30 Aug 2014 19:01 #50523 by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Gmoccapy - A new screen for linuxcnc
The Ctrl+space trick is a good workaround but doesn't help running a touchscreen.
Pull up matchbox-keyboard? I just installed it last night specifically for this kind of thing. It's not perfect, but it seems perfectly useful to me.
30 Aug 2014 19:46 - 30 Aug 2014 19:50 #50528 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@sliptonic
OK I do know now, that you run linuxcnc 2.6.2 on Debian Wheezy on a 15 " Touch Screen, correct?
What resolution do you run?
The cutting off of the Gcode and the programm name, could be caused because you use to big font size in the standard settings of XFCE, could you check the settings please.
I do not know why the error message should appear, the messages you show, should only be displayed if you push the corresponding test button on the settings page.
And the should never be shortend or compressed like on your screen.I just tested with 25 messages and did not get the behavior you showed.
According to onboard, I allready took contakt to the development board and got some advices. At the moment you will be forced to build it from source. Chris uses the same keyboard with gscreen, so he proposed making a linuxcnc paket for it. Lets see how the others think about it.
May be some of you do like to check xvkbd, I hope it is a good replacement.
Norbert
Last edit: 30 Aug 2014 19:50 by newbynobi.
30 Aug 2014 21:11 #50535 by sliptonic
Replied by sliptonic on topic Gmoccapy - A new screen for linuxcnc
Correct. This is a Triview 15" touchscreen at 1024x768. The Wheezy install is stock except but I bumped down the default font from 11 to 10 point and it looks better. The clipped lines are fixed.
I pushed the test button to create those messages for the screenshot but they appear the same way on other errors. At this point, I can live with it. I'll try the other keyboard alternatives though.
Thanks everyone.
01 Sep 2014 18:40 #50585 by LAIR82
Replied by LAIR82 on topic Gmoccapy - A new screen for linuxcnc
In regards to the error messages, how do you configure your own messages? When running Gscreen, I was able to configure 20 or so error messages in the INI file, that would pop up in a dialog box center screen and depending on the type of message I could stop motion, estop the machine, etc but when I switched to gmoccapy I don't see any way to configure these. It is very handy to have these, and operators got used to them,
Rick
01 Sep 2014 22:44 #50606 by sliptonic
Maybe I can't. I'm testing more thoroughly now and getting strange behavior related to tool change. When I switch to the tool table, select a tool and click the button to change to the selected tool (not the M61 button) it returns to manual mode with all the jog and mode buttons greyed out. Clicking the machine off and on returns control. I never get the dialog box to change the tool.
If I run a program, it just hangs at a line like T3 M06 G43. Again, no dialog.
Thoughts?
01 Sep 2014 22:58 - 01 Sep 2014 22:59 #50607 by Zahnrad Kopf
Thoughts?
Aren't you missing something on that line?
Last edit: 01 Sep 2014 22:59 by Zahnrad Kopf.
01 Sep 2014 23:10 #50608 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
Thoughts?
No, that's fine. G43 defaults to the current tool.
My guess is that the system is waiting for the tool change. How is your tool-changer set up? It may be that you have none at all (not even the manual toolchange routine configured)
01 Sep 2014 23:25 #50609 by sliptonic
Sorry. I should have been more clear on that point. This is manual tool change.
Per the gmoccapy wiki I have these three lines in the gmoccapy_postgui.hal file
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
01 Sep 2014 23:40 #50610 by newbynobi
@Rick,
Let me see if i can implement that, as it isn't at the moment.
But only if you do the documentation on the WIKI:-)
@sliptonic,
Could you please post your config files?
Does the sim config gmoccapy.ini work like expected?
Norbert
01 Sep 2014 23:52 - 01 Sep 2014 23:53 #50611 by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
Thoughts?
Yes, I had that too. Snippet from my (postgui) HAL file:
# Use gmoccapy toolchanger..
The last line is what I added; LinuxCNC is indeed waiting until the tool is prepared but without above line (or more complex logic) that will never happen. This is not gmoccapy specific.
Last edit: 01 Sep 2014 23:53 by DaBit.
Moderators: newbynobi, HansU
Time to create page: 0.995 seconds
