- Thank you received: 394
- newbynobi
I pushed a fix, so please get gmoccapy 1.1.5.2 from master.
The jump out after edditing is a known problem, but may need a complete rework of the offsetpage widget, I will ask Chris for help.
Chris, could you give me a hand on that?
Norbert
- newbynobi
with same parametrs it file works on axes and gsscreen too. What parametr me need tune in gmoccapy ?
i am copy hal and ini from axes or gsscren to gmoccapy and Rerror when fast move only in gmocappy. vv
Very strange, did anyone else had such problems?
Please post you complete config folder with axis and gmoccapy settings.
Norbert
- straga
Gmoccapy ferror -
Gscreen ok -
My configs
b.1-m1 - my config Gmoccapy - Ferror.
b.1-M1-gmoccapy - it just testing - Ferror.
my-mill - Axes config. - work ok.
gscreen - work ok.
- LAIR82
I have noticed the same thing as earlier, with the part preview not moving around using your finger on a touch screen. I have tried the different options for mouse buttons, but to no luck.
The zoom buttons work fine but I can't move the preview around and on large parts, like we do, it would be nice to have that move around.
Rick
- LAIR82
LAIR82 wrote: Hello Norbert,
We are taking Gmoccapy for a test drive on one of our turning centers and I have some questions,
1. When you edit a program and press the save button, does it reload it as well? I see the save/reload/run button but not a reload, and the operators while not be using the save/reload/run button.
2. How do you go about using the pop-up messages similar to what gscreen uses that are configured in the INI, example,
MESSAGE_BOLDTEXT = NONE
MESSAGE_TEXT = This is a statusbar test
MESSAGE_TYPE = status
MESSAGE_PINNAME = statustest
MESSAGE_TEXT = This is an ok dialog test
MESSAGE_TYPE = okdialog
MESSAGE_PINNAME = okdialogtest
MESSAGE_TEXT = This is an yes/no dialog test
MESSAGE_TYPE = yesnodialog
MESSAGE_PINNAME = yesnodialogtest
I have about twenty different messages configured for gscreen that will popup in the event of faults, low fluids, low pressures, etc,,,
Rick
Hey Guys,
Just wondered if you have any comments on these things?
Rick
- mariusl
There seem to be an issue with the MDI mode after partial homing or tool edit. After I done one of these I can see the MDI button is on but the MDI screen section is not displayed. I.E. the jogging keys remain in place although the mode is MDI.
Regards
Marius
www.bluearccnc.com
