28 Jun 2014 18:50 #48311 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Have you tried with the file
nc_files/gmoccapy_2_tools_with_cutter_radius_compensation.ngc
I used that one to test.
Norbert
The following user(s) said Thank You: billykid
28 Jun 2014 21:24 - 28 Jun 2014 22:03 #48312 by billykid
Replied by billykid on topic Gmoccapy - A new screen for linuxcnc
works best with gmoccapy_2_tools_with_cutter_radius_compensation.ngc
but the window is displayed change.ngc.
only at the end returns to the main program.
try again tomorrow to be more precise
good evening
Mauro
Last edit: 28 Jun 2014 22:03 by billykid.
30 Jun 2014 13:37 #48337 by billykid
Hello Norbert
everything works! to copy and paste some files were characters out of place.
the only problem is that the window gcode remains change.ngc even after the change
tool.
What I think I see also in your video on youtube.
however, the program is executed regularly, I tried using a file generated by eagle, for drilling a printed circuit board with various tips and works perfectly.
thanks
Mauro
07 Jul 2014 13:15 #48487 by mshaver
Replied by mshaver on topic Gmoccapy - A new screen for linuxcnc
I'm using the latest 2.6-pre version from the buildbot and when I
enable the aux acreen I get the following error the next time I start
linuxcnc:
www.mattshaver.com/error.png
Any ideas on this?
Also, are there any articles or online writeups on extending gmoccapy
with glade and the "user tabs"/gmoccapy2.glade feature? How would I
connect a glade button to an mdi command for example? Any pointers to
knowledge would be great!
09 Jul 2014 12:44 #48573 by newbynobi
solved with 1.1.5.4
Norbert
09 Jul 2014 12:48 - 09 Jul 2014 12:49 #48574 by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
Yesterday I started LinuxCNC while the Y-axis was on the limit switch.
I got the error when trying to turn the machine on, and the jog buttons were grayed out. Now, that's normal.
But the 'override limits' button was also greyed out, and that's not normal.
I'm running a 2.7.0~pre RIP build which I checked out 1-2 weeks ago.
Last edit: 09 Jul 2014 12:49 by DaBit.
10 Jul 2014 13:51 #48610 by billykid
Hello Norbert,
I configured both the tool change with probe. and CamView.
everything works fine except the window that always displays change.ngc instead of the main programand spindle icon are gray.
anyway thanks for the great work of this interface.
best regards
Mauro
13 Jul 2014 19:21 #48734 by newbynobi
Hi Norbert,
In Gmoccapy, large g-code program is dynamically loaded into the window and scroll slider is impossible to estimate how much has already been done.
Is it possible to make indicator of the accomplished part of large g-code programm?
@verser,
I just pushed 1.1.5.6 to master and 2.6, including new hal pin:
gmoccapy.program.length = S32, OUT (total number of program lines)
gmoccapy.program.current-line =S32, OUT (current executed line)
gmoccapy.program.progress = FLOAT, OUT (progress in %)
Now you are able to make your custom panel just with one hal progress bar and connect the gmoccapy hal pin to the progress bar.
I did not include jet such a bar in standard GUI, because I do not know where to place it.
Norbert
13 Jul 2014 19:28 #48735 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I am busy testing the lathe screen and it is working real good now after the last changes that you did on the offset editor and MDI mode stuff.
I have a request please. Is it possible to have a indicator to show if we are in Radius or Diameter mode. Especially in the touch off screen. Sometimes some gcode program can pit the machine into another mode than what you usually operate in and then when you touch off you enter the wrong offset.
Regards
Marius
www.bluearccnc.com
15 Jul 2014 19:45 #48815 by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Hello norbert,
Update my LinuxCNC, but when trying to open my gmoccapy environment, the screen opens but closes it ejectute from the terminal and shows me the following, attachment.
thanks,
Jorge Viloria
Moderators: newbynobi, HansU
Time to create page: 2.520 seconds
