the command:
ethercat upload -p 0 -t uint16 0x1C32 0x01 = 0x0002 2
ethercat upload -p 1 -t uint16 0x1C32 0x01 = 0x0002 2
ethercat upload -p 2 -t uint16 0x1C32 0x01 = 0x0002 2
ethercat upload -p 3 -t uint16 0x1C32 0x01 = 0x0002 2
  • rodw
  • rodw's Avatar
14 Apr 2026 10:17
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
A USB wifi adapter is also fine for a second network connection. I have often used one with an external antenna. If the PC is in your enclosure, run a SMA cable up to a bulkhead connecter and place the antenna on the outside of the enclosure. You just need to drill a hole for the connector. Something like this but check if you need male or female. www.amazon.com.au/Boobrie-Bulkhead-Exten...BRMR/ref=sr_1_4_sspa
The problem with wifi, often you need to search for  drivers and often you need to build them from source. Like my current wifi dongle. But it is bulletproof now its built. The wired NIC I use for Ethercat.
  • Dudelbert
  • Dudelbert
14 Apr 2026 09:49
My Z-axis stopped moving was created by Dudelbert
I am retrofitting a CNC lathe right now. In that process, I ran into a problem: my Z axis, which already worked, stopped doing so. I was messing with the encoder wiring, but I don’t think that is related. So X still works fine, but Z does not. I still get encoder feedback and see that when the machine is enabled, the Z axis drifts slowly.
I use a 7i97T and Chinese AASD motor drivers.
Troubleshooting I already did:
Driver: I confirmed that all the I/O still works. External E-stop, enable line from LinuxCNC, these are fine and work as expected. I then injected voltage into the analog line from the Mesa connector. The drive moves and stops after the following error gets too big, and the enable signal is removed by Mesa.
So I don’t think it is the driver or the wiring to it.
PWMgen: I then switched the pluggable connectors for X and Z on the Mesa and changed the HAL accordingly. Still, the X axis works fine and Z does not. In HAL Show I watched .pwmgen.nn.value, which started to grow after the machine was enabled and the Z axis started drifting. After a few seconds, it reached 60, which is the value of output-scale. With that, I would expect 10 V on that line, but I measure barely a few mV.
That really seemed like a hardware defect to me, but as I said, I switched the outputs between X and Z, and the PWMgens are confirmed to both be OK.
So in my head, only the software (e.g. HAL and INI) is left, but I did not really change anything there, at least I cannot think of anything.
With that, I am at the end of what I can think of. Please, if anyone has an idea, I am going insane trying to find this. I swear, if it is the equivalent of a missing semicolon in C…
I have the current .hal and .ini in the attachments.
At the end, I want to describe what I was doing immediately before this problem appeared. I cannot think of a reason how this would be connected, but still:
I had both axes moving and mostly tuned. I was testing the repeatability of the hall switches I use for homing. I found these to not be reliable and wanted to use the index pulses from the motor encoders. But I have linear scales on the machine, so I wired only the index pulses from the motor drivers to the Mesa inputs, while the A and B lines from the linear scales go directly to the bed and cross slide.
I changed only HOME_USE_INDEX = NO to HOME_USE_INDEX = YES and started the machine, at least that is what I remember. Since then, the INI and HAL have changed slightly as I tried to solve this. The HOME_SEQUENCE has changed as I wanted to check if the index thing worked for the X axis at least. It does.
So yes, I would be thankful for any help you can provide.
  • Pudding1960
  • Pudding1960
14 Apr 2026 09:49
Replied by Pudding1960 on topic Probleme mit G Code...
In this case i have Home switches on all axis,660x500 cm Travel on X,Y ,but i need only 40mm with a 2mm Endmill.... With a 3,175mm Endmill the Contour works fine,but the Finishing with the 2mm Endmill didnt !
  • raggielyle1@gmail.com
14 Apr 2026 09:38
Replied by raggielyle1@gmail.com on topic New Laser Build - raster engraving
Category: Plasma & Laser
Sorry about the delay. I cant upload the file because it has a sh extension. Please email me This email address is being protected from spambots. You need JavaScript enabled to view it. and I send the file.
  • grandixximo
14 Apr 2026 09:14
Category: EtherCAT
Yes, you are using DC. Both of your working configurations are DC.
syncToRefClock does not mean "DC on or off". It only controls who is the time reference that everyone else follows. Both modes use Distributed Clocks.
refClockSyncCycles=1 means the master pushes its time to the slaves every cycle. The slaves follow the master. This is DC.
refClockSyncCycles=-1 (without syncToRefClock) means the master adjusts its own cycle to follow the first DC slave. The master follows the slave. This is also DC.
refClockSyncCycles=-1 with syncToRefClock="false" flips the sign, making it effectively +1. So it is the same as refClockSyncCycles=1. Master pushes time to slaves.
Both your working configs resolve to the same thing: master as reference, sync every cycle.
What does not work for you is the mode where master follows the slave (syncToRefClock="true" or negative refClockSyncCycles alone). That is what I want to investigate, whether it is a problem with what your first slave reports or something else in my code.
To confirm DC is active on your slaves, run these commands:
ethercat slaves -v
This will show "Distributed clocks: yes" or "no" for each slave. If it says yes, the hardware supports DC.
Then to check what sync mode is actually active:
This reads the sync mode from the first slave. Value 0 means free run, 1 means SM-synchronous, 2 means DC Sync0, 3 means DC Sync1. You want to see 2 or 3. Replace -p 0 with -p 1, -p 2 etc for each drive.
Please post the output here, or if possible email me at luca at aitalmac.com about remote access. A USB to Ethernet adapter would give the machine internet while keeping the EtherCAT port dedicated.
  • Plithere46
  • Plithere46
14 Apr 2026 09:12
Hello to all, I am new here was created by Plithere46
Hello to all, I am new here and, do hope to learn what I can for what I intend to do with the CNC Router table and, linuxCNC. found this forum by chance, luck me.
I have Debian 12 on a laptop computer, I will be using this for the CNC router table in the workshop, I hope!
The issue I have is that I can not find a good site that has LinuxCNC that works on Debian 12 for download.
Is there anywhere that has this as a download? I simply need to put it on a flash drive and install it to the laptop.
Any help would be appreciated.
  • papagno-source
  • papagno-source
14 Apr 2026 08:26
Category: EtherCAT
Yes excuse the correct question Is :
So in my case, the only way to get it to work is:
refClockSyncCycles=1, without syncToRefClock
or
refClockSyncCycles=-1, with syncToRefClock=false
So I'm not using DC mode?
  • grandixximo
14 Apr 2026 08:18
Category: EtherCAT
refClockSyncCycles=-1, without syncToRefClock=false
Are you sure this works? I think you stated differently before.
  • papagno-source
  • papagno-source
14 Apr 2026 07:33
Category: EtherCAT
I tried writing in the XML file:
refClockSyncCycles=5, without syncToRefClock, and the machine makes noise.
I also tried:
refClockSyncCycles=1000, without syncToRefClock, and the machine makes noise.
or
  • grandixximo
14 Apr 2026 07:19
Category: EtherCAT
DC has one start time, that's set on start usually by the first Ethernet DC capable device, from there you have two choices, either the slaves follow the time that the master declares every x cycles with refClockSyncCycles=x
Or everyone follows what the first slaves says the time is, master included. To do that master nudges its own cycle time to match what the first slaves report, the problem with your setup I think, is what the first master is reporting, so this system seems to not work correctly.
This mode is also DC and is set with
Or
  • grandixximo
14 Apr 2026 07:02 - 14 Apr 2026 07:08
Category: EtherCAT
refClockSyncCycles=-1 and syncToRefClock="false"
Is identical to
What synctorefclock false clock does is make -1 become positive, if it was -5 it would be 5
refClockSyncCycles=-1 DC is enabled but master follows the reference slave, master will change its own time
This is identical to syncToRefClock true
About having only one Ethernet, USB to Ethernet adapter could work to give it internet, but I won't insist, but if possible I'd really love to test for myself, as some things get lost in communication
  • papagno-source
  • papagno-source
14 Apr 2026 06:57
Category: EtherCAT
Hello everyone. The machine has only one Ethernet port, dedicated to EtherCAT.
I wanted clarification regarding Hakan's statement:
If any of the slaves have an assignActivate bit 8 set (DC sync), switch on loop synchronization.
The drive's XML file contains these entries:
<OpMpde>
<Name>DC</Name>
<Desc>Dc-Synchron</Desc>
<AssignActive>#300</AssignActive>
<CycletimeSync0 Factor="1">0</CycleTimeSync0>
<ShiftTimeSync0Z0>/ShiftTimeSync0>
<OpModie>
Does this entry mean bit 8? Does the manufacturer declare that the drive supports DC?
So, to conclude.
If I write in the XML file:
refClockSyncCycles=-1 and syncToRefClock="false", DC is enabled, so the slaves synchronize with the master managed by LinuxCNC.
If I write only:
refClockSyncCycles=1 in the XML file, DC is enabled, so the slaves synchronize with the master managed by LinuxCNC.
But I can choose the synchronization frequency from 1-5-1000.
If I write only:
refClockSyncCycles=-1 in the XML file, DC is not enabled, but free mode is enabled, and the drives do not synchronize with the LinuxCNC master.
Correct?
I imagine that the best feature for a CNC machine is DC mode, or am I wrong?
I verified that the lcec.0.dc-phased pin is always false.
Displaying 3631 - 3645 out of 13584 results.
Time to create page: 8.603 seconds
