Back or front tool
01 Nov 2021 12:38 #224871 by andypugh
Replied by andypugh on topic Back or front tool
linuxcnc.org/docs/2.8/html/man/man9/moti....html#SPINDLE%20PINS
spindle.0.reverse - TRUE when the spindle should rotate backward
01 Nov 2021 13:26 #224876 by john11668
Replied by john11668 on topic Back or front tool
Fine but is that all that i need to add to my hal .
Somehow I suspect not
Please remember Andy that I am a novice here
My Hal was generated by initially by stepconfig and although I have progressively added a number of functions I have not needed to alter the spindle commands so i am floundering here !
01 Nov 2021 13:29 #224878 by andypugh
Which output pin (if any) is connected to your reversing relay?
Is it safe to reverse with the spindle on?
01 Nov 2021 13:38 - 01 Nov 2021 13:39 #224879 by john11668
Was planning for 14 or 16 unless you advise otherwise
Would not be safe to call for M4 if spindle running under M3 and Vice versa .
Was planning to call for a pause but if that can automated then all the better
Last edit: 01 Nov 2021 13:39 by john11668.
01 Nov 2021 19:51 #224909 by rider-83
Replied by rider-83 on topic Back or front tool
I hope you find this use full.
I'm using a servo motor for my spindle as the original DC motor was failing.
I have a dual 5v relay board from Ebay for around £4 for the control switching of the spindle.
The servo drive requires:
- Spindle enable
- Analogue 0-10v for its speed control, therfore:
Spindle Enable (Relay)
setp parport.0.pin-16-out-invert 1
net spindle-on => parport.0.pin-16-out
Spindle Direction (Relay)
net spindle-cw => parport.0.pin-17-out
Pin 17 output is connected to a small 5v relay wired normally open in series to the Polarity Reversing Modual
When CW is required, then 5v relay energises the Polarity Modual and +10v swaps to -10v for example.
www.modellingelectronics.co.uk/products/...arity-switch-module/
01 Nov 2021 21:22 #224919 by john11668
Not sure this fits my need s Ride
My pin 17 switches on the spindle and speed increase via the 0-10 v dc analogue output increases the speed .
I dont think I can change this to minus 10v .
My reversing relay simply reverses polarityat my DC motor which can be plus 170v to run forward and up to minus 170v to run backwards
01 Nov 2021 22:49 #224928 by andypugh
If you absolutely must not reverse the motor when it is running then that can be achieved with HAL trickery, but it would require that there be a spindle encoder so that the system can know that the spindle is stopped or moving.
But, the logic shown by rider-83 should work for you anyway, in that a parport pin will be set high in reverse. What happens in the hardware past that point is up to you.
02 Nov 2021 00:10 #224941 by john11668
Will try this and report back
02 Nov 2021 16:11 #225006 by john11668
So the following is a c/p from my Hal
setp parport.0.pin-01-out-invert 1
net spindle-pwm => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net xdir => parport.0.pin-03-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net spindle-on => parport.0.pin-17-out
net spindle-cw => parport.0.pin-16-out
I seem to need this format for my spindle to start and for me to have speed control
I am looking for pin 16 to operate my reversing relay
i do not see this as different from yours rider-83 except I have transposed 16 and 17 unless I am missing something
I am not getting any error messages But my reversing relay is not being operated
Is there anything wrong with the above
  • Moderator
  • Moderator
02 Nov 2021 17:29 #225020 by tommylight
Replied by tommylight on topic Back or front tool
Try:
net spindle-ccw => parport.0.pin-16-out
Moderators: newbynobi, HansU
Time to create page: 0.249 seconds
