Probing setup
- tecno
- Thank you received: 127
21 Apr 2019 11:52 #131387
by tecno
Probing setup was created by tecno
This is what I have in HAL and I want to keep it that way = having separate inputs for the probes.
What is needed to have this working with 2 probes on separate inputs. 2.7.14 here.
Cheers
Bengt
# external input signals
# --- TS27R contact tool setting probe ---
net probe1-in <= hm2_7i76e.0.7i76.0.0.input-04
# --- MP10 probe system ---
net probe2-in <= hm2_7i76e.0.7i76.0.0.input-06What is needed to have this working with 2 probes on separate inputs. 2.7.14 here.
Cheers
Bengt
- islander261
- Thank you received: 216
21 Apr 2019 17:55 #131412
by islander261
Replied by islander261 on topic Probing setup
Bengt
I'm not sure what you are trying to do. For my old plasma system I just connected the two probe sources together with an OR2 component and polled the inputs to see which one was active. The other way to do it is to use a mux_generic component and only connect the source you are interested in to the motion.probe-input.
- tecno
21 Apr 2019 18:29 #131415
by tecno
Replied by tecno on topic Probing setup
John,
mux is the way to go. Worst case for me is when I need to measure the MP10 for length on the TS27R as they are close in force.
But how do one do the *choose* of probe in Gmoccapy?
/Bengt
/Bengt
- islander261
21 Apr 2019 18:56 #131418
by islander261
Bengt
You will need to make a custom button on the GUI and make the connections in your .hal file. Carefully read all the Gmoccapy docs and wikis. I actually built custom tabs that go behind the preview screen for some of my plasma stuff and replaced parts on the main GUI. I have seem discussions on adding custom buttons to both the right side and bottom of the main UI. I have only actually made whole GladeVCP panels so I haven't just added a button. There are others here who know much more about this than I do, maybe Norbert will chime in on where to find instructions. Actually studying any documentation on GladeVCPs will not hurt as that is how UI will be edited. You may get lucky and find an example built by someone else.
- tecno
21 Apr 2019 19:21 #131421
by tecno
Easier said than done it is making buttons
Hoping Norbert to chime in.
- newbynobi
- Thank you received: 394
21 Apr 2019 20:24 #131422
by newbynobi
Replied by newbynobi on topic Probing setup
The easiest way is to build a glade panel using the glade editor and add to that one the hal button yiu need, imho just two radiobutton will do the job.
Done the panel just embed it at the place you like, allowed locations are explained in the gmoccapy documentation. Please take care to make the hal connections to the custom panel in a separate hal file and load that hal file with the embedding command!!
You can look at the sim configs of gmoccapy for examples, as i did add some panels with sim configs.
Last not least, report success!
Norbert
Norbert
- Thank you received: 4152
22 Apr 2019 05:13 #131454
Replied by rodw on topic Probing setup
Well, you could set up a physical switch on an input and attach that to your mux select pin... in Hal.
- tecno
30 Apr 2019 14:54 #132355
by tecno
Done some testing today and there is some more force to trig the probe compared to tool probe so these two will share same input.
- tecno
30 Apr 2019 18:04 #132363
by tecno
So far so good, appears to be functioning so now time to RTFM.
- Thank you received: 7490
05 May 2019 01:22 #132789
Replied by tommylight on topic Probing setup
Nice, glad it's going to your liking.
Moderators: newbynobi, HansU
Time to create page: 0.142 seconds
