- mariusl
12 years 3 months ago #48816
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Jorge
Did you do a "make clean" before building again after the pull?
And then do
./autogen
./configure
from the /src directory
And then do
./autogen
./configure
Regards
Marius
www.bluearccnc.com
The following user(s) said Thank You: jlviloria
- jlviloria
- Thank you received: 9
12 years 3 months ago #48817
by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Marius,
I make clean but still have problems
thanks
thanks
- mariusl
12 years 3 months ago #48818
by mariusl
Regards
Marius
www.bluearccnc.com
Jorge
I dont understand much of what I see in the file due to language barrier but I did see this line
there is a dot after the sim in the directory line "sim.gmoccapy" I dont know if that has anything to do with the problems but I suggest that you have a look at that.
How do you start the system?
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.gmoccapy'
Regards
Marius
www.bluearccnc.com
- newbynobi
- Thank you received: 394
12 years 3 months ago #48929
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hola Jorge,
favor de hacer lo siguiente:
maneja a /linuxcnc-dev/src
make clean
./autogen.sh
./configure
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcnc
Saludos de Norbert
make clean
./autogen.sh
./configure
make
sudo make setuid
cd ..
linuxcnc
Saludos de Norbert
- newbynobi
12 years 3 months ago #48930
by newbynobi
Hallo Jorge,
all the errors in you last attachment are normal, they are more likely informations from gmoccapy, I can not see, why linuxcnc closes at this time.
Have you tried any other GUI?
Norbert
Norbert
- newbynobi
12 years 3 months ago #48931
by newbynobi
@Marius
This is already included.
Please watch the DRO.
If you are in G8 the D-DRO should be with gray background, in G7 the R-DRO is grayed out.
Just look there and you know the black one is the active one.
Norbert
I have a request please. Is it possible to have a indicator to show if we are in Radius or Diameter mode. Especially in the touch off screen. Sometimes some gcode program can pit the machine into another mode than what you usually operate in and then when you touch off you enter the wrong offset.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.448 seconds
