Z homed DRO red !
9 years 7 months ago #89647 by dinkata
Replied by dinkata on topic Z homed DRO red !
Hallo Norbert ,
I test config attached from you .In sim-hardware.hal also changed JOINT 1 to JOINT2 .
Z homed DRO already green , but another problem .
MDI open , but command line not active !!??
Auto - open program , but not run !!!??
9 years 7 months ago #89681 by newbynobi
Replied by newbynobi on topic Z homed DRO red !
Please check, if there are any more joints in the config. Easiest is to look in hal show for all joints and the homing status.
Post again your last sim config.
Here it is working.
Norbert
9 years 7 months ago - 9 years 7 months ago #89726 by dinkata
Hallo Norbert ,
Please check
there is no JOINT_1 !!
I now test config I did in PC with Linuxcnc 2.7.8 ( attached after open in PC with Linuxcnc 2.8 pre )
Opening sequence :
1.Copy folder config "test27" in folder configs in PC with Linuxcnc 2.8 pre
2.Menu Linuxcnc
YES
3.Error
Corection in sim_hardware.hal and ini :
DISPLAY = axis => DISPLAY = gmoccapy net Xjoint-pos-fb axis.0.joint-pos-fb sim-hardware.Xcurrent-pos => net xpos-fb sim-hardware.Xcurrent-pos [AXIS_0] => [JOINT_0] [AXIS_2] => [JOINT_2]
4.Start , press Home Z , press Home X
File Name: Test27open28.tar.gz
File Size:5 KB
Last edit: 9 years 7 months ago by dinkata.
9 years 7 months ago - 9 years 7 months ago #89727 by dinkata
P.S. After Homing button MDI and button Auto not active
after pres jog X or jog Z then buttons active , but :
I want to help improve gmoccapy . I can do tests on the real machine !
Now new config Linuxcnc 2.8 with Joint 0 and Joint 1 work normal on Lathe ,
only DRO Z is red after homing !
9 years 7 months ago #89770 by andypugh
Replied by andypugh on topic Z homed DRO red !
This is somewhat odd. The conversion script really should change that pin name.
github.com/LinuxCNC/linuxcnc/blob/master...ipts/update_ini#L366
Did the conversion script appear to run correctly?
The following user(s) said Thank You: dinkata
9 years 7 months ago #89799 by dinkata
andypugh wrote: This is somewhat odd. The conversion script really should change that pin name.
andypugh Excuse my incompetence , but how to do it ?
Please give a brief instruction !
Thanks .
Moderators: newbynobi, HansU
Time to create page: 0.167 seconds
