- mariusl
12 years 4 months ago #47991
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Ha ha, yes but I have done that already :laugh:
I am going to take a break for a number of days to do some resting and some fly fishing and when I get back the lathe must get finished as I have some work for it.
Next after that is the tool changer.
Regards
Marius
www.bluearccnc.com
- straga
12 years 4 months ago #48111
by straga
Replied by straga on topic Gmoccapy - A new screen for linuxcnc
Hello.
I am check last pre4. Ferror no more.
Gmoccapy - it same 1.5.3.
But now it work perfecly without error.
- verser
- Thank you received: 69
12 years 4 months ago - 12 years 4 months ago #48145
by verser
replace txt with rar
Unrar to ~/linuxcnc-dev/configs/sim/gmoccapy/
Add to [Display] section of ~/linuxcnc-dev/configs/sim/gmoccapy/gmoccapy-your-machine.ini
get here is
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
Meanwhile made such an indicator as an addendum to Gmoccapyverser wrote: Hi Norbert,
In Gmoccapy, large g-code program is dynamically loaded into the window and scroll slider is impossible to estimate how much has already been done.
Is it possible to make indicator of the accomplished part of large g-code programm?
EMBED_TAB_NAME = progress_g_code_panel
EMBED_TAB_LOCATION = box_custom_4
EMBED_TAB_COMMAND = gladevcp -x {XID} -u progress.py progress.glade
Last edit: 12 years 4 months ago by verser.
- verser
12 years 4 months ago #48146
by verser
had to use one timer, although it can be excluded, but then you have to make changes in gmoccapy.py ,
maybe Norbert will do it
- tuxcnc
- Thank you received: 56
12 years 4 months ago - 12 years 4 months ago #48187
by tuxcnc
Replied by tuxcnc on topic Gmoccapy - A new screen for linuxcnc
I got a confusing message :
It was after update LinuxCNC and I suspected error in new code.
I have spent few hours, before I found reason of this error.
Simply I wrote in ini file :
not :
Each typo ends with this error, I think it would be good to prevent it.
Regards.
File "/usr/lib/pymodules/python2.7/gmoccapy/widgets.py", line 42, in __getitem__
raise IndexError, "No widget %widget" % attr
ValueError: unsupported format character 'w' (0x77) at index 11
EMBED_TAB_LOCATION = ntb_user_tab
EMBED_TAB_LOCATION = ntb_user_tabs
Regards.
Last edit: 12 years 4 months ago by tuxcnc. Reason: correction
- DaBit
- Thank you received: 19
12 years 4 months ago #48188
by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
Small feature request, not that important: when I want to scroll through a loaded G-code program in the 'auto mode screen' I am stuck with the default tiny scroll-buttons. My touchscreen is not super-accurate, so these are a bit cumbersome to use.
Being able to scroll like we do on an Android phone (touch and drag) would be nice. But probably hard to implement I suppose?
Moderators: newbynobi, HansU
Time to create page: 0.583 seconds
