27 May 2014 22:54 #47406 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@straga,
just adapted some parametrs.
What did you change?
The ngc File does run fine here on 2 Machines and also on sim.
Norbert
27 May 2014 23:03 #47407 by newbynobi
Hay Marius,
I am not able to reproduce the homing stuff, on sim it does work like expected.
But the G92 button is messing around, I will fix that as soon as possible.
You requests:
Start up mode selection, I will not put afford in that right now, as I do not see it as urgent as other fixes.
Same for the G54 /G55 changes and your wish to stay in ABS, but I did right it to my list, so I hope not to forget about that.
Norbert
27 May 2014 23:15 #47408 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks Norbert.
Maybe also look at the offset edit screen. When you edit a value manually and push return, the screen makes an exit in stead of remaining in the edit mode.
Regards
Marius
www.bluearccnc.com
27 May 2014 23:51 #47410 by straga
Replied by straga on topic Gmoccapy - A new screen for linuxcnc
with same parametrs it file works on axes and gsscreen too. What parametr me need tune in gmoccapy ?
i am copy hal and ini from axes or gsscren to gmoccapy and Rerror when fast move only in gmocappy.
28 May 2014 00:01 #47411 by newbynobi
Hallo Marius,
I pushed a fix, so please get gmoccapy 1.1.5.2 from master.
The jump out after edditing is a known problem, but may need a complete rework of the offsetpage widget, I will ask Chris for help.
Chris, could you give me a hand on that?
Norbert
28 May 2014 00:04 #47412 by newbynobi
i am copy hal and ini from axes or gsscren to gmoccapy and Rerror when fast move only in gmocappy. vv
Very strange, did anyone else had such problems?
Please post you complete config folder with axis and gmoccapy settings.
Norbert
28 May 2014 00:25 - 29 May 2014 01:06 #47413 by straga
I am make video.
Gmoccapy ferror -
Gscreen ok -
My configs
File Name: configs.tar.gz
File Size:90 KB
b.1-m1 - my config Gmoccapy - Ferror.
b.1-M1-gmoccapy - it just testing - Ferror.
my-mill - Axes config. - work ok.
gscreen - work ok.
Last edit: 29 May 2014 01:06 by straga.
28 May 2014 20:11 #47459 by LAIR82
Replied by LAIR82 on topic Gmoccapy - A new screen for linuxcnc
Hello Guys,
I have noticed the same thing as earlier, with the part preview not moving around using your finger on a touch screen. I have tried the different options for mouse buttons, but to no luck.
The zoom buttons work fine but I can't move the preview around and on large parts, like we do, it would be nice to have that move around.
Rick
09 Jun 2014 21:09 #47814 by LAIR82
Hello Norbert,
We are taking Gmoccapy for a test drive on one of our turning centers and I have some questions,
1. When you edit a program and press the save button, does it reload it as well? I see the save/reload/run button but not a reload, and the operators while not be using the save/reload/run button.
2. How do you go about using the pop-up messages similar to what gscreen uses that are configured in the INI, example,
MESSAGE_BOLDTEXT = NONE
MESSAGE_TEXT = This is a statusbar test
MESSAGE_TYPE = status
MESSAGE_PINNAME = statustest
MESSAGE_TEXT = This is an ok dialog test
MESSAGE_TYPE = okdialog
MESSAGE_PINNAME = okdialogtest
MESSAGE_TEXT = This is an yes/no dialog test
MESSAGE_TYPE = yesnodialog
MESSAGE_PINNAME = yesnodialogtest
I have about twenty different messages configured for gscreen that will popup in the event of faults, low fluids, low pressures, etc,,,
Rick
Hey Guys,
Just wondered if you have any comments on these things?
Rick
10 Jun 2014 16:45 #47841 by mariusl
Hi Norbert
There seem to be an issue with the MDI mode after partial homing or tool edit. After I done one of these I can see the MDI button is on but the MDI screen section is not displayed. I.E. the jogging keys remain in place although the mode is MDI.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.234 seconds
