  • andrax
  • andrax's Avatar
13 Apr 2026 16:32
Replied by andrax on topic CiA 402 Folder Missing
Category: EtherCAT
That looks good.
The error is normal; it happens when LinuxCNC shuts down.
Can you move the axis in jog mode without any problems?
If so:
You now have two options. Connect the remaining axes and use the CIA402 homing.
Note: Prone to errors with gantry setups
or
Use the LinuxCNC homing. However, this is significantly less accurate.
If there are battery-powered encoder cables available for your servos,
install them, and you’ll save yourself the homing process and avoid any further trouble.
  • papagno-source
  • papagno-source
13 Apr 2026 16:15
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
A question.
So is it better to work with refClockSyncCycles="1" or with
refClockSyncCycles="-1" and syncToRefClock="false"?
If the two settings are equivalent, does the value of refClockSyncCycles have to be 1 or can it take on values ​​other than 1, and how do I know what the correct value is in this case?
  • stonebite
  • stonebite
13 Apr 2026 15:48
Wiederholungen, Schlaufen im manuell geschriebnen G Code Programm
Category: Deutsch
vielen Dank, Deine Zeilen muss ich noch lernen zu verstehen und oder ergänzen,
  • papagno-source
  • papagno-source
13 Apr 2026 15:43
Category: EtherCAT
1° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
DC reference time: 829435419653140029
Application time: 829439464192168202
2° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Application time: 829439529368163181
3° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Application time: 829439568792164528
4° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Application time: 829439599360167607
1° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
DC reference time: 829439756498240034
Application time: 829439771336260988
2° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Application time: 829439799640262918
3° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Application time: 829439828648257947
4° without power on <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Application time: 829439854792266116
  • grandixximo
  • grandixximo's Avatar
13 Apr 2026 15:29 - 13 Apr 2026 15:30
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
Yes, the reference is only one, and right now is 0, and that I/O might not be doing DC properly.
So I'm try to move it to the servo.
The ethercat master, I'm only interested in two values
DC reference time:
Application time:
And three times on the same run, not one time per run. Sorry about not being clear about it. Appreciate it if you could test it, thank you.
Manda il comando tre volte dopo aver iniziato, non una volta per avvio.
  • papagno-source
  • papagno-source
13 Apr 2026 14:41
Category: EtherCAT
Because dcRefClock="true" only for drive 1 and not for all drive ?
  • papagno-source
  • papagno-source
13 Apr 2026 14:37
Category: EtherCAT
I don't understand how can attachment file.
This test, are without your last fix.
I have executed N°3 test for refClockSyncCycles="1" and refClockSyncCycles="-1"
1° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Main: 68:ed:a4:79:15:bb (attached)
Link: UP
Tx frames: 105648
Tx bytes: 22401382
Rx frames: 105647
Rx bytes: 22401017
Tx errors: 0
Tx frame rate [1/s]: 1053 1050 752
Tx rate [KByte/s]: 360.7 359.5 216.8
Rx frame rate [1/s]: 1053 1050 752
Rx rate [KByte/s]: 360.7 359.5 216.8
Common:
Tx frames: 105648
Tx bytes: 22401382
Rx frames: 105647
Rx bytes: 22401017
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: Slave 0
DC reference time: 829434877492390059
Application time: 829434927369399203
2026-04-13 22:35:27.369399203
2° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 201920
Tx bytes: 55838998
Rx frames: 201919
Rx bytes: 55838617
Tx errors: 0
Tx frame rate [1/s]: 1055 732 844
Tx rate [KByte/s]: 376.3 246.9 277.6
Rx frame rate [1/s]: 1055 732 844
Rx rate [KByte/s]: 376.3 246.9 277.6
Common:
Tx frames: 201920
Tx bytes: 55838998
Rx frames: 201919
Rx bytes: 55838617
Lost frames: 0
Loss rate [1/s]: 0 -0 0
Frame loss [%]: 0.0 -0.0 0.0
Distributed clocks:
DC reference time: 829435021988989029
Application time: 829435029703007959
2026-04-13 22:37:09.703007959
3° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 335803
Tx bytes: 102363460
Rx frames: 335802
Rx bytes: 102363095
Tx errors: 0
Tx frame rate [1/s]: 1062 800 845
Tx rate [KByte/s]: 375.7 272.1 283.3
Rx frame rate [1/s]: 1062 800 845
Rx rate [KByte/s]: 375.7 272.1 283.3
Common:
Tx frames: 335803
Tx bytes: 102363460
Rx frames: 335802
Rx bytes: 102363095
Lost frames: 0
Distributed clocks:
DC reference time: 829435160651165030
Application time: 829435171294192841
2026-04-13 22:39:31.294192841
1° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 394894
Tx bytes: 122081343
Rx frames: 394893
Rx bytes: 122080980
Tx errors: 0
Tx frame rate [1/s]: 1056 1001 811
Tx rate [KByte/s]: 345.4 327.0 265.2
Rx frame rate [1/s]: 1056 1001 811
Rx rate [KByte/s]: 345.4 327.0 265.2
Common:
Tx frames: 394894
Tx bytes: 122081343
Rx frames: 394893
Rx bytes: 122080980
Lost frames: 0
Distributed clocks:
DC reference time: 829435219977025031
Application time: 829435246614056284
2026-04-13 22:40:46.614056284
2° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
Master0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 466209
Tx bytes: 145310656
Rx frames: 466208
Rx bytes: 145310307
Tx errors: 0
Tx frame rate [1/s]: 1055 865 766
Tx rate [KByte/s]: 345.2 278.2 243.7
Rx frame rate [1/s]: 1056 865 766
Rx rate [KByte/s]: 345.5 278.2 243.7
Common:
Tx frames: 466209
Tx bytes: 145310656
Rx frames: 466208
Rx bytes: 145310307
Lost frames: 0
Loss rate [1/s]: -1 -0 0
Frame loss [%]: -0.1 -0.0 0.0
Distributed clocks:
DC reference time: 829435319890377036
Application time: 829435334302407866
2026-04-13 22:42:14.302407866
3° power on with <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
aster0
Phase: Operation
Active: yes
Slaves: 4
Ethernet devices:
Link: UP
Tx frames: 555839
Tx bytes: 174885365
Rx frames: 555839
Rx bytes: 174885365
Tx errors: 0
Tx frame rate [1/s]: 1054 901 812
Tx rate [KByte/s]: 345.2 292.8 259.7
Rx frame rate [1/s]: 1054 901 812
Rx rate [KByte/s]: 345.2 292.8 259.7
Common:
Tx frames: 555839
Tx bytes: 174885365
Rx frames: 555839
Rx bytes: 174885365
Lost frames: 0
Distributed clocks:
Application time: 829435435462157958
2026-04-13 22:43:55.462157958
  • MaHa
  • MaHa
13 Apr 2026 12:58
Category: Deutsch
Die Widerholungen können mit repeat gelöst werden. Beim inkremental verfahren muss halt darauf geachtet werden, das auch nach einem Abbruch die empfohlene Grundeinstellung G90 wieder aktiv ist.
;inkremental
#<anzahl_n> = 5
G91
o111 repeat [#<anzahl_n>]
     G1 X-100
     X100
o111 endrepeat
G90
oder
;Start an aktueller Position im aktiven Koordinatensystem
#<anzahl_n> = 5
#<actual_xpos> = #<_x>
     G1 X[#<actual_xpos> + 100]
     X[#<actual_xpos>]
o111 endrepeat
  • grandixximo
13 Apr 2026 12:18 - 13 Apr 2026 12:21
Category: EtherCAT
I have commit a small change to enable you to set drive 1 as the reference clock please update the code from
github.com/grandixximo/linuxcnc-ethercat
and run with this xml
File Name: deb13_2026...13-2.xml
File Size:17 KB
and confirm that DC reference clock is slave 1 and not 0 by running
ethercat master
in a terminal, I expect
Reference clock: Slave 1
  • grandixximo
13 Apr 2026 11:50 - 13 Apr 2026 11:53
Category: EtherCAT
Sorry, not a pin
it is the output to the terminal when you send this command
ethercat master
in a terminal window
it will list various things, I am interested in DC reference, and APP time, they are near the end
ethercat master command outputs
Master0
Phase: Operation
Active: yes
Slaves: 20
Ethernet devices:
Main: 00:e0:b4:68:34:0a (attached)
Distributed clocks:
DC reference time: 829391683702736097
Application time: 829391693979787340
the above is what I'd like to see, thank you
  • papagno-source
  • papagno-source
13 Apr 2026 11:44 - 13 Apr 2026 11:45
Category: EtherCAT
What parameters should I check?
the name the pin
  • stonebite
  • stonebite
13 Apr 2026 11:44
Category: Deutsch
salue zusammen,
ich habe ein wenig wegen dieser Thematik recheriert, nur komme ich nicht für Linux CNC auf Antworten wie ich sie verstehe und oder benötige.
Mir ist G Code zum fräsen noch nicht so geläufig. Bedeutet, ich möchte ein kleines G Code Programm schreiben welches mir mit der X Achse ein Verfahrweg von 100mm ins plus und wieder 100mm ins minus verfährt und zwar mit X anzahl Wiederholungen bis ich unterbreche oder bsi diese abgelaufen sind?
G 25 und G 26 scheint nicht verwendbar zu sein. Wie sehen G code Zeilen für Linux CNC aus die mir die Bewegung in der X Achse mit Wiederholungen, Schlaufe und oder Loop ausführt?
lieben Dank schon mal im voraus
Claude
  • grandixximo
13 Apr 2026 11:27
Category: EtherCAT
can you run ethercat master a few times consecutively while running with
and paste here the DC reference and the App time values?
at least 3~4 consecutive times please
do the same for
  • papagno-source
  • papagno-source
13 Apr 2026 11:05 - 13 Apr 2026 11:19
Category: EtherCAT
With refClockSyncCycles="-1" the value of the ecat.0.pll_reset_cnt pin is continuously increasing, it never stops, it increases in a positive direction more and more, in a short time it was already at 20,000
with  refClockSyncCycles="1" the pin ecat.0.pll_reset_cn remain stable = 0
  • grandixximo
13 Apr 2026 10:56
Category: EtherCAT
please check hal pin
with refClockSyncCycles="-1"
Displaying 3661 - 3675 out of 13584 results.
Time to create page: 1.702 seconds
