(SOLVED) BUG REPORT: Gmocappy Homing buttons in joint mode in Master
9 years 8 months ago #88227 by tommylight
I do not know why, but the error relates to the same file you got the error in git, namely control.c
9 years 8 months ago #88231 by rodw
I worked it out. I think there was a network timeout when I checked out the new branch so the file file was corrupt. I did a hard reset of the master branch and started again. This time it worked.
So now I've got the axis offset branch installed, I've run the demo sims but I still don't really understand what it is trying to demonstrate. I did see that it applied offsets, but how could we use it?
Sorry about the dump questions, but I want to follow through on this all seeing I started it!
9 years 8 months ago - 9 years 8 months ago #88264 by newbynobi
@rodw,
I think you have pulled the wrong branch. The one related to the bug fixes with simultaneous JOINT homing is:
dgarr/per_seq_homing
That branch will home simultaneous all joints with the same negative value. So if you put in your INI File to a XYYZ config the home sequence value to both Y-Joints "-2" they will be tight together. So it does not matter, if you start homing the first or the second Y joint, LinuxCNC will take care to home both simultaneous.
You can watch that with halshow, watching the joints homing state.
Norbert
Last edit: 9 years 8 months ago by newbynobi.
9 years 8 months ago #88309 by rodw
Norbert, thanks but I want them both :)
I have to work out how to merge branches yet.
When I had a look at Dewey's source, it looked like he had incorporated you gmocappy revisions already. Anyway with the offset branch working, the homing buttons was disabled.
9 years 8 months ago #88311 by BigJohnT
Yea Dewey will merge that branch with master to keep it up to date with changes in master until he merges that branch back into master.
JT
9 years 8 months ago #88694 by newbynobi
@rodw,
the branch per_seq_homing has been merged to master.
Could you please test, if the changes of gmoccapy do fit your needs?
Norbert
Moderators: newbynobi, HansU
Time to create page: 2.060 seconds
