- Thank you received: 6
- DaOne
12 years 2 months ago #49981
by DaOne
Replied by DaOne on topic Gmoccapy - A new screen for linuxcnc
Also those screens above are old ones. There are many additions and fixes since those were taken. The IPS system only worked with the modules that were created. The screen itself is finished for the most part. Like I say I gave up when I had Mach3 freak out and make my lathe do wild things. Thankfully it was only a 1 HP hobby lathe and not the 30 HP version I was planning to retrofit with it. That lathe was converted with Linux CNC
I would love to have this working under LinuxCNC but the learning curve to implement was just way too much time at the time.
- Zahnrad Kopf
12 years 2 months ago #49982
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Gmoccapy - A new screen for linuxcnc
Man oh man, oh man, oh man...
THIS ought to be good. If Gmoccapy had these graphics with its layout as customizable as it is, and combined with the features of ncgui... woo...
We'd basically have the LinuxCNC equivalent ( possbily better? ) of Mazatrol...
I can't wait to see how this goes.
Thank you Wes for the offering and thank you Dave for the undertaking. If I can assist in some way, holler.
- newbynobi
- Thank you received: 394
12 years 2 months ago #50005
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@Dave,
if you need help, or just any kind of information regarding gmoccapy, do not hesitate to contact me.
I will be glad if I can give you a hand.
But first question to answer is: Should we go on with Glade in the actual version? It will not be supported any more in 12.04 as far as I know. Installing it under 12.04 is possible.
Glade vcp is based on an older Glade version than the default from 12.04.
@Marius,
thanks, I will change the names as soon as possible.
Norbert
@Marius,
Norbert
- Thank you received: 2181
12 years 2 months ago #50015
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
Norbert
I think you'll find that Gmoccapy will continue to work beyond 12.04 - you just won't be able to edit the glade file.
But you could edit it on an older system and the transfer it to the newer system.
I haven't tried this, but i'm pretty sure it's just the gtk2 glade editor they have dumped.
Chris M
Chris M
- cncbasher
- Thank you received: 202
12 years 2 months ago #50018
by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
well if glade is not going to be supported , then i think we need to seriously consider the options , or we are going to become bogged down
because of incompatibility's , now or in the future . same as or similar to what has happened the last few years with linuxcnc in general
better to make changes now , than another 2 years when everything is entrenched , and then something happens
QT4 Perhaps ?
QT4 Perhaps ?
12 years 2 months ago #50021
I believe Qt 4 is licence incompatible but QT5 is ok - this is what machinekit has basically gone to.
gladevcp needs to converted to gtk3 then the glade editor is useful again. (not a small adventure)
again,the existing glade panels / screens should work fine, one just can't edit them on the newest systems.
Chris M
Chris M
Moderators: newbynobi, HansU
Time to create page: 1.465 seconds
