(SOLVED) BUG REPORT: Gmocappy Homing buttons in joint mode in Master
9 years 8 months ago #87645 by andypugh
rodw wrote: Andy, From what I can see, you absolutely can't home a joint axis other than with a home all.
This might be considered a feature... It does at least ensure that the tool is out of the way before moving the gantry.
It would be interesting to see what happens if you toggle the "halui.joint.N.home" input of both sides of the gantry at the same time. (whether it waits for each side to complete each stage as with home-all or whether it just individually-homes each side)
9 years 8 months ago #87649 by rodw
Yes, the "feature" never bothered me and I never even knew Axis had additional homing menu options until Norbert told me.
I have an associate who has run a lot of commercial profile cutters and his view of the geometry based on every machine he had ever operated was a bit different to mine. (He picked a different corner for home). As a result, I can see that I will need to add a "Park" button that moves the gantry to X max for loading etc so homing won't actually get things out of the road. Thats why I have a XXYZ machine and most people seem to have a XYYZ gantry machine.
I might have a go at your idea before I bolt things together. Perhaps Joint homing should check if it is part of a Joint axis and either do nothing or home it mates at the same time. Anyway, clearly, there is more work before axes and joints are truly independent of each other.
9 years 8 months ago #87664 by Todd Zuercher
The machine does not have to home to X0. I have a machine set up that homes the gantry to the back of the machine sets that position as 62" then parks at 61" (with 0 being at the front).
9 years 8 months ago #87686 by newbynobi
Hallo @all,
I think todw's way is the correct one. I will at first step introduce a check if any axis letters are double, if so I will set the corresponding button insensitive. I can not hide it, because hiding a button leads to place changes of the resting button and the order has to be the same if you use hardware button around the screen.
At second step, I will try to find a way to start homing of two joints at the same time. I will make that in a separate branch and will then need a very brave gantry user to test the changes, as I have no gantry. If that works, I will need to find a way to reorder the relations between joints and axis, to avoid homing the wrong joint/axis.
The better way would be to allow homing an axis and linuxcnc knowing the relation between axis and joints, but that is out of my skill.
And that could also cause a lot of problems on non trivial kinematics.
All the mentioned will only take place, on trivial kinematics (I count gantry as such).
Norbert
9 years 8 months ago - 9 years 8 months ago #87691 by bevins
newbynobi wrote: Hallo @all,
Norbert
This is closing the doors for people that might need to use the same axis letters on different joints that are not gantry related. I think a better option would be to provide a checkbox on settings screen called dual motor gantry then do whatever you need to do to disable the homing of the double drive letters.
My thoughts.....
Last edit: 9 years 8 months ago by bevins.
9 years 8 months ago #87701 by rodw
My thoughts.....
Maybe not. Perhaps my approach is a bit simplistic.If the detection code also referred to the HOME_SEQUENCE setting for each affected axis joint to see if it is negative (which is how a Joint Axis should be set up), then this should not affect the situation Bevins raises. I'm like Norbert, I simply don't know enough to be conclusive on this stuff given I only have half a LinuxCNC controlled machine under my belt
Moderators: newbynobi, HansU
Time to create page: 0.213 seconds
