Gmoccapy Bug?
9 years 9 months ago #85619 by newbynobi
Replied by newbynobi on topic Gmoccapy Bug?
@racedirector,
could you test?
I need a result to update also the other releases.
Norbert
9 years 9 months ago #85679 by thor44
Replied by thor44 on topic Gmoccapy Bug?
I downloaded the file from github.com/LinuxCNC/linuxcnc now how do I install it?
Sorry I'm still very new to Linux.
Orson
9 years 9 months ago #85708 by timmert
Replied by timmert on topic Gmoccapy Bug?
I'm using the new Gmoccapy UI with the master release and came across a bug that happens each time.
I start Linuxcnc -> home all -> go to MDI -> if I home again the screen doesn't switch from the jog screen to MDI.
I need to completely restart LinuxCNC to get it working again.
9 years 9 months ago #85732 by racedirector
Replied by racedirector on topic Gmoccapy Bug?
newbynobi wrote: @racedirector,
could you test?
Norbert
Sorry Norbert
Too hot to go in the garage (46C) but got to update today. Did a git pull and ran the same code - no change other than maybe a little less distance.
9 years 9 months ago - 9 years 9 months ago #85734 by newbynobi
I am not able to reproduce that. If I test with sim, I can home the machine, go to MDI, go back to manual and if I try to home again, I get the message, that the axis is on a limit switch, that is OK, because of simulated home switches.
I can jog all axis to negative values and press home all. All axis get homed and I can switch modes again.
So, what are you doing exactly?
Post the part of homing of you INI.
On my basement mill I can home as much times I like, also no error.
Norbert
Last edit: 9 years 9 months ago by newbynobi.
9 years 9 months ago #85735 by newbynobi
Sorry Norbert
Could you send me your gcode? I have tested on different machines with different codes and I am not able to see so large movements. What release number does the GUI show? Should be 2.2.3 by now.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.765 seconds
