Probing setup
- newbynobi
- Thank you received: 394
07 May 2019 20:35 #133090
by newbynobi
Replied by newbynobi on topic Probing setup
In your ini file you have remaped the M6 command to a file manual_change, that file is not published, so no help possible?
Sorry
Sorry
- tecno
- Thank you received: 127
07 May 2019 21:07 - 08 May 2019 05:36 #133095
by tecno
Replied by tecno on topic Probing setup
So what file is missing, I just did the install as I understood the instructions.
This line?
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
So is it so that the ngc file has to be edited?
github.com/verser-git/probe_screen_v2/tree/master/macros
I am still on 2.7.14
This line?
Last edit: 08 May 2019 05:36 by tecno. Reason: added text
- newbynobi
08 May 2019 08:38 - 08 May 2019 08:40 #133116
by newbynobi
Just comment out the remap line and try again.
Does the tool change work? If yes, we know it is within remap.
And please!
For all testing start LinuxCNC from terminal and whatch the output, i am sure the output will show what is missing or wrong
Norbert
And please!
Norbert
Last edit: 08 May 2019 08:40 by newbynobi.
- newbynobi
08 May 2019 17:09 #133172
by newbynobi
There seems to be something wrong with onboard, what have you changed?
- tecno
08 May 2019 17:11 - 08 May 2019 17:40 #133173
by tecno
Onboard?
One board?
forum.linuxcnc.org/27-driver-boards/3642...i76e?start=40#132461
I did get help from Peter with a new BIT file as I want to add a secondary spindle.
So there is a BOB added to my 7i76e
One board?
Last edit: 08 May 2019 17:40 by tecno. Reason: added text
- newbynobi
08 May 2019 17:45 #133177
by newbynobi
gmoccapy is trying to load onboard keyboard but gets an error from that component.
You will need to try with the less possible hal files and add than one by one. So you can check the reall error.
Norbert
Norbert
- tecno
08 May 2019 18:15 #133178
by tecno
That error has been there from day 1 when I installed gmoccapy and I do not know where to start finding this.
- pl7i92
- Thank you received: 358
08 May 2019 18:47 - 08 May 2019 18:49 #133181
by pl7i92
Replied by pl7i92 on topic Probing setup
did you check if
**** No virtual keyboard installed, we checked for <onboard> and <matchbox-keyboard>.
**** GMOCCAPY INFO ****
**** No gmoccapy2.glade file present ****
You need to install Matchbox or Onboard keyboard separately
Last edit: 08 May 2019 18:49 by pl7i92.
- tecno
08 May 2019 18:49 #133182
by tecno
There is another *error* since day 1
I do not know where to find what is missing.
- newbynobi
08 May 2019 20:08 #133185
by newbynobi
As i told earlier,
commend out all hal file and all embedded tabs, just leave the main hal file where you load the driver for your card activated and start from terminal, check for the output!
If that minimal config does start, activate the next hal file and check again.
Go on till the config does not start any more and then post the complete output of the terminal with your complete config folder.
Without that testing from your side and without very more detailed output, am am not willing to help, as it is like whatching in my glass ball.
And as i am completely convinced that this has nothing to do with gmoccapy, i strongly recommend to move the futher discussion in its own thread as a probe screen problem or advanced hal configuration.
Norbert
Norbert
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.105 seconds
