Z homed DRO red !
9 years 7 months ago #89508 by dinkata
Replied by dinkata on topic Z homed DRO red !
ini :
[KINS]
JOINTS = 2
KINEMATICS = trivkins coordinates=XZ
9 years 7 months ago #89554 by newbynobi
Replied by newbynobi on topic Z homed DRO red !
I am on my fone, but without looking in your config i do know, you are using a corrupt config.
A lathe is a identity kinematics, so you need 3 joints, X being joint 0 and Z being joint 2.
Joint 1 is unused and does not need to be in your ini file.
Change joints to 3 and rename your joint 1 to joint 2.
After that the dro problem should be gone.
Norbert
9 years 7 months ago - 9 years 7 months ago #89569 by dinkata
Hello Norbert , thanks for the reply !
I did this,but there is another problem .This is config real machine :
ini:
Warning: Spoiler!
hal
Warning: Spoiler!
In this configuration, when pressed the button -X or +X normal move
but when pressed the button -Z or +Z joint.2.vel-cmd =0 joint.1.vel-cmd = 3
[ jog speed = 180mm/min ( and another problem show sometimes inch/min ) ]
joint.1 error !!!!!!??????
Last edit: 9 years 7 months ago by dinkata.
9 years 7 months ago #89614 by andypugh
Replied by andypugh on topic Z homed DRO red !
dinkata wrote: ini :
[KINS]
JOINTS = 2
I have my lathe set up as 2 joints and use the 2.8 version of LinuxCNC.
I use the Touchy GUI and have noticed that I don't get a "homed" indicator in the GUI for the Z axis.
This looks like exactly the same problem. (Except it isn't really a problem for me, and I have ignored it).
I will try some experiments tonight to see if I can see the problem.
The following user(s) said Thank You: dinkata
9 years 7 months ago - 9 years 7 months ago #89625 by newbynobi
Hallo dinkata,
I just corrected your config, please find it attached.
I think you missed to change also your hal file ;-)
Norbert
P.S. This is at the moment a gmoccapy "feature / bug" I will work on this ASAP.
Last edit: 9 years 7 months ago by newbynobi.
9 years 7 months ago #89630 by andypugh
I think a simple solution for the OP is probably to alter their version of gmoccapy.glade (with a text editor) so that Z has joint number 1.
github.com/LinuxCNC/linuxcnc/blob/master...gmoccapy.glade#L1164
That might correct the colour but show the wrong numbers, though.
Moderators: newbynobi, HansU
Time to create page: 0.605 seconds
