Gmoccapy Bug?
9 years 9 months ago - 9 years 9 months ago #85736 by newbynobi
Replied by newbynobi on topic Gmoccapy Bug?
I downloaded the file from github.com/LinuxCNC/linuxcnc now how do I install it?
Sorry I'm still very new to Linux.
Orson
build from source
For newbies it is much easier to use buildbot .
Norbert
Last edit: 9 years 9 months ago by newbynobi.
9 years 9 months ago - 9 years 9 months ago #85737 by timmert
Replied by timmert on topic Gmoccapy Bug?
newbynobi wrote:
I'm using the new Gmoccapy UI with the master release and came across a bug that happens each time.
I start Linuxcnc -> home all -> go to MDI -> if I home again the screen doesn't switch from the jog screen to MDI.
I need to completely restart LinuxCNC to get it working again.
I am not able to reproduce that. If I test with sim, I can home the machine, go to MDI, go back to manual and if I try to home again, I get the message, that the axis is on a limit switch, that is OK, because of simulated home switches.
I can jog all axis to negative values and press home all. All axis get homed and I can switch modes again.
So, what are you doing exactly?
Post the part of homing of you INI.
On my basement mill I can home as much times I like, also no error.
Norbert
See attachment.
This is a 2.7 config though. Because I just rolled back.
Last edit: 9 years 9 months ago by timmert.
9 years 9 months ago #85740 by newbynobi
Hallo Timmert,
please change you HOME = 0 to a smal value away from your home switches or give a HOME_OFFset value.
Otherwise your machine may still be on the mome switch after homing, leading to an error if you try to home again.
I use on my mill both (METRIC!!)
HOME = 10
HOME_OFFSET = -0,5
HOME_SEARCH_VEL = -25
HOME_LATCH_VEL = 3
What error do you get?
Norbert
9 years 9 months ago #85741 by timmert
Hi Norbert
My home offset is working fine never had problems.
I also don't get any error.
The problem is that after I home the machine I go to the MDI screen.
If I home again I can't switch between jog and MDI screen. I can click MDI, but the screen doesn't switch from the jog mode.
Homing is working fine.
9 years 9 months ago #85742 by newbynobi
OK,
What release number does the GUI show?
Please start from a terminal and watch for outputs.
I am not able to reproduce that, are you able to make a screen video?
I recommend "RecordMyDesktop" for that purpose.
Norbert
9 years 9 months ago #85743 by timmert
Ok will make a video
Moderators: newbynobi, HansU
Time to create page: 0.063 seconds
