Duplicate settings in Pref File
- Ritterchen
- Thank you received: 18
24 Jul 2024 12:46 #305970
by Ritterchen
Replied by Ritterchen on topic Duplicate settings in Pref File
I can confirm that these errors appear only after a toolchange has been done after LinuxCNC started.
- CNCGOOS
26 Aug 2024 14:51 #308733
by CNCGOOS
Replied by CNCGOOS on topic Duplicate settings in Pref File
I Have runs som programs but error was stil happening. I have no Tool Change don but i have changed the Ofset tabel in G55 and G54.
than i get a duplicatet items in the file
- rickjmain
27 Aug 2024 21:57 #308859
by rickjmain
Replied by rickjmain on topic Duplicate settings in Pref File
I'm having the same problem as well. The system _name values get entered twice. The file change happens on exit, if I've edited my offests or done a tool change.
Using gmoccapy, dark theme. I have a glade vcp panel that handles air/mist/dust collection
- HansU
- Thank you received: 217
15 Nov 2024 17:32 #314578
by HansU
Replied by HansU on topic Duplicate settings in Pref File
I can reproduce it by running Gmoccapy from LinuxCNC 2.10 with a pref file which is created by 2.9 or earlier, so it has lowercase names for "system_name_gxx" and so on. After that, entries like "system_name_G5x = G5x" are added additionally to the existent "system_name_g5x = G5x".
If you try to run that with 2.9, it gives the duplicate settings error.
Now come the weird thing: Gmoccapy from LinuxCNC 2.10 works with the duplicate settings because it only takes those ones with the capital letter.
Internally Gmoccapy works with the capital letter, so "system_name_G5x", "Gtk_theme" and so on.
In 2.9 the configparser does convert the settings name to lowercase and the same configparser on the same pc but in a 2.10 environment does not sonvert it and write the capital letter. I have really no idea why the configparser does now take capitals into account.
However I provided a fix here: github.com/LinuxCNC/linuxcnc/pull/3181
The following user(s) said Thank You: tommylight, Ritterchen, pistrix
- HansU
12 Jan 2025 05:02 #318752
by HansU
FYI: it's now in 2.9 and so master
The following user(s) said Thank You: rickjmain, Ritterchen, pistrix, CNCGOOS
Moderators: newbynobi, HansU
Time to create page: 0.214 seconds
