- Thank you received: 83
- billykid
12 years 4 months ago - 12 years 4 months ago #48298
by billykid
Replied by billykid on topic Gmoccapy - A new screen for linuxcnc
Hello
I installed LinuxCNC-dev 2.7.0 and 1.1.5.3 gmoccapy run in place.
change the configuration works fine on my machine but when it goes into the tool change position specified in the ini file give this error:
linear move in line 21 exceeds axis 1 positive limit.
actually reaches the right position in my case y -200
x-axis and z-axis are fine.
after this error the key mdi no longer in effect
thanks in advance
Mauro
thanks in advance
Mauro
Last edit: 12 years 4 months ago by billykid.
- newbynobi
- Thank you received: 394
12 years 4 months ago #48301
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Mauro,
first : Nice YAMAHA XT, is it a 500 cc or 600 cc?
Ok to solve your tool change problem, please post your INI file, so I can try to reproduce it.
Norbert
Norbert
- billykid
12 years 4 months ago #48302
by billykid
hallo Norbert
first thanks for all !!
My xt 550 year 82, first four valve, electronic advance mono shock ecc really 558 cc
here is my ini
many thanks
Mauro
here is my ini
many thanks
Mauro
- newbynobi
12 years 4 months ago #48304
by newbynobi
Hallo Mauro,
have you checked this line?
TOOL_CHANGE_POSITION = 100 100 -10
This line will be used by the normal linuxcnc toolchange.
Do you use integrated tool chnage or the remaped version?
Please try commenting out the above mentioned line.
Norbert
Norbert
- billykid
12 years 4 months ago - 12 years 4 months ago #48305
by billykid
yes !
i use remapped version.
now go to the change position i can change tool and it appear in tool information
but message says: it is not possible to change to auto mode at moment.
Mauro
edit
enter mdi mode type m6 t1 probe correct but says: parameter #<workpiece_height> not defined
edit
renamed parameter #<workpiece_height> to #<block_height> in change.ngc and seems to work.
The last problem is this: it is not possible to change to auto mode at moment.
thanks to the availability and the excellent work.
Mauro
Mauro
edit
edit
Mauro
- newbynobi
12 years 4 months ago #48306
by newbynobi
Hallo Mauro,
please try:
- estop reset
- switch on the machine
- home all axis
- push auto mode button,
what happens?
Norbert
please try:
- estop reset
- home all axis
what happens?
Norbert
Moderators: newbynobi, HansU
Time to create page: 4.900 seconds
