12 years 6 months ago #46319 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
mariusl wrote: Although Gmoccapy can handle 4 axis configurations, I dont know about the foam config. You must also see what kinematics are required for the foam cutting. Maybe look at gantrykins (not sure though).
Does your setup work with Gscreen at the moment?
A "Foam Cutter" view is an option in Axis.
www.linuxcnc.org/emc2/index.php/english/...-stepconf-test#40952
Has a screenshot of what it looks like.
  • cx4359481
  • Visitor
  • Visitor
12 years 6 months ago #46321 by cx4359481
Replied by cx4359481 on topic Gmoccapy - A new screen for linuxcnc
Hi!
This is use "Axis GUI",I want to use "gmoccapy" or "gscreen" to achieve XYUV control。
12 years 6 months ago - 12 years 6 months ago #46322 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
cx4359481 wrote: Hi!
I have looked over "linuxcnc-dev/configs/sim/axis/axis_foam.ini" and others .It seems have no connection with “gantrykins”
When i use "Gscreen“,I find that “Gscreen” may has some connections with "pGLADEvcp widgets hal_action_open"
I guess that is there any error happened with "hal_action_open"?
The foam sample config in Axis directory uses Gantrykins. Look in the hal file.
The foam config will not work in Gmoccapy though. I dont know if it will work in Gscreen.
Regards
Marius
www.bluearccnc.com
Last edit: 12 years 6 months ago by mariusl.
12 years 6 months ago #46323 by andypugh
mariusl wrote: The foam sample config in Axis directory uses Gantrykins. Look in the hal file..
It seems to use core-sim-9 ?
There is absolutely no reason for a foam cutter to use Gantrykins.
12 years 6 months ago #46327 by dcrabtree
Replied by dcrabtree on topic Gmoccapy - A new screen for linuxcnc
Norbert
Just wanted to drop a huge Thanks for making Gmoccapy. I love the feel of it and now that ArcEye and andypugh helped me with a few other issues(not relating to Gmoccapy) this will be perfect for us to get rid of our Flashcut controllers that run on windows.
Thanks for all of your hard work.
David
12 years 6 months ago #46341 by mariusl
Hi Norbert
I did a fresh pull today and after compiling I tested a ngcgui file I have been working on. Before the update it worked ok but after the update I get these errors.
this is the file I am running. The stuff that is commented out in at the top is the next things to test via remap.
File Name: seal_a.ngc
File Size:6 KB
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.378 seconds
