- Thank you received: 394
Thanks, didn't notice your reply as it was an edit of of my post.racedirector wrote: Quick question.....will this version work with 2.7.8? Was going to download all the required files and do a re-make of the source to get V2+ if it does.
No!
It will not!
If you want to use v2+ with 2.7, you will need to change some code. The main difference is that I changed gmoccapy to support the new Joint/Axis changes from 2.8
If you just want to use the new slider Widgets, that can be done with a reasonable amount of gode modifications.
Because I do support at the moment 3 release versions (gmoccapy in 2.6, gmoccapy in 2.7 and gmoccapy in 2.I have not many time to make special wishes come True
I will announce very soon, that gmoccapy in 2.6 will not be supported any more, as users should update to 2.7
Norbert
