22 Jun 2014 23:05 - 22 Jun 2014 23:13 #48187 by tuxcnc
Replied by tuxcnc on topic Gmoccapy - A new screen for linuxcnc
I got a confusing message :
File "/usr/lib/pymodules/python2.7/gmoccapy/widgets.py", line 42, in __getitem__
    raise IndexError, "No widget %widget" % attr
ValueError: unsupported format character 'w' (0x77) at index 11
It was after update LinuxCNC and I suspected error in new code.
I have spent few hours, before I found reason of this error.
Simply I wrote in ini file :
EMBED_TAB_LOCATION = ntb_user_tab
not :
EMBED_TAB_LOCATION = ntb_user_tabs
Each typo ends with this error, I think it would be good to prevent it.
Regards.
Last edit: 22 Jun 2014 23:13 by tuxcnc. Reason: correction
22 Jun 2014 23:34 #48188 by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
Small feature request, not that important: when I want to scroll through a loaded G-code program in the 'auto mode screen' I am stuck with the default tiny scroll-buttons. My touchscreen is not super-accurate, so these are a bit cumbersome to use.
Being able to scroll like we do on an Android phone (touch and drag) would be nice. But probably hard to implement I suppose?
28 Jun 2014 12:58 - 28 Jun 2014 13:20 #48298 by billykid
Replied by billykid on topic Gmoccapy - A new screen for linuxcnc
Hello
I installed LinuxCNC-dev 2.7.0 and 1.1.5.3 gmoccapy run in place.
change the configuration works fine on my machine but when it goes into the tool change position specified in the ini file give this error:
linear move in line 21 exceeds axis 1 positive limit.
actually reaches the right position in my case y -200
x-axis and z-axis are fine.
after this error the key mdi no longer in effect
thanks in advance
Mauro
Last edit: 28 Jun 2014 13:20 by billykid.
28 Jun 2014 14:01 #48301 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Mauro,
first : Nice YAMAHA XT, is it a 500 cc or 600 cc?
Ok to solve your tool change problem, please post your INI file, so I can try to reproduce it.
Norbert
28 Jun 2014 14:19 #48302 by billykid
hallo Norbert
first thanks for all !!
My xt 550 year 82, first four valve, electronic advance mono shock ecc really 558 cc
here is my ini
many thanks
Mauro
28 Jun 2014 15:06 #48304 by newbynobi
Hallo Mauro,
have you checked this line?
TOOL_CHANGE_POSITION = 100 100 -10
This line will be used by the normal linuxcnc toolchange.
Do you use integrated tool chnage or the remaped version?
Please try commenting out the above mentioned line.
Norbert
28 Jun 2014 15:22 - 28 Jun 2014 16:38 #48305 by billykid
yes !
i use remapped version.
now go to the change position i can change tool and it appear in tool information
but message says: it is not possible to change to auto mode at moment.
Mauro
edit
enter mdi mode type m6 t1 probe correct but says: parameter #<workpiece_height> not defined
edit
renamed parameter #<workpiece_height> to #<block_height> in change.ngc and seems to work.
The last problem is this: it is not possible to change to auto mode at moment.
thanks to the availability and the excellent work.
Mauro
Last edit: 28 Jun 2014 16:38 by billykid.
28 Jun 2014 17:46 #48306 by newbynobi
Hallo Mauro,
please try:
- estop reset
- switch on the machine
- home all axis
- push auto mode button,
what happens?
Norbert
28 Jun 2014 17:53 #48308 by billykid
hello Norbert,
enter in auto mode regularly ..
not program load
mauro
28 Jun 2014 18:31 #48310 by billykid
if you load a program runs but when changing tool displays change.ngc without returning to the main program.
runs but always displaying change.ngc.
I have to leave now, I enclose change.ngc to see if it has problems
thanks
Mauro
Moderators: newbynobi, HansU
Time to create page: 1.026 seconds
