Gmoccapy Bug?
9 years 9 months ago #85748 by thor44
Replied by thor44 on topic Gmoccapy Bug?
Norbert
I have not tested yet, I am still waiting for someone to help me install the update.
can you help?
9 years 9 months ago - 9 years 9 months ago #85755 by timmert
Replied by timmert on topic Gmoccapy Bug?
thor44 wrote: Norbert
can you help?
Follow linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
1.1 updating LinuxCNC
And add one of the master branch (depending on what you're using, Wheezy, Precise etc)
buildbot.linuxcnc.org/
The master = development
if you want to rollback:
Remove the master branch repository from the Synaptic Manager.
Remote LinuxCNC
Add the stable release
Reload
Install
Make sure to backup your config first
Last edit: 9 years 9 months ago by timmert.
9 years 9 months ago #85812 by timmert
newbynobi wrote: OK,
What release number does the GUI show?
Please start from a terminal and watch for outputs.
I am not able to reproduce that, are you able to make a screen video?
I recommend "RecordMyDesktop" for that purpose.
Norbert
I start the machine
1. home
2. enter MDI and enter a G30 (doesn't matter which command I enter)
3. home
4. MDI screen doesn't open, have to completely restart lcnc.
9 years 9 months ago - 9 years 9 months ago #85814 by newbynobi
Replied by newbynobi on topic Gmoccapy Bug?
OK, that is strange. I can see, that your system is not getting out of MDI mode, because of the terminal output.
I checked the code as much as possible, but could not find a solution. The only I did not test, is using gmoccapy together with hal-manual Toollchange.
So please do three tests and report:
1. go to settings page and uncheck reload tool on startup (advanced settings)
2. change from hal_manual toolchange to gmoccapy toolchange (you are using the axis one at the moment)
3. after leaving the MDI mode, before homing the second time, just push any of the jog button, does the machine jog?
And please post your complete config folder.
Norbert
Last edit: 9 years 9 months ago by newbynobi.
9 years 9 months ago - 9 years 9 months ago #85816 by timmert
Thanks for the quick reply.
1. Once I uncheck reload tool on startup. It works fine. But that was the reason I updated to the master haha.
2. Changed it to Gmoccapy tool changer. But doesn't solve it.
3. Machine jogs fine
I added my config
File Name: config.zip
File Size:8.31 KB
9 years 9 months ago #85823 by timmert
Editted my previous post
Tested and configured the gmoccapy tool changer, works.
But the 'reload tool' setting seems to be the problem.
MDI works fine when it's turned off.
Moderators: newbynobi, HansU
Time to create page: 0.294 seconds
