Spindel problems in Gmoccapy
9 years 6 months ago #92466
Replied by andypugh on topic Spindel problems in Gmoccapy
No, only the files specified in the INI are used.
But you have two files, and you are only referencing one in the INI, the other is commented out.
(And I am not sure that it is possible to call more than one postgui file).
It might be that the right file is being called, but that it has an error so drops out before the critical line. (but the "halmeter" line seems to have disproven that theory.)
Which of your two postgui files contains the net command for the spindle speed bar? (I am sure I have asked this before)
- tecno
- Thank you received: 127
9 years 6 months ago #92467
by tecno
Replied by tecno on topic Spindel problems in Gmoccapy
postgui.hal
- tecno
9 years 6 months ago #92468
by tecno
moved unused files, still no go
- tecno
9 years 6 months ago #92469
by tecno
9 years 6 months ago #92473
You need "halcmd" before the HAL commands.
Close LinuxCNC, then re-start it with the "linuxcnc" command from the terminal. We should be able to see what the error is.
- tecno
9 years 6 months ago #92474
by tecno
oops... halcmd
Will do this tomorrow starting linuxcnc from terminal.
Now I have pain in my leg so I have to rest.
cheers
Bengt
cheers
Bengt
Moderators: newbynobi, HansU
Time to create page: 0.655 seconds
