- straga
12 years 5 months ago - 12 years 5 months ago #47332
by straga
Replied by straga on topic Gmoccapy - A new screen for linuxcnc
I have config. and ngc g-code test file.
If your load that config you can't move withot Ferror.
Join 0-2 fallowing
But if you open file in Axes with same hall and ini just adapted some parametrs. It work perfectly.
Velocity speed 2700-3500.
I am check that on 10.04 , 12.04. - 2.6pre3 -
Different PC.
All same.
27.05 - I am also check gscreen (with my hall and Holle1-4,,, ) - it work right without Ferror, like in Axis.
Config -
G-code -
Join 0-2 fallowing
Different PC.
All same.
Config -
G-code -
Last edit: 12 years 5 months ago by straga. Reason: check gscreen
- mariusl
12 years 5 months ago #47401
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I am busy with some testing on my lathe setup and found some strange behaviour and some requests please.
1: After homing the touch-off button is greyed out and you have to switch the machine off to get it back.
2: The Zero G92 button does not clear the offsets but jumps the screen directly to MDI mode.
Requests:
1: Is it possible for set the DRO startup mode. I would like to use ABS
2:After homing cycle is complete, do not jump to G54 on the DRO but stay in the selected mode.
As always thanks for your kind support
Requests:
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 5 months ago #47406
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@straga,
What did you change?
The ngc File does run fine here on 2 Machines and also on sim.
Norbert
Norbert
- newbynobi
12 years 5 months ago #47407
by newbynobi
Hay Marius,
I am not able to reproduce the homing stuff, on sim it does work like expected.
But the G92 button is messing around, I will fix that as soon as possible.
You requests:
Start up mode selection, I will not put afford in that right now, as I do not see it as urgent as other fixes.
Same for the G54 /G55 changes and your wish to stay in ABS, but I did right it to my list, so I hope not to forget about that.
Norbert
You requests:
Norbert
- mariusl
12 years 5 months ago #47408
by mariusl
Regards
Marius
www.bluearccnc.com
Thanks Norbert.
Maybe also look at the offset edit screen. When you edit a value manually and push return, the screen makes an exit in stead of remaining in the edit mode.
Regards
Marius
www.bluearccnc.com
- straga
12 years 5 months ago #47410
by straga
with same parametrs it file works on axes and gsscreen too. What parametr me need tune in gmoccapy ?
i am copy hal and ini from axes or gsscren to gmoccapy and Rerror when fast move only in gmocappy.
Moderators: newbynobi, HansU
Time to create page: 0.736 seconds
