Spindel problems in Gmoccapy
9 years 6 months ago - 9 years 6 months ago #92327 by newbynobi
Replied by newbynobi on topic Spindel problems in Gmoccapy
I have tried to get your hal file OK.
So first I splitted it up. So in your INI you must load two hal files and one postgui hal file. Please find the modified files attached.
I did that, because this way it is easier to maintain and debug and correct.
I would recommend to split it even more so that you have one file for each part of your machine.
Please see also, that I did a little formating.
Also included the gmoccapy tool change and the tool offset connections.
Norbert
P.S. you must rename the files to fit your needs.
Last edit: 9 years 6 months ago by newbynobi.
9 years 6 months ago #92335 by tecno
Replied by tecno on topic Spindel problems in Gmoccapy
Thank you for the cleanup = much appreciated!
Still the problem remains = no real rpm shown.
Also M3/M4. Lathe front tooling spindle rotation shown as negative.
9 years 6 months ago - 9 years 6 months ago #92343 by newbynobi
Hallo,
OK we seem to get a signal, but he feedbackbar can only show positive values, so I added a abs component.
Please replace spindle.hal with the new attached one and report.
Norbert
9 years 6 months ago #92350 by tecno
Still same problem that is nothing on spindle feedback bar or LED
Bengt
9 years 6 months ago #92353 by newbynobi
Please use Halshow and inform, about the results of all pin related to encoder.0
Norbert
9 years 6 months ago #92354 by tecno
Will go down to shop and you will have report shortly.
Bengt
Moderators: newbynobi, HansU
Time to create page: 0.154 seconds
