Probing setup
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 May 2019 20:22 #133186 by tecno
Replied by tecno on topic Probing setup
Will do this tomorrow, also do a Axis + probe setup just to verify where the issues are.
When you say comment out all hal and embedded tabs is this the files related to probe screen only?
08 May 2019 20:36 #133188 by newbynobi
Replied by newbynobi on topic Probing setup
No, all ones!
I do recommend to split this huge hal files in separate files.
I have a main.hal file, where i just load the rt components and add that ones to the servo thread. This file also contains the axis joint setup, but nothing else.
Second file would be all stuff related to homing.
Third is spindle stuff.
If that does work i have a working machine!
Next would be cooling, next doors, next vacuum, next .....
Also my postgui.hal is a postgui.call list file whitch calls relevant postgui stuff in separate small files, as one for the tool offsets connections to gmoccapy, one for spindle feedback to gmoccapy one for the toolchange dialog etc.
The advantage of doing that way is the easier way to find errors, as you can disable part by part and running configurations etc. Coolant or spindle can just be transfered to hew configs. I bild my configs today just by copy files to bew folders, edit then to fit the new hal pin names and i am done.
Norbert
  • tecno
  • Platinum Member
  • Platinum Member
08 May 2019 20:50 #133193 by tecno
Was für eine Aufgabe, das zu klären
I do not understand how to connect / implement these hal files
But I understand what you say just hard to wrap this around my head.
08 May 2019 21:03 #133196 by newbynobi
Just split the files as you need them, save every file in your config folder and load each file with an entry in the ini file.
Read documentation about ini configuration.
Das wird schon alles, ist halt ein wenig Fleisarbeit und Lernen angesagt?
  • tecno
  • Platinum Member
  • Platinum Member
11 May 2019 15:32 #133453 by tecno
I have found the tool change issue, here in ini
HAL]
HALUI = halui
HALFILE = GB_3speed.hal
HALFILE = mpg.hal
POSTGUI_HALFILE = custom_postgui.hal
Here was the error = NO TOOLCHANGE
# Include your custom_postgui HAL commands here
# This file will not be overwritten when you run PNCconf again
net spindle-vel-cmd-rpm-abs   => gmoccapy.spindle_feedback_bar
# net hm2_7i76e.0.7i76.0.0.spinout    => gmoccapy.spindle_feedback_bar
The Tool change was in postgui.hal
#        gmoccapy_postgui.hal file from Norbert Schechner         #
#                        spindle stuff                            #
net   tool-change        gmoccapy.toolchange-change   <=  iocontrol.0.tool-change
net   tool-changed       gmoccapy.toolchange-changed  <=  iocontrol.0.tool-changed
net   tool-prep-number   gmoccapy.toolchange-number   <=  iocontrol.0.tool-prep-number
net   tool-prep-loop     iocontrol.0.tool-prepare     =>  iocontrol.0.tool-prepared
net   tooloffset-x       gmoccapy.tooloffset-x        <=  motion.tooloffset.x
net   tooloffset-z       gmoccapy.tooloffset-z        <=  motion.tooloffset.z
net tool-prep-loop         iocontrol.0.tool-prepare      <=   iocontrol.0.tool-prepared
Now INI is edited
[HAL]
HALUI = halui
HALFILE = mpg.hal
POSTGUI_HALFILE = postgui.hal
And this is postgui.hal now
#                        spindle stuff                            #
# net spindle-vel-cmd-rpm-abs   => gmoccapy.spindle_feedback_bar
So now tool change is working, but still some issues to be solved, some gmoccapy related and other are probe screen related.
**** GMOCCAPY GETINIINFO ****
Preference file path: gmoccapy_preferences
**** GMOCCAPY INFO ****
**** No gmoccapy2.glade file present ****
**** audio available! ****
**** virtual keyboard program found : <onboard>
**** probe_screen GETINIINFO ****
**** PROBE SCREEN INFO ****
**** To many increments given in INI File for this screen ****
**** Only the first 5 will be reachable through this screen ****
**** no valid probe config in INI File ****
**** disabled auto tool measurement ****
toolnumber = 0 False
**** replaced btn_zero_g92 to btn_block_height ****
**** GMOCCAPY INFO: Gcode.lang found ****
(gmoccapy:4579): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
**** GMOCCAPY INFO : inifile = /home/bengt/linuxcnc/configs/GB_3speed/GB_3speed.ini ****:
**** GMOCCAPY INFO : postgui halfile = postgui.hal ****:
(onboard:4592): Gdk-CRITICAL **: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
Emit interp-run
Emit interp-run
1 2
Emit interp-run
task: main loop took 0.149095 seconds
estopping / killing gmoccapy
  • tecno
  • Platinum Member
  • Platinum Member
12 May 2019 11:23 - 12 May 2019 11:26 #133549 by tecno
Now I have copied the gmoccapy2.glade file from github I get even more errors.
File Name: 20191205_d...5-12.txt
File Size:8 KB
Last edit: 12 May 2019 11:26 by tecno.
12 May 2019 19:38 #133590 by newbynobi
Please read first, prior to copy files arround.
If you do not need gmoccaly screen 2 you do not need to install that file. If you need it, please build your own screen2. If you do not know howto build a glade screen, you do not need screen2!
In the prior post, there is no relevant gmoccapy error, you can igniore the gtk sourceview and the onboard errors.
Screen has started according to the output you posted.
So what is the problem? Please read hal documentation, as all mentioned till today was only missconfigured hal files.
Norbert
Norbert
  • tecno
  • Platinum Member
  • Platinum Member
12 May 2019 20:00 #133593 by tecno
Norbert, do not get me wrong here but why is it that all these *error* message pop up if one just can ignore these? No I do not need screen2 as far as i know. So why is it that the error messages are there if no need for them? Same goes for the Gtk messages, something must be wrong don't you agree?
Not so easy for a beginner to wrap all this mystery around one's head with errors here and there.
Cheers
Bengt
12 May 2019 20:11 - 12 May 2019 20:15 #133596 by newbynobi
It is not easy!
The errors i mentioned are not from gmoccapy and have been there for about 5 years, i agree that they are missleading, that is why i mentioned you can ignore them.
I do not see more errors, just a lot of informations!
Probe screen does tell you, that you do not have a valid probe configuration in your ini file!
Norbert
Last edit: 12 May 2019 20:15 by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 0.290 seconds
