gmoccapy 2.1.0 has been released
10 years 2 months ago #79867 by newbynobi
Please check the hal connections, as some hal pin names has been renamed!
I just pushed the fix to update the label besides the 100 % spindle button.
Feedback bar should work, if you have the feedback pins connected.
Please test with sim config and report steps to reproduce the error.
Norbert
The following user(s) said Thank You: tarasko
10 years 2 months ago - 10 years 2 months ago #79877 by tarasko
I verified on latest master, all works like charm!
newbynobi wrote: Please check the hal connections, as some hal pin names has been renamed!
I didn't change any configuration files. Besides in my custom_postgui.hal file there are no any gmocappy pin connections
newbynobi wrote: Please test with sim config and report steps to reproduce the error.
Norbert
I verified on my real harware config.
Thanks.
Back to other little bug. "Shorctuts mode switching problem"
Reproduce steps:
1. Switch to the AUTO mode.
2. Switch to the MDI mode with 'F5' shortcut.
3. Switch back to the AUTO mode.
4. Switch againt to MDI mode with 'F5' ---> oops. It doesn't switch.
5. Switch to the MANUAL mode by F3.
6. goto step 1
Other little issue is labels on macro buttons, and their alignment.
As you can see on the attached picture. The macro names are not full.
full names are "1_measure_and_change", "2_tool_change", "3_tool_measure"
Last edit: 10 years 2 months ago by tarasko.
10 years 1 month ago - 10 years 1 month ago #79892 by dinkata
Well as user you'll get new gmocappy 2.1.0 when linuxcnc 2.8.0 will be released.
I update to 2.8 gmoccapy 2.1.2 a pleasant surprise ,
please note DRO axis Z remains in red after homing ..I use sim_hardware.hal .
Last edit: 10 years 1 month ago by dinkata.
10 years 1 month ago #79960 by newbynobi
Reproduce steps:
6. goto step 1
Fixed with 2.1.3
it was caused, because we do record the last key event, to avoid that a action is excecuted several times with one push of the button. Now the button push event reset the key event and so it does work fine.
I also corrected another bug, Pressing F3 or F5 while running a program leaded to a short time of no reaction of the GUI.
Now a error message will be trhrown.
Norbert
10 years 1 month ago #79961 by newbynobi
That is caused due to space reasons, I will check, if there is a possibility to line brake them automatically on the button.
Norbert
10 years 1 month ago #79962 by newbynobi
If the DRO does not get green, it is not homed. I am not able to reproduce that, because I do not know the content of sim_hardware.hal.
I am convinced, that the home switch of Z is not connected, or you did not home that joint.
Please try with configs/sim/gmoccapy/gmoccapy_lathe.ini
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.344 seconds
