Duplicate settings in Pref File
19 Jun 2024 08:13 #303334 by cmorley
Replied by cmorley on topic Duplicate settings in Pref File
Are you using any embedded programs?
If you erase the entry does it come back?
You must only hand edit preferences when Gmoccapy is not running.
The ones with a capital letter on the end word are from Gmoccapy:
system_name_G54 = G54
It seems the system entries preferences are checked at initialization and when the offsets tab is closed.
19 Jun 2024 11:59 #303348 by neerajbagi
Replied by neerajbagi on topic Duplicate settings in Pref File
No. Not using any embedded programs.
Yes. After erasing the duplicate entry, it comes back only after shutting down Linuxcnc.
I am editing the preference file only when Gmoccapy isn't running.
And the occurrence of this is very very random. At times, the duplication doesn't happen.
19 Jun 2024 17:30 #303369 by cmorley
What version of linuxcnc are you using and can you post your INI file?
19 Jun 2024 19:08 - 19 Jun 2024 19:08 #303377 by neerajbagi
Using Linuxcnc 2.9.2. I am attaching the INI.
I have another system that runs on Linuxcnc 2.8.4, and it hasn't encountered this issue even once. Not sure if I am doing something wrong on the previous system.
File Name: meukron_li...6-19.ini
File Size:6 KB
Last edit: 19 Jun 2024 19:08 by neerajbagi.
19 Jun 2024 20:57 #303382 by cmorley
What does the embedded gladevcp panel do?
19 Jun 2024 21:10 #303385 by cmorley
Also do you ever run a different version of GMoccapy in the same folder?
Ie it may record things in the preference file.
19 Jun 2024 21:13 #303386 by cmorley
How about translations? Does your system use translated text?
20 Jun 2024 04:37 #303396 by neerajbagi
The embedded panel is only for the zeroing of XYZ axes. No other functionality is being used with gladevcp.
I didn't run a different version of linuxcnc in the same folder, but I have copied my previous folder from the 2.8.4 machine to the configs directory, primarily to make similar changes to the .ini and .hal files.
No translations for text are being used.
29 Jun 2024 10:00 - 29 Jun 2024 10:04 #304014 by CNCGOOS
Replied by CNCGOOS on topic Duplicate settings in Pref File
It by me also stil happening.
with the same strange interval. i will look if there is by mee also a connection whenn jobs ar ready.
By me was the first time after opdating to 2.9
Last edit: 29 Jun 2024 10:04 by CNCGOOS.
15 Jul 2024 14:21 #305232 by Ritterchen
Replied by Ritterchen on topic Duplicate settings in Pref File
Have the same issue converting my config files from 2.8 to a 2.9 install.
I was guessing it might be from differences in the tool change files? But I can't really check about it -.-
Moderators: newbynobi, HansU
Time to create page: 0.240 seconds
