- Thank you received: 3
gmoccapy 2.1.0 has been released
- tarasko
10 years 2 months ago - 10 years 2 months ago #79799
by tarasko
Replied by tarasko on topic gmoccapy 2.1.0 has been released
Strange. I used the same manual to compile linuxcnc from source and I got a newest version of Gmocappy.
How do you launch compiled linuxcnc?
Also you must ensure that you compile sources from the master branch
type next command in linuxcnc-dev directory:
$ git branch
You must see output:
* master
$ git branch
* master
Last edit: 10 years 2 months ago by tarasko.
- Dale Lusby
10 years 2 months ago #79800
by Dale Lusby
Replied by Dale Lusby on topic gmoccapy 2.1.0 has been released
Perhaps that's my issue. The wiki said type "LinuxCNC" and when i did from the directory Linxucnc-dev it launched the config picker. Otherwise I was looking in the Linxucnc-dev folder and don't see 2.1.0 version.
- Dale Lusby
10 years 2 months ago #79801
by Dale Lusby
Here's showing the master
- Dale Lusby
10 years 2 months ago - 10 years 2 months ago #79802
by Dale Lusby
Here is what may be issue I'm thinking. Would I just type the enable non distributable command that is in parentheses into the Linxucnc-dev directory?
Last edit: 10 years 2 months ago by Dale Lusby.
- dinkata
10 years 2 months ago - 10 years 2 months ago #79809
by dinkata
www.linuxcnc.org/linuxcnc-2.7-wheezy.iso
with update 2.7.6 . I use DISPLAY= gmoccapy
Please give instructions step by step how to update gmoccapy !
This does not work
wiki.linuxcnc.org/cgi-bin/wiki.pl?Gmocca...w_to_update_gmoccapy
Replied by dinkata on topic gmoccapy 2.1.0 has been released
I need help .I have installed :newbynobi wrote: If you need help, we are here!
Norbert
This does not work
Last edit: 10 years 2 months ago by dinkata.
- tarasko
10 years 2 months ago #79818
by tarasko
Well ok. You even didn't compile it correctly.
First you need to launch configure script with additional parameter as been sain in error message:
./configure --enable-non-distributable=yes
Then continue with compilation as instruction says.
After successful compilation you need to launch linuxcnc script:
~/linuxcnc-dev/scripts/linuxcnc ~/<some_location>/<your_configuration_ini_file>
Moderators: newbynobi, HansU
Time to create page: 1.759 seconds
