- Thank you received: 394
- newbynobi
12 years 3 months ago #48573
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
solved with 1.1.5.4
Norbert
Norbert
- DaBit
- Thank you received: 19
12 years 3 months ago - 12 years 3 months ago #48574
by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
Yesterday I started LinuxCNC while the Y-axis was on the limit switch.
I got the error when trying to turn the machine on, and the jog buttons were grayed out. Now, that's normal.
But the 'override limits' button was also greyed out, and that's not normal.
I'm running a 2.7.0~pre RIP build which I checked out 1-2 weeks ago.
Last edit: 12 years 3 months ago by DaBit.
- billykid
- Thank you received: 83
12 years 3 months ago #48610
by billykid
Replied by billykid on topic Gmoccapy - A new screen for linuxcnc
Hello Norbert,
I configured both the tool change with probe. and CamView.
everything works fine except the window that always displays change.ngc instead of the main programand spindle icon are gray.
anyway thanks for the great work of this interface.
best regards
Mauro
best regards
Mauro
- newbynobi
12 years 3 months ago #48734
by newbynobi
@verser,
I just pushed 1.1.5.6 to master and 2.6, including new hal pin:
gmoccapy.program.length = S32, OUT (total number of program lines)
gmoccapy.program.current-line =S32, OUT (current executed line)
gmoccapy.program.progress = FLOAT, OUT (progress in %)
Now you are able to make your custom panel just with one hal progress bar and connect the gmoccapy hal pin to the progress bar.
I did not include jet such a bar in standard GUI, because I do not know where to place it.
Norbert
Hi Norbert,
In Gmoccapy, large g-code program is dynamically loaded into the window and scroll slider is impossible to estimate how much has already been done.
Is it possible to make indicator of the accomplished part of large g-code programm?
@verser,
Norbert
- mariusl
12 years 3 months ago #48735
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I am busy testing the lathe screen and it is working real good now after the last changes that you did on the offset editor and MDI mode stuff.
I have a request please. Is it possible to have a indicator to show if we are in Radius or Diameter mode. Especially in the touch off screen. Sometimes some gcode program can pit the machine into another mode than what you usually operate in and then when you touch off you enter the wrong offset.
Regards
Marius
www.bluearccnc.com
- jlviloria
- Thank you received: 9
12 years 3 months ago #48815
by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Hello norbert,
Update my LinuxCNC, but when trying to open my gmoccapy environment, the screen opens but closes it ejectute from the terminal and shows me the following, attachment.
thanks,
Jorge Viloria
thanks,
Jorge Viloria
Moderators: newbynobi, HansU
Time to create page: 0.274 seconds
