Spindel problems in Gmoccapy
9 years 6 months ago #92356 by tecno
Replied by tecno on topic Spindel problems in Gmoccapy
I hope I understood what you wanted to see thas pin 10
If not please tell me, remember I am new to this!
Bengt
9 years 6 months ago #92357 by tecno
Z and A flickers
Bengt
9 years 6 months ago #92358 by tommylight
Replied by tommylight on topic Spindel problems in Gmoccapy
newbynobi wrote: Please use Halshow and inform, about the results of all pin related to encoder.0
Norbert
On the left tree view there is encoder under pins, find there encoder.0 and show what is going on while working.
9 years 6 months ago #92359 by tecno
9 years 6 months ago #92400 by andypugh
Replied by andypugh on topic Spindel problems in Gmoccapy
encoder.0.velocity is showing a value (equivalent to 213 rpm) so it is something wrong in HAL, we can be certain.
You can follow the trail (encoder.0.velocity is shown going to the spindle-rps signal) and see where it breaks.
Probably a component that is not added to a thread, or possibly a hyphen/dash confusion in a signal name somewhere.
9 years 6 months ago #92411 by tecno
Just to get clear that I understand this.
Velocity is commanded to 200rpm and you read encoder.0.phase-Z to 213rpm, is this correct?
If so remember there is this LM circuitry converting steps to V that can be off and not tuned in.
If not = I am lost here and can not wrap my head around this.
"You can follow" Do you say that I need to use Halscope and look at the signal flow?
Is it this you want me to follow, I can sure try.
net spindle-rps encoder.0.velocity => scale.0.in
net spindle-rps motion.spindle-speed-in
net spindle-rpm-not_abs abs.0.in <= scale.0.out
net spindle-rpm abs.0.out
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-enable motion.spindle-on => stepgen.2.enable
net spindle-cmd-rpm stepgen.2.velocity-cmd <= motion.spindle-speed-out
net spindle-comanded near.0.in1
net spindle-rev_per_min near.0.in2
net spindle-at-speed near.0.out => motion.spindle-at-speed
Cheers
Bengt
Moderators: newbynobi, HansU
Time to create page: 0.224 seconds
