  • rodw
  • rodw's Avatar
09 Feb 2026 03:54
Retrofitting an old industrial CNC Plasma table
Category: Plasmac
This example config include a separate ohmic.hal and the hypersensing component is in the components folder.
github.com/rodw-au/showstopper
  • Looby
  • Looby
09 Feb 2026 03:13
Lenovo T14 Gen2 AMD - CRAZY High Latency - Am I screwed?
Like it could be a cooling issue? I guess I can pull the cooler off but the fans are barely spinning and fdoesnt feel warm at all.
09 Feb 2026 03:10
Last ditch effort, but not far fetched: repaste the CPU.
09 Feb 2026 03:09
  • besriworld
  • besriworld
09 Feb 2026 02:56
Servo Wiring and Tuning detailed How To example Mesa 7i77.
I am trying to configure the spindle as a C-axis, but I am having a problem and cannot find a solution.
Could someone please take a look at my configuration and the video and give me some advice?
I was not able to post this in the original lathe thread.
# AXIS C JOINT 2
setp  pid.c.Pgain     [JOINT_2](P)
setp  pid.c.Igain     [JOINT_2](I)
setp  pid.c.Dgain     [JOINT_2](D)
setp  pid.c.bias      [JOINT_2](BIAS)
setp  pid.c.FF0       [JOINT_2](FF0)
setp  pid.c.FF1       [JOINT_2](FF1)
setp  pid.c.FF2       [JOINT_2](FF2)
setp  pid.c.deadband  [JOINT_2](DEADBAND)
setp  pid.c.maxoutput [JOINT_2](MAX_OUTPUT)
setp  pid.c.error-previous-target true
net c-index-enable    =>  pid.c.index-enable
net c-enable          =>  pid.c.enable
net c-pos-cmd         =>  pid.c.command
net c-spindle-pos-fb  =>  pid.c.feedback
net c-output          <=  pid.c.output
# ---PWM Generator signals/setup---
268 net c-output            =>  hm2_7i98.0.pwmgen.00.value
269 net c-pos-cmd           <=  joint.2.motor-pos-cmd
270 net c-enable            <=  joint.2.amp-enable-out
271 # enable _all_ sserial pwmgens
272 #net c-enable            =>  hm2_7i92.0.7i77.0.1.analogen
276 net c-spindle-pos-fb    <=  hm2_7i98.0.encoder.02.position
277 net c-spindle-vel-fb    <=  hm2_7i98.0.encoder.02.velocity
278 net c-spindle-pos-fb    =>  joint.2.motor-pos-fb
279 #net c-index-enable     joint.0.index-enable <=> hm2_7i92.0.encoder.06.index-enable
280 net c-pos-rawcounts     <=  hm2_7i98.0.encoder.02.rawcounts
282 # ---setup home / limit switch signals---
284 net c-home-sw           =>  joint.2.home-sw-in
285 net c-neg-limit         =>  joint.2.neg-lim-sw-in
286 net c-pos-limit         =>  joint.2.pos-lim-sw-in
[AXIS_C]
MAX_VELOCITY     = 360
MAX_ACCELERATION = 500
MIN_LIMIT        = -900.0
MAX_LIMIT        = 900.0
[JOINT_2]
TYPE             = ANGULAR
HOME             = 0.0
FERROR           = 1000.0
MIN_FERROR       = 500.0
MAX_VELOCITY     = 360
P        = 0.0000001
I        = 0.
D        = 0.
FF0      = 0.98
FF1      = 0
FF2      = 0
BIAS     = 0
DEADBAND = 0.1
MAX_OUTPUT = 10
ENCODER_SCALE    = -40
OUTPUT_SCALE     = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -1000
MAX_LIMIT = 1000
HOME_OFFSET   = 0.0
HOME_SEQUENCE = 1
  • Looby
  • Looby
09 Feb 2026 02:51
Well Ive spent all day trying other installs or live versions and no dice. Cant get any to run live as they just hang at a blank cursor screen. Cant even get anything installed due to a "bad archive mirror" error.
Tried latest regular Debian and got that installed and then followed directions to install linuxcnc and got it up enough to latency test aaaaaand 4,550,000ns....
What causes this so I have some idea what to avoid in the future? What in the hardware would cause this?
  • PCW
  • PCW's Avatar
09 Feb 2026 02:09
Replied by PCW on topic socket raw Eth.
socket raw Eth.
We did some tests last year comparing IP network access vs raw packets
with Mesa HostMot2 and the statistical improvement of peak latency  was
minimal so decided it was not worth the effort.
There no issue with root access and LinuxCNC as direct hardware access
requires this and the blocking of normal network traffic on the real time
Ethernet channel also requires root priviledges.
  • Massimo148
  • Massimo148
09 Feb 2026 01:58
Replied by Massimo148 on topic Retrofitting an old industrial CNC Plasma table
Category: Plasmac
thank you for the information Rod. mine has an hpr 130 torch on it and it uses technical gases while cutting, it is dual shielded. the probing happnens from the outer shield on wich the copper consumable touches the table and completes the loop with the ground cable. the wire for probing is connected to the outer shield itself, i can send a picture tomorrow if needed. i'll order two THCAD boards. how would i proceed to connect the one used for probing to the Mesa 7i97T? is it the same as voltage sensing? connected to an encoder input?
09 Feb 2026 01:47
Replied by tommylight on topic 403 Forbidden
403 Forbidden
Category: Forum Questions
Try now
  • PCW
  • PCW's Avatar
09 Feb 2026 01:06
Replied by PCW on topic Configuration Problems 7i92 PnCConf
Category: PnCConf Wizard
The point is that for most configurations you don't deal with pin numbers at all,
just channel numbers, which is also consistent with the hal file function naming.
For GPIO (which is not much used on newer systems) it would be helpful if
pncconf listed the pin numbers at least for parallel port BOBs
  • markbaenen
  • markbaenen
09 Feb 2026 00:50
Replied by markbaenen on topic Configuration Problems 7i92 PnCConf
What is the point of this config page? This has to be the least intuitive config thing I have ever seen.
  • PCW
  • PCW's Avatar
09 Feb 2026 00:15
Replied by PCW on topic 403 Forbidden
403 Forbidden
If this is:
forum.linuxcnc.org/18-computer/58339-socket-raw-eth
I get a 401 error if not logged in and a 403 error when logged in,
so I don't think it's a  user issue.
  • rodw
  • rodw's Avatar
09 Feb 2026 00:13
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
As Tommy alludes to Grub errors are usually because you have secure boot enabled. Turn that off in the BIOS. Trixie is batter with secure boot but still better to disable it.
08 Feb 2026 22:47
In BIOS:
disable "secure boot"
enable CSM
try switching from Legacy to UEFI and vice versa.
08 Feb 2026 22:45
403 Forbidden
Are you using VPN?
Try disabling it.
Forbidden errors are always from trying to access restricted parts of the web server, so something is wrong on users side.
Displaying 6511 - 6525 out of 13542 results.
Time to create page: 0.461 seconds
