  • Hakan
  • Hakan
08 Apr 2026 12:49
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
This is not related to the phasing.
Or perhaps it is, on the way that clocks have started to run with different speeds.
You can switch on debug "ethercat debug 1" and watch the DC time difference between slaves slooowly converge.
It's part of the startup of slaves
gitlab.com/etherlab.org/ethercat/-/blame...e=heads&page=2#L1480
The server issues 5000 sync requests, one every millisec, and waits until clocks are within 10 microseconds.
If they aren't, you get the message. The slaves' clocks will eventually converge.
I had this issue, was unable to fix or even poke at it, and then suddenly it went away.
I suspect it has something to do with ethercat master version, but since I was unable to
diagnoze it, I really don't know.
  • grandixximo
  • grandixximo's Avatar
08 Apr 2026 12:34
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
I'm also on the discord, and I am fluent in Italian
discord.gg/WwMfD9v9M
If your Italian friend wants to hop in, I'll be glad to help him out.
  • grandixximo
08 Apr 2026 12:27 - 08 Apr 2026 12:28
Category: EtherCAT
I've used debian 10 11 and 13
I skipped debian 12 this is for internal timing release reasons, not because 12 had anything wrong with it. I did not notice on my hardware considerable differences between debian releases. If you have issues please share your configuration, be clear about the issue, share as much info as you can, and if you are not using my fork code, you most likely HAVE phasing issues. Those maybe effecting OP times, or motion, or nothing, it depends on the hardware. Will update to my fork fix everything? No, most definitely NOT everything, but I am sure phasing will be as proper as it can be on your system, and you will have debug pins to analyze performance which you can share, run halscope and halshow, see the ecat.0.xx pins, so that we can get to the bottom of the issue.
If Scott was still in the game, he would probably merge it and make a release. I would advise everyone to update, and if you have any issue, I will be here or on GitHub for support.
TL;DR
My fork does not magically fix all issues, but it does fix some, and gives you pins to benchmark your setup. Please build and install my fork, then test, and share your configuration and test results if you have issues and you want help.
  • rodw
  • rodw's Avatar
08 Apr 2026 12:02
Water depth, slats, and underwater cutting
Category: Plasma & Laser
I think 4" deep is enough even less if you have to. I found best quality was with the water touching the bottom of the plate (to 5mm below) but often evaporation took it down lower. Enable preflow to get air flowing before starting a cut to blow the water away from the torch. Using commercial quench, I only emptied the tray every 6 months or so and just kept topping it up as the active ingredient does not get lost.
  • endian
  • endian's Avatar
08 Apr 2026 11:59 - 08 Apr 2026 12:09
Replied by endian on topic Beckhoff BK1120 + KL modules on Linuxcnc
Category: EtherCAT
Hi everyone,I am trying to get a Beckhoff BK1120 (EtherCAT to K-bus coupler) working with LinuxCNC using EtherLab (ethercat-master) and the linuxcnc-ethercat (lcec) driver.I am running into some limitations and hope someone has experience with this.Setup:
  • LinuxCNC on Debian Bookworm
  • EtherLab master (from openSUSE repo)
  • linuxcnc-ethercat (lcec)
  • NIC: Intel I210 (working fine)
  • Hardware:
    • BK1120
    • KL1104 (digital inputs)
    • KL9010 end terminal
      What works:
      • EtherCAT master is running and stable (Active: yes, Phase: Operation)
      • BK1120 is detected correctly
      • Communication is stable (no frame loss, link up)
        The problem:
        The BK1120 does not expose standard CoE PDOs like typical EtherCAT slaves (for example EL terminals).
        Instead it provides a fixed process image for the attached KL modules.Because of this:
        • Standard PDO mapping via lcec XML does not work (0x6000 etc.)
        • Terminal-based configs (EK1100 + ELxxxx) do not apply to KL modules
        • lcec does not seem to support raw domain access for mapping the BK1120 process image directly to HAL pins
          What I have tried:
          • Generic slave configs with and without PDO entries
          • Attempted raw mappings (not accepted by lcec parser)
          • Minimal configs to bring the master up (works, but no usable I/O)
          • Checking data with ethercat CLI (limited without proper domain mapping)
            Current conclusion:
            • BK1120 with KL modules does not fit well with lcec, which expects PDO-based slaves
            • The data exists, but is not easily exposed to HAL
              Questions:
              • Has anyone used BK1120 with KL modules in LinuxCNC?
              • Has anyone managed to access the process image and map it to HAL pins?
              • Has anyone written a custom lcec extension or used another approach?
                Alternatives I am considering:
Writing a custom HAL component to read from EtherCAT master directly
Userspace polling (not suitable for realtime CNC)
Before I give up on the BK1120, I would like to know if there is a workable solution.Any input, configs or experience would be appreciated.Thanks
For every problem exist solution ... you have K-bus, something like profi-bus
you need USB to TTL serial communication then open small doors which are for this connection, then you will need buy or made custom cabling for 4x2,54mm pins ...
you need to have KS2000 paid software which will allow to configure your EEPROM of KL1120 for existing/present members of Kbus because they are not self-identifing itselfs ... You will create configuration of whole Kbus members behind KL1120 in KS2000 and every bus member has some lenght of data .. everything in WORDs
then done mapping for ethercat PDOs and each SMs and then you can list your config over terminal build configuration tool ... then create .xml file
finally you should run some KL stuff with non DC mode without synchronization
  • rodw
  • rodw's Avatar
08 Apr 2026 11:54
Replied by rodw on topic Estimate program run time
Category: Plasmac
Snowgoer- I get what your saying. I've heard enough "Can't you just...?" of my own. I know you can't please everyone, but I'm grateful for all your and everyone else's contributions.
I guess I'll see what I can do with axis. I do appreciate the plasmac statistics.
As a fabricator, most of my quoting involves chicken blood, planetary alignments and bs. I'll let you decide how much of each.
Does anyone quote by inches and pierces?
I think there is a feature in Sheetcam that gives a job time estimate that does it this way. I see, to remember you did define a pierce time. Don't forget to include the phase of the moon!
  • rodw
  • rodw's Avatar
08 Apr 2026 11:44
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
I spoke too soon. I've been helping someone in Italy who has 6 Ethercat drives and says:
When run lcnc the drive pdo are read with after some second , respect debian 10 ( is instantanious). On dmesg have slave did not sync after 5000 ms. The same drive with the same xml file not have problem on debian 10. I have test 2 pc, with realtek nic and intel nic , but the problem is the same. How can resolve. This problem is the same on debian 12.
So I assume he' s experiencing this issue and using grandixximo's repo should fix it. Can someone confirm?
Its odd that he says it works on Debian 10. My live machine (since sold) was running Debian 11 so perhaps its a Debian 12 and up issue.
  • Tserakhau
  • Tserakhau
08 Apr 2026 11:33
Replied by Tserakhau on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Thank you so much! I'm looking through your files. I'll definitely let you know the results!
  • Hakan
  • Hakan
08 Apr 2026 05:04
Replied by Hakan on topic Beckhoff BK1120 + KL modules on Linuxcnc
Category: EtherCAT
The BK1120 seems to use AoE mailboxes to communicate. That is not supported by the ethercat master.
You have a big project in front of you should you decide to implement that.
  • spumco
  • spumco
08 Apr 2026 04:34
Replied by spumco on topic Water depth, slats, and underwater cutting
I agree with Tommy that a reservoir on a daily-use table is kinda pointless.  But for an intermittent-use table I'm in favor.
We built a 5x10 table with a 4" deep pan.  Slats are 2", giving us the ability to raise the water level ~1"-2" above thin sheets.  We don't frequently cut with the nozzle below the surface, but it makes a noticable improvement when cutting stainless.  And reduces warping on thin materials.  And makes a huge mess because the nozzle isn't deep enough, but oh well.
Our reservoir is a large polyethelyne tank under the pan.  Takes up about 1/3 the length of the table.  We have a motorized ball valve for a drain and a 2-speed pump for filling.  The pump can fill the pan in just a few minutes - it's a big hot-tub pump - so you don't get annoyed waiting to fill the table.
The ball valve is a powered-closed version, which means we can open the drain, shut the machine/control down and walk away without having to babysit the drain valve.
Our table is not in daily use - perhaps once or twice a week.  Here's why we like the ability to drain the pan:
  • The shop full of other CNC equipment isn't nearly as humid.  Yes, the dirty plasma monster is in a separate section of the shop, but the humid air can still circulate to the 'clean' parts of the shop.
  • The table is on casters (with locking feet).  We only move it a couple times a year, but draining the pan in to the tank makes dragging it out of the corner way less of a splashing disaster.
  • It's easier to muck out the pan
    • The pan is not sloped, nor does it have a sump. I think those are pointless unless you have a complicated automatic, underwater rake.  Which means we don't get swarf/junk in our tank - it just drops to the pan bottom and sits there waiting for us to stop ignoring it.
    • If you've ever tried to dig out a deep sump packed with plasma crap, you'll never want to do it again.  That $hit is heavy and turns to concrete.
  • Our plasma can double as a router table.  We have removable aluminum-framed panels that sit on top of the pan fram and connect to a vacuum system, and the plasma floating head assembly can come off and a 3kw spindle bolts in place.
    • Being able to drain the water is a must, otherwise the MDF spoilboards would disintegrate after a few days of the humidity.  Even though the top and bottoms of the removable panels are HDPE, any MDF on top turns to oatmeal if we forget to drain the water.
  • Getting water to the table is sort of a hassle as the only source is ~60 feet away.  Hauling buckets sucks, so the less we have to do it the better.
  • We use borax as an anti-rust agent in the water, and not having to mix up a batch as frequently is nice.
If you have problems with freezing, maybe look for a sous-vide heater that's adjustable to a very low temp. You don't need much heat, and the circulation function of a sous-vide dingus will go a long way towards avoiding a freeze event.
Oh, and the table is not controlled by Linuxcnc, which means it's horrible in every possible way and I'm ashamed to be associated with it.
  • bentiggin
  • bentiggin
08 Apr 2026 04:31
Replied by bentiggin on topic Water depth, slats, and underwater cutting
I figure being able to quickly drain/refill the pan to fish out small parts is best reason for a reservoir, but I also worry about the pan freezing in the winter since the glorified shed it lives in is not heated. So figure when it gets cold, the water will already be in the heated reservoir, ready to refill the pan.
I'm thinking 12-15cm(5-6") deep. How much higher should the pan sides be than the top of the slats?
I appreciate your suggestions. I wanna hear them, especially the ones pointing out my potential problems. Mostly basing this plan on a few other large tables I've seen in person and forums, not youtube videos. The only reason why I even looked into underwater cutting is cause I think you prefer to cut underwater? I've only seen ones that that are up to the plate, not submerged. But apparently some plasma's cut under several inches of water so I figured I'd ask the experts on the linuxcnc forum.
08 Apr 2026 02:34
Replied by tommylight on topic Water depth, slats, and underwater cutting
I have some suggestions, you wont like them:
-Reservoir is utterly useless, unless you intend on using the machine about once every month or two, simple physics water evaporates and does so much more when it has a nozzle spewing 10000 degrees heat into it all day long. During summer here (35-40C) and heavy use, i have to refill every 2 or 3 days, meaning 2-4cm of water level is gone in that time. In general bigger table = less water level drop daily.
Having a water tap directly into it would be much more useful.
-You can cut underwater, easily, do not go above about 1-2cm deep with the torch, and that absolutely requires drying the torch whenever you do not use it as it will rust, quickly and badly. Everyday use should be fine.
-Roughly 15 cm deep would be nice (a lot less spill/spray over, 10 is very usable (mime are usually 10-12cm deep), and i would not go lower than 5cm on slats for up to 100A, 10cm for 200A and above.
-as for reservoir issues, see first paragraph.
Also, I might be utterly wrong here, but, stop watching youtube experts that built a single machine and now dispense advice like they are the "be all-end all".
  • bentiggin
  • bentiggin
08 Apr 2026 01:26
I have a 20'x6'(6m x 1.8m) plasma that I'd like to convert to a water table. I plan on having a reservoir underneath that gets filled/drained with air pressure.
I have seen some water tables that have the water at the bottom of the sheet, but I've yet to see one that cuts underwater. How deep underwater does the plate need to be?
I guess I'm trying to figure out how deep the pan should be and how tall the slats should be.
The way the table is, it'd be fairly easy to make a 4"-6"(10-15cm) deep pan. It wouldn't be too hard to go deeper, but we're already at 100's of gallons and thousands of pounds at that depth.
My main reason for a water table is smoke control, but minimizing warping on sheet metal would be a plus.
I'm not certain I want underwater cutting, but I like the idea of it.
Some other questions.
How to keep sediment out of the reservoir? I thinking of having the last few inches of the pan go directly to the reservoir, with a sort of lip and screen. The upside of this would be easier fabrication, but that would also make the reservoir/pan one piece. Alternatively, I could use pipes, but I still don't know how I'd deal with sediment and I'm sure that would really increase the drain/fill time.
The building the plasma is in is unheated so I need a heater to keep the reservoir from freezing. I think a screw in or tri clamp element like you'd see in a residential water heater would be the best choice. How would I go about controlling the temp? I don't wanna reinvent the wheel if there are already off the shelf solution if anyone has a suggestion.
Any insights are appreciated.
  • NWE
  • NWE's Avatar
08 Apr 2026 01:18
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
I understand this currently comes with 8 digital inputs and 8 digital outputs, besides the analog I/O. If I later wanted to add additional inputs, would it be just a simple matter of stacking on additional input cards and updating my linuxcnc config, or would additional changes be needed?
Displaying 3886 - 3900 out of 13570 results.
Time to create page: 5.191 seconds
