gmoccapy 2.1.0 has been released
10 years 2 months ago - 10 years 2 months ago #79819 by tarasko
dinkata wrote: This does not work
wiki.linuxcnc.org/cgi-bin/wiki.pl?Gmocca...w_to_update_gmoccapy
It works! I used this instruction without any problem.
Last edit: 10 years 2 months ago by tarasko.
10 years 2 months ago #79824 by dinkata
tarasko wrote: It works! I used this instruction without any problem.
This ??
3. How to update gmoccapy
3.1. For users
Just do an update using your deb package tool like synaptic.
10 years 2 months ago - 10 years 2 months ago #79828 by tarasko
dinkata wrote: This ??
3.1. For users
Well as user you'll get new gmocappy 2.1.0 when linuxcnc 2.8.0 will be released. Current release version is 2.7.6 and it doesn't include new gmocappy. So as user you'll need to wait some time when linuxcncn 2.8.0 will be releaed (I don't know release schedule)
So you need to use 'For developers' way. Manually compile master branch and use compiled version of linuxcnc
The following user(s) said Thank You: dinkata
10 years 2 months ago - 10 years 2 months ago #79862 by newbynobi
I want to report a few bugs.
1. Spindle speed is reporting 0 when I'm running a g-code program with command 's12000 m3'
2. Transition from AUTO -> MDI doesn't work when I'm pressing F3 key after program finish.
To item 1: Did you connect the corresponding gmoccapy hal pin in your postgui hal file?
I understand you are referring to the feedback bar, or do you thing the active gcode?
I see, the label besides the 100 % button is not updated as expected, I will check that.
I have an idea, but no time actually, so please stay tuned;-)
To item 2: I checked that, after running a program, pressing F3 brings me back to manual, and pressing F5 to MDI mode, so here everything is fine.
Norbert
Last edit: 10 years 2 months ago by newbynobi.
10 years 2 months ago #79864 by newbynobi
@All
There is ctually no documentation for gmoccapy 2.1.0 !!!
And please do not use the WIKI, It is not up to date:
For 2.7.6 branch the documentation is here:
gmoccapy documentation for 2.7
Master is on this page:
gmoccapy documentation for master
but I have not updated the master stuff to be actual with gmoccapy 2.1.xx
If you use master branch, be aware, that that one is the developers branch, you should know how to compile stuff and how to fix small hal issues, as in that branch a change may happen changing names or complete behavior!!
If you want to use that please do:
sudo apt-get install git-core gitk git-gui git config --global user.name "Your full name" git config --global user.email "you@example.com" git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev sudo apt-get install libboost-python1.49-dev libmodbus-dev libusb-1.0-0-dev libxmu-dev libglu1-mesa-dev libgl1-mesa-dev libreadline-dev tcl8.5-dev tk8.5-dev cd linuxcnc-dev cd src ./autogen.sh ./configure make sudo make setuid cd .. . ./scripts/rip-environment linuxcnc
Norbert
10 years 2 months ago #79865 by tarasko
newbynobi wrote: To item 1: Did you connect the corresponding gmoccapy hal pin in your postgui hal file?
Well no. In gmocappy of linuxcnc 2.6.7 all works out of the box.
newbynobi wrote: I understand you are referring to the feedback bar, or do you thing the active gcode?
Feedback bar works properly when I manually increase/decrease spindle speed, but If I call
the MDI command like 's6000m3' feedback bar shows '0'
Moderators: newbynobi, HansU
Time to create page: 0.474 seconds
