  • georgio
  • georgio
16 Mar 2026 01:20
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
thank you Peter,
That got rid of the error there but it points now to an error on Hal line 25: empty variable name. I don't know how lines are counted no matter how many ways I counted them it did not make sense to me.
I so very much appreciate your help, I have spending days with AI trying to get this figured out to no avail, you forum experts know this stuff!!!!
Grorge
  • rock861261
  • rock861261
16 Mar 2026 01:08
Replied by rock861261 on topic El5101 Config
El5101 Config
Category: EtherCAT
Can I use the El5101 for the a/b and use an optical sensor for the z with an input to EL1008
  • rock861261
  • rock861261
16 Mar 2026 00:47
El5101 Config
Category: EtherCAT
I can get a Z activation but cant configure it to linuxcnc
I agree I see a bunch of pieces but no results. So what does everyone use for a spindle encoder for threading?
  • Marcos DC
  • Marcos DC's Avatar
16 Mar 2026 00:42
Replied by Marcos DC on topic El5101 Config
El5101 Config
Category: EtherCAT
Did you check the Beckhoff EL5101 latch documentation?
EN_LATC / LATC_VAL look like the terminal’s native C/index latch mechanism to me, so the EL5101 does seem to provide native index support in hardware.
The real gap looks to be on the LinuxCNC side: mapping that cleanly into the expected index-enable semantics.
From what I have seen in the LinuxCNC forum threads, there are bits and pieces of reference material, but apparently no complete end-to-end example covering EL5101 + LinuxCNC spindle index semantics + threading/orient.
16 Mar 2026 00:31
Replied by tommylight on topic MESA 7i76eu Firmware
Category: Driver Boards
16 Mar 2026 00:27
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Did you try to lower the jog velocity to something really slow and jog?
  • rock861261
  • rock861261
16 Mar 2026 00:09
Replied by rock861261 on topic Spindle Encoder: Float Precision Issues
Category: HAL
Do you have a copy of the hal file?
  • Jaragua
  • Jaragua
15 Mar 2026 23:50
Também estou com o mesmo problema.aparentemente precisa editar o arquivo .hal no LinuxCNC. Conseguiu resolver?
  • PCW
  • PCW's Avatar
15 Mar 2026 23:43
This section of the hal file is broken in at least 3 ways:
#loadrt [KINS]KINEMATICS
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_stepgens=4 sserial_port_0=2"
#loadrt hostmot2
1. loadrt [KINS]KINEMATICS is commented out
2. loadrt hostmot2 is commented out
3. loadrt hostmot2 is in the wrong order (it must be loaded before hm2_eth)
It should look like what pncconf creates:
loadrt hostmot2
  • rock861261
  • rock861261
15 Mar 2026 23:04
El5101 Config
Category: EtherCAT
is it possible to set it up as a output to a 5v input? I can trigger it that way?
  • grandixximo
  • grandixximo's Avatar
15 Mar 2026 22:07 - 15 Mar 2026 22:10
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
@andrax
Sittner's repository does  not support
syncToRefClock
If you want to test Sascha Ittner's code with pll
Set
refClockSyncCycles="-1"
My code is a different repo
github.com/grandixximo/linuxcnc-ethercat
Sasha's code is missing some drivers, he has done a huge rework, he also removed the grind, but used another method, I am still undecided on how to merge his code properly.
  • georgio
  • georgio
15 Mar 2026 21:37
Hello all,
I am a newbie and I might have posted this question on the wrong thread before so I apologize for my lack of knowledge and experience. I have got my board and pc communicatiing and I think I have fixed most of the error but until i get this one fixed I won't know. I have an error which seems to be misidentifiying my z axis. I have a xyyx router setup hopefully to get y  squaring. The error I am getting says an undefined kinematicsSwitch and it leaves my setup with undefined limit on z. All help will be greatly appreciated. I will post my ini and hal files for you to look at.
Thanks again,
George
  • georgio
  • georgio
15 Mar 2026 21:12
Replied by georgio on topic MESA 7i76eu Firmware
File Name: georges_router.hal
File Size:18 KB
File Size:18 KB
File Name: georges_router.ini
File Size:5 KB
File Size:5 KB
Thank you for for your assistance, i VERY MUCH appreciate it.I am having problems with my hal files and my ini files no matter what i do i keep getting the same error message kinematisSwitch not defined. If I could get you look at my ini and hal files I would be eternally gratful. I have got past the communication errors and my pc is able to communicate with the 7i76eu I think I have most errors fixed now but unitl I get this current error out of the way I don't know if ther are anymore. I am not sure if this is the right place to ask, so please excuse my inexperience. Thannks again
George
  • Atsu
  • Atsu
15 Mar 2026 17:11
Replied by Atsu on topic Ethercat random jitter fix
Category: EtherCAT
@TAKUYA
@Atsu
please check the value of the parameters lcec.0.pll-step
You can do so with this command
halcmd show param lcec.0.pll-step
This parameter will be set at 1000 automatically if you have RTAPI_TASK_PLL_SUPPORT
also I have updated again the repo
if you could be so kind as to download, build and test again, thank you
Thank you! I pulled the latest changes and can confirm that it is now working. The dc-phased pin turns true, and I can see the pll- pins getting values other than zero. I did couple restarts and so far there is no grinding noise. I will continue testing to see if its gone for good.
  • fery15sty
  • fery15sty
15 Mar 2026 16:59
buildbot.linuxcnc.org is not active, how install linuxcnc 2.10 in debian buster
I've checked the site buildbot.linuxcnc.org/ again. It's back up and running. A while ago, the site was showing an error and couldn't be opened. The inactivity is probably temporary.
Thank you all for your responses.
Displaying 4876 - 4890 out of 13553 results.
Time to create page: 1.872 seconds
