9 years 1 month ago - 9 years 1 month ago #99395 by pippin88
Replied by pippin88 on topic Gmoccapy - A new screen for linuxcnc
Norbert,
A couple of things:
Documentation for 2.8 (master) has pin names which appear to have changed in new versions of gmoccapy.
gmoccapy.reset-spindle-override is now gmoccapy.spindle.reset-spindle-override
gmoccapy.reset-feed-override is now gmoccapy.feed.reset-feed-override
(from memory, I'm away from my CNC pc).
Is the information regarding XZ + C lathe from forum.linuxcnc.org/gmoccapy/30175-xz-lat...xis-gmoccapy-crashes still relevant in lastest gmoccapy? If so, can you include it in the documentation?
I ran into this problem on 2.7.11, but have since changed to master and have not tried this setup again.
Once again, thanks for gmoccapy - it is an awesome GUI.
Last edit: 9 years 1 month ago by pippin88.
9 years 1 month ago #99420 by Patrik T
Replied by Patrik T on topic Gmoccapy - A new screen for linuxcnc
Bug fix in _init_axis_four( self ),
for axis in self.axis_list: self.widgets["Combi_DRO_%s" % axis].set_property( "font_size", self.dro_size ) if self.get_ini_info.get_lathe(): # There is a bug here that I am patching. self.widgets["Combi_DRO_%s" % 'y'].set_property( "font_size", self.dro_size )
9 years 1 month ago #99648 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
I will check this and correct as soon as possible
I have not tested, but IMHO it is not possible to have a machine with that configuration, as gmoccapy expect the first 3 coordinates to be XYZ. I am not sure, if it does worse to include such configs, but I will check how much work that would be to include.
What is the bug? I have not noticed any till now.
Norbert
9 years 1 month ago #99651 by Patrik T
The bug is that in lathe mode, if I change the DRO font size in the settings page, only the R and Z axes changes size. The D axis font size is unaffected.
9 years 1 month ago #99666 by newbynobi
OK, I can reproduce that one.
Should I wait for your fix, or just push the correction?
Norbert
9 years 1 month ago #99672 by Patrik T
Don't wait for me.
The code I posted does fix the problem, but it is only a quick and dirty fix.
Moderators: newbynobi, HansU
Time to create page: 3.964 seconds
