Z homed DRO red !
9 years 7 months ago #89807
It should all have been automatic.
I will try to remember to test the script with the old config tonight.
Replied by andypugh on topic Z homed DRO red !
dinkata wrote: Excuse my incompetence , but how to do it ?
- newbynobi
- Thank you received: 394
9 years 7 months ago #90385
by newbynobi
Replied by newbynobi on topic Z homed DRO red !
Hallo @all,
I am working on the solution, but it is more work than I thought, because I do not want to destroy the compatibility to older configs.
There is a work around for the mentioned problem.
Add for all unused joints lines like so:
I will inform, as soon as I got the solution finished.
But I will need another while.
Norbert
[JOINT_1]
HOME_SEQUENCE = 0
Norbert
The following user(s) said Thank You: dinkata
- newbynobi
9 years 6 months ago - 9 years 6 months ago #90766
by newbynobi
I just pushed gmoccapy 2.3.0
That release has much better support for the new joint axis stuff. So now a two joints lathe config is possible.
And all the new homing stuff for gantry is also implemented. A negative homing sequence will home both joints simultaneous.
Please see:
updating linuxcnc
and man trivkins
to update your configs.
I updated all sim configs for gmoccapy. Most old configs should work with no changes needed.
If you find any problem, please let me know, as I could only test on simulation.
Norbert
Please see:
updating linuxcnc
and man trivkins
Norbert
Last edit: 9 years 6 months ago by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 0.310 seconds
