12 years 1 month ago #50987 by newbynobi
@Anders,
I will take a look, i have been thinking about that feature allready, but missed to implement it. But you will be forced to do also some work, like Rick was:-)
What about if i ask you for the needed icon?
Or making a handbook with the wiki info, so we can include the Information in the 2.6 deb packets?
Or a new translation to have even more languages?
Or.....
I will not implement more features if i remain beeing a one man show:-):-)
@probamo
Please post screenshots of:
- start fullscreen
- start maximized
- start as Window with min possible size.
See the settings page for the different options.
I do beleave you have not realized the differences, as you mentioned the window decoration.
Norbert
12 years 1 month ago #50989 by cncbasher
probamo:
perhaps try opening the settings panel in gmoccapy and in main window , select start as window
and then change width & height values from 979 & 750 , then select start maximised
and see if changing these helps
12 years 1 month ago #51044 by probamo
Norb,
cncbasher,
I tried all possibility. No need for hidden panels any more :) . I run well with full screen, the icons at the bottom are fully visible. :silly:
Thank you,
12 years 1 month ago - 12 years 1 month ago #51156 by microsprintbuilder
I'm trying out this screen and like it. I have some mysteries numbers running threw the tool info area in the screen. can anyone tell me what I need to do where to look to get rid of them.
Last edit: 12 years 1 month ago by microsprintbuilder. Reason: photo didn't show
12 years 1 month ago #51157 by mariusl
Hi
Look in the INI file under the [TRAJ] section you will find and entry MAX_LINEAR_VELOCITY = xxx. Change that entry to MAX_VELOCITY = xxx
Regards
Marius
www.bluearccnc.com
The following user(s) said Thank You: microsprintbuilder
12 years 1 month ago #51158 by microsprintbuilder
That fixed it. Thanks!
Moderators: newbynobi, HansU
Time to create page: 0.225 seconds
