- Thank you received: 127
Spindel problems in Gmoccapy
- tecno
9 years 6 months ago - 9 years 6 months ago #92445
by tecno
Replied by tecno on topic Spindel problems in Gmoccapy
Halmeter shows
0 on bar and False on LED
INI
[DISPLAY]
#DISPLAY = axis
DISPLAY = gmoccapy
POSTGUI_HALFILE = postgui.hal
#POSTGUI_HALFILE = custom_postgui.hal
HALFILE = base.hal
HALFILE = spindle.hal
INI
[DISPLAY]
#DISPLAY = axis
DISPLAY = gmoccapy
HALFILE = base.hal
Last edit: 9 years 6 months ago by tecno.
9 years 6 months ago #92448
Replied by andypugh on topic Spindel problems in Gmoccapy
Which HAL file makes the connections to the spindle speed bar?
- tecno
9 years 6 months ago #92449
by tecno
Spindle.hal to postgui.hal
postgui
# link to gmoccapy toolchange, so you get the advantage of tool description on change dialog
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
net tooloffset-x gmoccapy.tooloffset-x <= motion.tooloffset.x
net tooloffset-z gmoccapy.tooloffset-z <= motion.tooloffset.z
net spindle-rpm gmoccapy.spindle_feedback_bar
net spindle-at-speed gmoccapy.spindle_at_speed_led
from spindle.hal
# spindle.hal
# holds all stuff related to the spindle control
# First load all needed rel time components
loadrt encoder num_chan=1
loadrt scale count=1
loadrt near count=1
loadrt abs count=1
# Next add them to a thread so they are updated periodicaly
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
addf scale.0 servo-thread
addf near.0 servo-thread
addf abs.0 servo-thread
# Set initial pin values if needed
# position scale =
# The scaling for position feedback, position command, and velocity command, in steps per length unit.
# IMHO should be 1.0
setp stepgen.2.position-scale 0.9
setp stepgen.2.steplen 5000
setp stepgen.2.stepspace 5000
setp stepgen.2.maxaccel 5000
setp scale.0.gain 60
setp encoder.0.position-scale 1
setp encoder.0.counter-mode 1
# make needed connections to hardware
net spindle-step stepgen.2.step => parport.0.pin-06-out
net spindle-dir stepgen.2.dir => parport.0.pin-07-out
net spindle-signal parport.0.pin-10-in => encoder.0.phase-Z
net spindle-signal encoder.0.phase-A
# internal hal connections
net spindle-index-enable motion.spindle-index-enable <=> encoder.0.index-enable
# encoder velocity is in units per seconds
# we use scale to get it in units per minutes
# in postgui.hal we connect the signal spindle-rpm to the gmoccapy pin
net spindle-rps encoder.0.velocity => scale.0.in
net spindle-rps motion.spindle-speed-in
net spindle-rpm-not_abs abs.0.in <= scale.0.out
net spindle-rpm abs.0.out
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-enable motion.spindle-on => stepgen.2.enable
net spindle-cmd-rpm stepgen.2.velocity-cmd <= motion.spindle-speed-out
#Spindle at speed ?
setp near.0.scale 1.2
setp near.0.difference 10
net spindle-comanded near.0.in1
net spindle-rev_per_min near.0.in2
net spindle-at-speed near.0.out => motion.spindle-at-speed
postgui
from spindle.hal
# spindle.hal
loadrt near count=1
loadrt abs count=1
# position scale =
#Spindle at speed ?
9 years 6 months ago #92455
Are you sure of the file names?
Does anything else in postgui.hal seem to work?
If you open a terminal window while LinuxCNC is running and use the command
Does the speed display start to work?
halcmd net spindle-rpm gmoccapy.spindle_feedback_bar
- tecno
9 years 6 months ago #92456
by tecno
The other parts in postgui was added by Norbert for future use I suppose.
Will go down to shop and see if there is a way to open terminal i gmocccapy and try
- tecno
9 years 6 months ago #92457
by tecno
No there is not any way to open terminal
Moderators: newbynobi, HansU
Time to create page: 0.733 seconds
