12 years 3 months ago #48933 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I tested in sim and it seems to be as you say (not that it would be else wise :) ). I did not notice that on my lathe though. The motor is burned out now so I cannot run it to test.
The scenario happens when I run some of the pyngngui stuff. Sometimes the program is in Radius mode and sometimes not ( i have added some programs already). I will have to test to see how it happens. I am hoping to have a new motor and VFD soon.
Regards
Marius
www.bluearccnc.com
12 years 3 months ago #49161 by verser
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: @verser,
I just pushed 1.1.5.6 to master and 2.6, including new hal pin:
gmoccapy.program.length = S32, OUT (total number of program lines)
gmoccapy.program.current-line =S32, OUT (current executed line)
gmoccapy.program.progress = FLOAT, OUT (progress in %)
Now you are able to make your custom panel just with one hal progress bar and connect the gmoccapy hal pin to the progress bar.
Norbert
Thanks!
12 years 2 months ago #49863 by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Gmoccapy - A new screen for linuxcnc
Guys,
I tried reading through the whole thread, but might have missed my answer.
Is there a screen in Gmoccapy that resembles this one yet?
That one is actually really very close to what I am desiring. Is there some location with many different Turning Center screens available right now, in LCNC?
Thank you.
12 years 2 months ago #49864 by mariusl
The Gmoccapy screen in lathe mode has all the functions that you need on a lathe. And very similar to the sample you gave. I am using the Gmoccapy lathe screen and it does very well and is very practical.
Try it.
If you want a screen just like that you will have to create it yourself :).
Regards
Marius
www.bluearccnc.com
12 years 2 months ago #49866 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Zahnradkopf,
This is gmoccapy for a front side lathe, there is a very big difference between the MACH3 Screen you show and the design of my GUI gmoccapy.
Gmoccapy is designed to be operated with a touch screen, not a mouse and most functions can be reached placing hardware button around the screen, so it simulates more or less a industrial CNC machine control.
For all details, I made a WIKI ,
you will find also information about customizing the layout in the WIKI. Feel free to contribute.
Norbert
12 years 2 months ago #49867 by mariusl
Of coarse you are right they are not the same. I meant to say similar in function. :blush: All the required functions to operate a lathe is on the Gmoccapy screen.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.353 seconds
