8 years 10 months ago #103739 by kjacobs
Replied by kjacobs on topic Gmoccapy - A new screen for linuxcnc
Hallo Norbert,
I just checked that gscreen has the same offset issue with de_DE.utf8 as gmoccapy. There is really no need to put much work into this as setting LC_NUMERIC differently is not a problem at all, at least for my application. Exciting news that you are working on a new version and going from glade to Qt. I am looking forward to that!
Cheers,
Karl
8 years 10 months ago #103919 by grijalvap
Replied by grijalvap on topic Gmoccapy - A new screen for linuxcnc
hi
does anybody know how I can connect the DRO input to a different pin other than the default Z axis?
8 years 10 months ago #103921 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
What are you trying to do?
All can be done in the gmoccapy python file,
but without more details no one will be able to help.
What gmoccapy release?
What config?
What distro?
What purpose?
Norbert
8 years 9 months ago - 8 years 9 months ago #103935 by grijalvap
HI
Happy new year to all.
I have created a kind of stand-alone THC component for plasma.
forum.linuxcnc.org/plasma-laser/32555-do...nent?start=20#103768
This component does not work with the motion controller.
However, I really like to show the step generator feedback on the DRO & Plot
I'm working on the master branch with the debian distro.
thanks...
Last edit: 8 years 9 months ago by grijalvap.
8 years 9 months ago #103948 by newbynobi
I just looked in the sample INI you referenced too.
It is an axis config, so may your comment is in the wrong thread?
Norbert
8 years 9 months ago #103952 by grijalvap
Well, I have a very limited knowledge of the Gmocaapy GUI.
As I see in a normal configuration the feedback from step generator should be connected to
joint.x.motor-post-fb
net x-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
however, I don't want to connect mine to a joint, I want to connect directly to DRO
thanks..
Moderators: newbynobi, HansU
Time to create page: 3.214 seconds
