25 Sep 2026 19:30
Faceting/Linearization leading to poor surface finish
Category: PathPilot
It doesnt change with feeds or speed changes or end mill changes. Its always there.
Does the rastering change with those changes?
Might want to try with a single or dual flute on some aluminium with the same high spindle speed and different feed rates to see if the distance changes, in general, if it does change would point to servo/tuning issues, if it does not would mean mechanical issue.
Would be nice to also do same feed rate, but vary the spindle speed.
Thinking of it, at what spindle speed are you cutting and what mill? I might have missed that.
25 Sep 2026 19:20
Connect external potmeters to rapid- and feedrate override sliders in QTDragon
Category: Qtvcp
@ the forum moderator: feel free to remove my question above.
Leaving it for now, we can decide later if it would be better to leave or delete.
Thank you.
  • Henk72
  • Henk72
25 Sep 2026 18:24
Category: Qtvcp
Dear forum,
I found more information related to what I am trying to do on section 2.8 of  www.linuxcnc.org/docs/html/gui/qtvcp.html#cha:qtvcp  . I will first try to go through these sections and see how far I can come...
  • Henk72
  • Henk72
25 Sep 2026 18:03
Category: Qtvcp
Dear forum members,
I am progressing well with the conversion of my 1980 MAHO MH300 to a linuxCNC based machine. I made a replacement console consisting of a high res screen (not a touch-screen) and keyboard + Estop etc. console (see attached image). I copied the layout of the console, including two potentiometers from a DMG machine. On the DMG these are intended for rapid traversal override and feed override. I am now trying to make QTDragon_HD to run and read that this GUI was not intended for keyboard use.... However, I do like the way the QTDragon gui screen is build up and would like to try to adapt it in such a manner that I can set these overrides with the potentiometers. Similar to the Estop I would like to go for an implementation where the console hardware (physical estop button and physical potentiometers) set the hal signals and that the QTDragon_HD GUI only displays (follows) the setting set by the button and potentiometers. For the Estop I think I made this work, but from what I have read thus far I think the QTDragon_HD does not allow these override sliders to be set by another HAL output. Is this indeed the case? I am still quite inexperienced in LinuxCNC, HAL and Qtvcp, maybe I overlooked something. Any help or suggestion is welcome!
  • BSAT
  • BSAT
25 Sep 2026 18:02
Category: PathPilot
I have reached out & got the updated servo files. But they said it will only help with i templates moves. If im seeing thisnproblem in a straight line then there is a mechanical issues.
I have reached out to clear path & the point me to tormach.
I have set it up per their instruction, its there. I set it up tighter or looser, its there, ive replace contact bearings on the axis, its there.
I autotuned the servos, helped maybe a little. But still there.
At this point I gotta think its a limitation/configuration of the servos that I dont readily have access too. By accident as much as I have messed with, it should have made a difference one way or the other. But it seems to be the same no matter what.
  • MarkoPolo
  • MarkoPolo
25 Sep 2026 17:58
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
I don't have a repository, but I can send the files.
Actually, it's just two modified files: `primitives.py` and `qt_vismach.py`.
  • BSAT
  • BSAT
25 Sep 2026 17:57
Category: PathPilot
Its not gcode related. Im using the conversational and moving in straight lines. But, it doesnt matter if its a straight line because I also see it in interpolated moves. It doesnt change with feeds or speed changes or end mill changes. Its always there.
  • Gotrune
  • Gotrune
  • cmorley
  • cmorley
25 Sep 2026 17:23
Replied by cmorley on topic Flex GUI 2.1.0 OpenGL 3.3
Category: Flex GUI
As for guis there is good and bad on both sides of having code in and out of the main project.
Linuxcnc is lucky, it has both options.
25 Sep 2026 16:00
Replied by tommylight on topic LinuxCNC-Branded USB Drives
Very nice idea, thank you.
  • andypugh
  • andypugh's Avatar
25 Sep 2026 14:59 - 25 Sep 2026 15:03
LinuxCNC-Branded USB Drives was created by andypugh
I have had occasions at events like EMF Camp and Maker Central that I have wished that I had a USB drive with LinuxCNC on it to hand out, like a sort of business-card for the project. It would lower the barrier for entry, and also serve as a reminder of the conversation when they got home.
However, I don't want to spend my own money on this. So the plan I hatched was to sell a decently-sized version of the USB key at a slight premium, each of which funds a smaller, cheaper giveaway version.
So this is what I have done. £25 gets you a 128GB LinuxCNC stick with both USB-A and USB-C plugs, and also buys an 8GB one with LinuxCNC on it, for a stranger who is not yet aware of the joys of LinuxCNC.
www.ebay.co.uk/itm/117429761717
  • tietouwa
  • tietouwa's Avatar
25 Sep 2026 13:48
J1900 L2 sibling: pin Qt HMI to CPUs 0-1, keep the 1 ms EtherCAT thread on CPU3
Category: EtherCAT
Thanks rodw. I'm not using ec_generic. The EtherCAT port runs on IgH's native ec_r8169 driver, which is polled from the RT thread on CPU3, so there is no NIC IRQ to pin. What I pinned: the 1 ms thread on CPU3 (SCHED_FIFO 80), and the Qt HMI threads on CPUs 0-1 via taskset. Isolating CPU2 is a good idea. I'll try it next.
  • Japoo_Ness
  • Japoo_Ness
25 Sep 2026 11:10
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
Hi everyone, I'm experiencing noisy/fluctuating readings on my axes. They are currently ungrounded as I just wanted to verify basic readings first. My main star ground is in the main electrical cabinet, but my Mesa 7I97T is mounted remotely in the old display/controller enclosure. I'm considering the grounding scheme shown in the attached diagram. Is this a good approach for logic signals, or will the extra connection points make it more prone to noise and ground loops?
  • JB-Motoring
  • JB-Motoring
25 Sep 2026 10:59
Exchange Simodrive 610 to new components was created by JB-Motoring
Hello guys,
I am running Linuxcnc on my Chiron FZ12S for almost 10 years now.
The machine is equipped with Siemens hardware ( 1FT5 Motors and Simodrive 610 +/-10V).
What I notice, is that the Simodrive is getting old... It starts with random Joint following errors, then cutting out, Errors ect.
There are days, where you have to switch on and off like 50 times to get the machine homing without error...That's just frustrating. But yeah, the drives are almost 35 years old, so quite okay for that age.
I am thinking quite long about this project, but today pissed me so off, that I really want to move on.
For me, it's no option in buying "refreshed" hardware, because that stuff is expensive and also 30+ years old....
So my wish would be, to completely throw the Simodrive away and replace it by new hardware, that doesn't cost as much as the Siemens stuff.
I am running this right now on the 7I77 hardware, but for sure can switch to another board.
Motors XYZ, 4th axis are: Siemens 1FT5064- 1.6 kW @ 4000 RPM
Spindle: Siemens 1FT5076- 7.5 kW @ 7100 RPM
The motors are equipped with Tachos and ROD encoders.
Are there any drives, that could work with these? I would really like to keep the motors, as they are really good and not worn out.
I am happy over any input!
Thank you guys!
  • Aciera
  • Aciera's Avatar
25 Sep 2026 10:42
Replied by Aciera on topic Notifications
Notifications
Category: Show Your Stuff
Thanks for sharing it!
Displaying 541 - 555 out of 12281 results.
Time to create page: 0.577 seconds
